Question about Shop Vac Vacuums
My shop vac will not turn on. model 87L400 - Shop Vac Vacuums
2 Suggested Answers
SOURCE:
SOURCE: craftsman shop vac no power when turn on
I just picked up a similar model someone was throwing away. turns out there is a thermal fuse inside the motor housing that blew. I just need to find the values of the fuse and repalce with appropriate size. motor runs when fuse is bypassed.
Posted on Jun 09, 2009
Shop vac doesn't work. Does my shop vac have a thermo fuse?
Contact the manufacturer of device. They may help you. If not, make sure that current is reaching the on/off switch and that the power is reaching the motor - if power gets to motor and still nada then the issue is probably with the brushes not making proper contact with the commutator.
Dec 23, 2016 | Shop Vac Vacuums
Shop vac stopped working
Motors have a thermal safety fuse in the field winding. If it overheats, it will blow and either can be replaced or the whole field winding will have to be replaced. It is wired and is not considered to be a user servicable item.
Apr 22, 2014 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
Wet vac wont turn on
That Model of Shop vac often has on/off switch failure.
Dec 02, 2013 | Craftsman 20 gal, 6.5 Peak HP Wet/Dry Vac
Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
May 16, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
Craftsman shop vac no power when turn on
Apr 14, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Shop vac 90L400 stopped working won't start
I had the same problem with the same model. Turned out to be the thermal fuse on the motor housing, between the switch and the windings. Took it apart and replaced the melted solder with 14 guage copper wire. Works fine! No thermal protection but I don't use it for long at a time anyway. Check the switch for continuity, if good then check the thermal fuse for continuity. If good, it's the motor.
Oct 19, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Need an owner's manual on line
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19255&thid=658668
Posted by LinJay on Jun 09, 2008
I have lost my owner's manual for my shop vac and need to figure out how to set it up so I can pump out my flooded basement using a garden hose.
Is there anywhere I can find an owner's manual on line??
The model stated on my vac is not what I clicked on your site....my vac states:
Model QPV 10.5
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am supplying you with the contact for the Shop Vac Factory Service for owner’s manuals listed below: for the website and the customer service line, but make sure you include the Shop Vac Model # and the Serial # as well. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp Customer Service 570-326-0502 Phone #
Shop-Vac Corporation Customer Service 570-326-7185 Fax #
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 09, 2008 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Vacuums Logo
93 people viewed this question
Top Shop Vac Vacuums Experts
Mike
jdthefixer
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
