This problem should be removed because:
Problem with Vacuums
Is my vacuum FM310K considered a Fantom Fury? I need a belt and can't figure out which one to buy!
Solutions (1)
Here is a link to the parts available for your model of vacuum:
http://www.appliancefactoryparts.com/vacuumcleaners/brands/fantom/fm310k.html
And here is the link to the belt that you need (part number XFB1310):
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=1043859&modelsID=137895&typeName=vacuum cleaner
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
fantom fury vacuums
hey i was just wondering if anyone knew how to change the belt on a fantom fury vacuum...i have had the machine for probably 8 years and...
fantom fury vacuum
how do you change the belt on the fantom fury vacuum?
Where can I find a belt for my Fantom Fury vacuum
Where can I find a belt for my Fantom Fury vacuum and how do I replace it?
How do you change the belt? I cannot figure out
How do you change the belt? I cannot figure out how to take it a part.
Add Your Solution
progressive on off switch does not work it always...
My progressive on/off switch does not work, vacuum is constant running on, I have to UN-plug it to turn it off, and when...
How do I fit the exhaust pre filter seal
I need help fitting the exhaust pre filter seal on the vacuum. It is the seal that is behind the vacuum at the bottom...
Top Vacuum Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
