Question about Acer Aspire 3000 Notebook
Component missing Acer aspire 3620
Acer aspire 3620...I've replaced the fan only about 2 months ago, but the computer keeps on warming up too fast. May it be because i miss someone?
  • Acer Master
  • 13,433 Answers
Hey,
The vga board on this laptop heats up very easyly and the heatsink is uselessly small. Video may fail withing 12 months. I would recommend another laptop model, this series 3xxx and 15xx have cooling issues and parts fail often. Not much you can do about the problem.
Thanks,
Ekse
Posted on Aug 29, 2008
Acer aspire overheating fix
What model of acer apire ?
When a laptop gets hot physically hot, to the touch you know something isn\'t quite right. It\'s normal for a computer to get a bit warm as it runs, which is why computers have a built-in cooling fan in addition to a heatsink and cooling vents. Excessive heat, however, is almost always an indication that something is malfunctioning. This is no different with the Acer Aspire 5000.
What\'s Happened If you\'ve ever looked inside of a computer or seen an "exploded view" of a laptop, you will know that thousands of components work together to ensure your computer\'s best performance. The cooling fan is activated by temperature readings from the central processing unit, which heats up and cools down depending on what it is being used for. Sitting idle, the temperature of the CPU will be low and the fan won\'t come on. When the computer is performing a few tasks simultaneously, the CPU is taxed and the fan kicks in. When you hear the fan whirling excessively, the computer is overheating which can damage the CPU. Thermal compound is a sticky paste that is placed directly onto the CPU. http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink. b> Checking Temperatures You can download programs to monitor the core temperature of your CPU. Programs like Core Temp, Speed Fan or Motherboard Monitor use the hardware monitoring devices built into your Aspire notebook to track its core temperature. Different sources suggest that the Aspire 5000 can run at a different maximum temperatures. Users on Tech Support Forum say 50 to 60 degrees Celsius is normal even optimal and that above 75 degrees is a problem. Acer\'s technical manual for the Aspire talks about external temperatures for running the computer efficiently (between minus 20 and 30 degrees), but it says nothing of internal temperatures. A few different users reported overheating to the point of 90 degrees, at which point the computer freezes and shuts off. Warranty Fix Computer original equipment manufacturers like Acer sell every computer with a limited warranty. Overheating is usually covered by this warranty. If your computer is repeatedly reaching high temperatures, and you\'ve recorded the temperatures with software, contact Acer for a replacement or a repair. Out-of-Warranty Fix The simplest way to address an overheating problem is to let the computer breathe a little. Make sure that you use it on a flat, hard surface so that air can pass to the fan easily and without interruption. You can buy laptop cooling pads at most computer stores that are designed with this in mind. As a complex fix for an out-of-warranty system, you can follow a picture tutorial from MPS Computers to replace the sealant around the heatsink with a new glue called Arctic MX-2. This glue allows more heat to escape and brings the core temperatures down about 10 degrees. Acer Aspire Overheating issues http://www.techsupportforum.com/forums/f108/acer-aspire-overheating-issues-214199.html 257 software downloads results for "temperature"
b> Acer Support - ASP Login http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/S.G_AS3000_3500_5000_BOOK.pdf
Feb 26, 2013 | Acer Aspire Computers & Internet
My Acer Aspire 3620 crashed. I reloaded my
How did you access this website if your modem is not working?
Jun 17, 2009 | Acer Aspire 3100-1405 Notebook
I need to replace the keyboard on an Acer Aspire 3680 series laptop
Hi there.
Remove the laptop battery and the AC power supply, open the lid as far back as you can take it.
Get a small flat headed screwdriver, now, you have to take off the keyboard bezel, this is the strip of plastic above the keyboard with the power button on it, the best way to remove it is to start by the on/off button by gently prying the bezel up from the lid hinge, once you have one side out gently pull it up using your fingers, it will unclip and lift away.
Next you have to remove 2 screws from the top of the keyboard, these should be visible to you, once the screws are out carefully lift the keyboard up, you will see a ribbon cable that is connected to the motherboard, gently pull the tab up on the connector that the ribbon cable sits in and it should release it and you can now remove the keyboard and replace it.
To re-assemble just follow my direction in reverse.
Please post back with the results and for any additional advice if needed.
Good luck and thanks for using FixYa!!
May 22, 2009 | Acer Computers & Internet
Replacing cooling fan in ACER ASPIRE 3620 Notebook
Try this link:
http://www.insidemylaptop.com/clean-cooling-module-acer-aspire-3620/
Apr 17, 2009 | Acer Computers & Internet
Need to open acer aspire 3620 to replace fan
I believe that the 4020 and 3620 have the same chassis. See if this helps
To the left of the battery there is an I/O cover with 2 screws, then the heat sink cover has 2 screws. There you should see the Thermal Unit (fan). It has 4 screws. Take those out and lift the unit out.
Let me know , curious to see if they are indeed the same chassis.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 16, 2008 | Acer Computers & Internet
Acer Aspire 3620 Screen
Check Acer's website for a BIOS update. I've seen a LOT of laptop's screen issues been related to the power saving settings in the BIOS. Sometimes screens going black very fast and not working properly can be caused by that.
The Power Inverter could also be the problem which you wouldn't be able to repair yourself. If you purchased it at Best Buy you can take it to them and they could get that fixed for you (at a charge if there is no warranty with that).
Jun 22, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3620
u simply need to call up acer support as ur acer system is getting heated up and u need to get the servicing scheduled for the cpu fan and heatsink and that should fix the problem
Mar 24, 2008 | Computers & Internet
Acer Aspire 3620
I hope this helps:
This first link is for windows vista, if thats what you are running
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Acer-Aspire-3620-Bluetooth-Driver-601.shtml
now the this one is for windows xp: click the link and then click the little green box on the left witht he arrows pointing down.
http://www.notebook-drivers.com/ViewDownloadUrl.asp?ID=87869&brNum=3&show=0
Jan 21, 2008 | Computers & Internet
Acer Aspire 3000 Notebook Logo
118 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
