Question about Symbol Spectrum24 Wireless Neworker (LA-4137)
No Light I just setup my desktop to have wireless security. When I went to my Laptop I noticed my wireless card light no longer comes on. Should be unrelated problem. Does this mean that my Symbol Spectrum 24 wireless card has failed?
Either an IP conflict try using DHCP or you will need to reconnect with the laptop and add the wep Key or whatever encryption key/keys are set.. problem solved make sure your laptop support the type of security you have set...
I’m happy to assist further over the phone at https://www.6ya.com/expert/michael_8d7ee7163ca2d2d6
Posted on May 07, 2009
SOURCE:
Tip
Setting up Wireless on router and wireless security
For setting up any router you can follow the below simple steps
  1. Connect the router with a power cable and switch on the poser, reset the router with its reset button normally you can find the reset button on the rear side of the router for 30 seconds and then switch off and on the power
  2. After reset conenct the router to any laptop or desktop with a cable and also connect the router to the modem or the internet service provider cable
  3. after all connection lights will come on go to right hand side corner of the computer and check if the network connection is showing connected
  4. Once you are connected with a wired connection open a page of internet explorer and type in router addess normally it will be http://192.168.1.1 or http://192.168.0.1 and then type the username and password default usernames and passwords can be found in router manual.
  5. Once the router setup page is open you can confugure the router easily without the CD setup.
  6. The advantage is you do not have to run the setup CD and you can also do wirless settings for your wireless laptops or devices
  7. Go to the wirless settings page and you can select the wireless on and off or you can setup a wireless security to avoide your router with unauthorized acess
  8. I would recomend always keep the wireless network secured if you are using the router for a home or small office as there can be people who will be using your bandwidth for free without your permission
  9. one more tip i would like to give whenever any kind of setup is required on the router do it by a wired connection only and not thought a wireless pc or laptop as it can disconnect you from the router in between of your setup
  10. WEP is the kind of wireless security which is easy to setup and remember and most wireless cards of laptops and computers support it
All the best with your wireless router configuration and security setup
Regards
Vikram
on Dec 02, 2009 | Computers & Internet
I have a netgear WGT624V4 and I'm trying to setup to use laptop wireless and I having issues can anyohelp
Network Key (WEP, WPA, WPA2 Encryption key)To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
May 02, 2012 | NetGear Computers & Internet
Wireless belkin router all light are on but wireless light, my laptop and apple will not work, the light blinked red for a few seconds then went out again been having trouble with the connection for a...
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Dec 07, 2010 | Belkin (F5D5231-4) Router
Laptop stopped connecting via wifi to home network.
The wireless settings in the Belkin has been setup with encryption.
You can restore the Belkin back to the factory default by powering up the Belkin and press the RESET button for 7 secs.
It is not wise to leave your wireless router unsecured, anyone can access your network and Internet connection and use up your allocated download limit. Once you exceed your download limit you could be slug with addition charges - this depends upon your contract with your ISP.
For details on securing your wireless router and configuring the wireless card in the laptop, please click on this link and follow my instructions :-
Dec 31, 2009 | Belkin (F5D7231-4) Wireless Router
Security(wps) light not lit on router
You need to setup the wireless security ON on the router by loggin in to router setup page for that you need to connect the router with a ethernet cable with the computer or laptop and open the router setup page with router IP in internet browser, if you can tell me the model number of the router and brand i can give you step by step process to setup the security on the router.
on selecting the security as any apart from none the light comes on
Let me know if this will help
Regards
Nov 30, 2009 | Computers & Internet
I have two desktops and one laptop on my di-524. One desktop no longer connects. The others are fine. Is this a router or adapter problem? I tried a d-link 'stick' but after working for one day, it no...
One desktop and 1 laptop are working that means your router must be working.
1 desktop is not working. Is that wired to the router or wireless ?
If it is wired then check the light on the router, If your computer is connected to port 1 of the router then port 1 light should lit up. If the light is not lit up then check the connection.
If the light is lit up then check the IP address on the computer.
If it is wireless desktop then check the wireless connection.
Click Here for more info
Nov 24, 2009 | D-Link AirPlus DI-524 Wireless Router
Black screen blinking green light
You have a bad backlight fluorescent bulb.
Dec 28, 2008 | KDS 17S 17" Monitor
No internet connection with laptop computers in home
Good day!
If your Desktop computer is hardwired to the router and your laptop computers can't connect wirelessly, it could be your wireless computers are not synchronized with your router by not having the same settings as the router.
You can use the desktop machine to access your router web interface (setup page) to check the wireless settings such as SSID (Network Name-> Name of your wireless signal shown on your laptop computers), channel and security (wether it is WEP or WPA encryption)
The channel and network name will be automatically detected by the wireless computers. If you have an encryption/security on the router, you need to type the password on the wireless computers for them to authenticate.
Try these and post back if there's any progress
Aug 03, 2008 | NetGear : WGT624 108 Mbps Wireless...
Open Questions:
AOL password reset phone {&$&{[email protected]*O352} NuMbEr teCHNIcal Support for USA American This AOL USA phone number +1:8OO:,:24O0352 is ranked #2 out of 2 because 7,728 AOL USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:24O0352 is to reach the AOL USA password reset department for problems like Where to buy, Complaint, password reset, Repairs, Returns. As far as we can tell, AOL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AOL USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO24OO352 and ways to call or contact AOL USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AOL USA Calling AOL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AOL USA password reset can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AOL USA's password reset department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AOL USA's phone numbers against each other. Contacting AOL USA in General While I8OO24OO352 is AOL USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO24OO352 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AOL USA help by calling them, is that other techs give their password reset at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AOL USA.
Oct 17, 2019 | AOL Computers & Internet
See all Symbol Spectrum24 Wireless Neworker (LA-4137) Questions
Symbol Spectrum24 Wireless Neworker (LA-4137) Logo
65 people viewed this question
Top Symbol Computers & Internet Experts
Ekse
Vish Iyer
Vish Iyer
Thomas F. Schneider
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
