Question about Garmin 010-00358-00 GPS Receiver
Blank Screen on Garmin E-Trex Vista
My Garmin E-trex Vista will have the screen go blank with the exception of one dark line down the center. It is somewhat random and it doesn't matter if I am running off the battery, plugged into the cigarette lighter or into the laptop. Sometimes it goes blank in a minute or two, other times in fifteen minutes. New batteries don't help.
  • 9 more comments
  • padge1 Sep 26, 2008
    i have the exact same problem, have tried to update the recievers software and it still happens,
  • Anonymous Oct 05, 2008
    My E-trex is doing the same thing. It has the current software.
  • philsp2006 Oct 13, 2008
    My Etrex Legend does the same thing: randomly crashes with a vertical line down the display, usually when switching to map view. I bought my legend in 2005 and have used it a lot and it's just now (in the last week) started displaying this problem.
  • shopper334 Oct 24, 2008
    Same exact problem. Only re-starts by removing the batteries, then repeats the same problem moments later.
  • tpell Oct 29, 2008
    I bought a bunch of Legends for my fire crew, and they've been dying left and right, with at least two doing this very thing, a line down the blank screen after startup.
  • Anonymous Nov 03, 2008
    Same exact problem. Legend, Only re-starts by removing the batteries. Anyone have an answer?
  • Anonymous Nov 10, 2008
    Garmin Legend, two years old this Christmas. Has developed the "flat line" problem, blank screen with one line down middle. Occurs shortly into boot up. Finds satellites and then "flat lines". Contacting Garmin to see what they say.
  • pilemehere Nov 14, 2008
    Garmin Legend with screen blank problem. Anyone get a fix on this problem yet?
  • prbeda Nov 20, 2008
    Garmin unit is a Legend, bought new in Jan 2007 and I have the same issue. Changed batteries and not better. Suddently problem stopped few weeks after.
  • Dyshippie Nov 20, 2008
    Same problem here, does anyone know of a fix yet?
  • JENNY7123 Feb 12, 2009
    My GPS is two years old. After I plug it in the cigarette lighter, two seconds later the screen goes black and does not come back on. What can I do?
  • Garmin Master
  • 638 Answers
Yes, this problem has been caused by the launch of a new satellite earlier this year. As soon as your unit gets a fix from the new satellite, it causes this problem. Simple immediate fix: disable WAAS in the setup. Permanent fix: go to Garmin website and update your unit's software and it will fix this temporary problem. Enjoy your GPS and don't forget to come back and tell us if this fixed your problem.
Posted on Dec 18, 2008
My garmin e trex vista keeps telling me acquiring satelite for 1 month now. What's the problem and how do I fix it?
have you tried moving it to another location?
does it have an internal or external antenna..either way give it a good view of the sky..
May 29, 2012 | Garmin GPS
Garmin e-trex Vista - blank screen
I would suggest that you contact Garmin for a replacement if you still have it under warranty. If your computer can still detect the Garmin when plugged in you might still be able to update the firmware but as you said it does not turn on then that would be a remote possiblity so it would be best to have it replaced if it is under warranty
Aug 19, 2008 | Garmin 010-00358-00 GPS Receiver
Window is filled with blue lines
BAD SCREEN cable connection. Your screen cable needs to be reseated. Better to take it to the professionals than toopen and attempt it yourself
Jun 30, 2009 | GPS
Trouble tunrning gps on with batterie mode
Solved my problem by buying another new model from garmin.The e'trex was great but I rather have a model with buttons on top and a larger screen so I orderd a gpsmap76cx. This e,trex I would of sold it but not with the problem I have with it.I will contac garmin support to see what they say.It,s a rebuilt model so I think the unit was sent back for a certain problem and even thou it was rebuilt the unit is problem cursed.Thanks for your time and I won't be spending another cent on this one.
May 28, 2009 | Garmin GPS
Display on my Garmin E-Trex Legend GPS
Sounds like the screen is shot and theres nothing really you can do to fix it, sorry :(
You can send it to Garmin for the flat rate repair fee of $79 dollars. I would recommend getting the new eTrex Legend H with the high sensitivity receiver if you want a similar model. It's sat reception will blow the prior version out of the water and has 24mb of memory rather than the 8mb it used to have.
Jan 19, 2009 | Garmin eTrex Legend GPS Receiver
Error message when downloading; No response. Check connection or
من مشکل ترا حل کرده نمی توانم کشاد خان
Jan 10, 2009 | Garmin eTrex Vista GPS Receiver
Screen goes blank except for a verticle streak
I had the same problem (blank screen, vertical line). After speaking with Garmin, I was told to make sure I was using the latest software version, and to turn off the WAAS function. Disable it for now, because the WAAS signal, coming from the satellite, has changed, and Garmin has not yet published a remedy to correct this problem. A fix should be out in a software update, sometime in the future, hopefully. I also did the software update, to the latest version 4.0. The unit performs perfectly now, however, the accuracy is not quite as good, due to the lack of WAAS. Good Luck!!
Nov 03, 2008 | Garmin GPSMAP 76S GPS Receiver
The problem is that your software version needs updating. A recently added satellite creates a glitch in the older software. Go to the Garmin website, load WebUpdater if you haven't already done so, and the updated version (3.8) will automatically install to your Garmin unit. I had the same symptoms, they have now disappeared and my Etrex Vista is back to normal.
Oct 14, 2008 | Garmin GPSMAP 76CS GPS Receiver
If that is the case you can go to to use the webupdater
Click on unit update. If that does not work then its most likely shot.
If you need further assistance please reply Thanks
If this works please dont forget to rate under my name on the premium post that you have.
Screen is unreadable
I have garmin e-trex Legend and it was just working fine then the next time i turned it on the screen is unclear with lines thru all the writing. Please help.
Jun 04, 2008 | Garmin eTrex Legend GPS Receiver
Garmin 010-00358-00 GPS Receiver Logo
319 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
