I'm having problems with the power windows, door locks and courtesy lights in my 2003 chevy venture all problems seem to start at the same time. check the fuses none are blown and the power windows are not getting power through the fuse but the locks and courtesy light are getting power through the fuses but still won't work
    President:
  • 2,961 Answers
Post this in the correct subject, no body with car experience will see it in the pc catagory
Posted on Aug 19, 2008
2003 Chevrolet Venture - my courtesy lights, power windows, power door locks short out when turning on the ignition. They come back on when turning off the ignition
As far as power windows, pull the circuit breaker, key on check for voltage at the circuit breaker, use a test light. I was thinking ignition switch, usually the ignition switch and lock cylinder are two different components. I'd have to check voltage to and from ignition switch, before deciding if the problem is ignition switch. RAP is retained accessory power, shouldn't come into play until you turn off the key. The windows may operate for about 10 minutes or you open the door. Just my opinion.
Feb 18, 2018 | Chevrolet Cars & Trucks
I have a 2005 Chevy extended cab 1500 and the controls on my driver side door aren't working. The door is saying it ajar when it's closed. I can't roll the windows up or down. Is it the master switch?
How to fix the Chev power window door lock switch - YouTube
? 5:04
https://www.youtube.com/watch?v=XDKaDURD8Sc
Jul 13, 2013 - Uploaded by spelunkerd
How to fix the Chev power window door lock switch ..... Some time later my drivers side window stopped working in the down position. ... These intermittent electrical problems are frustrating,aren't they? .... How To Install Replace Door Locks Chevy GMC Truck Silverado Sierra Yukon Tahoe Suburban ...
Diagnose Power Door Locks Dont Work Properly - Auto ...
www.auto-repair-help.com/.../diagnose_power_door_locks_dont_work_...
An inoperative power door lock can be caused by the switch, solenoid, wiring problem or ... Hi, I have a 2005 Nissan Sentra and the power locks aren't working. .... Hi, mypassenger door locks/unlocks both doors but my driver side door works independently and .... I have a 1986 Chevy Silverado K10 with auto door locks.
SilveradoSierra.com • 2003 silverado no power in right door ...
www.silveradosierra.com/.../2003-silverado-no-power-in-right-door-t30...
Dec 26, 2015 | Cars & Trucks
2003 chevy venture plastic window clip problem window coming off track
last time i checked you can not get that clip seperate from the windows regulator,,,and the window regulator was like $350,,,your gonna have to pull the inner door panel off to acess it,,,i would look for a used one,it would be alot cheaper
Oct 19, 2009 | 2003 Chevrolet Venture Passanger
03 Chevy Venture....Clarification Passenger Window stuck down.
It will be in the switch lift up the controls on both the drivers side and passenger side the wires going into the connection wiggle then and the button at the same time if you get any movement then you have a broken wire if not use a test light hook one wire to some metal and the other to the wires if their is any power the light will come on, if no light then you probably have a broken wire. The passenger side power comes from the drivers side control. When you open the doors you will see a large black set of wiring harness in the door going into the side under the dash that is the wiring harness for all the power windows and door locks, open it and test those wires for power.
Aug 04, 2009 | 2003 Chevrolet Venture Passanger
Venture van power door problem
It sounds as though one of the proximity sensors is faulty. Also try giving the tracks for the door a good shot of white spray lithium grease. The door may be binding enough so that the emergency reverse is kicking in.
Jul 30, 2009 | 2003 Chevrolet Venture Passanger
I have a 2004 chevy venture. The power locks do
open the door and look on the side of door for little switch up and down ,it a safety switch ,little gray lever sticking out on the side of doors, move it up or down ,read decal on the door jam,hope to help robert b.
Jul 16, 2009 | 2003 Chevrolet Venture Passanger
2004 Chevy Venture Interior light will not turn off when you put on drive or lock the doors. I have to use Interior Lamp Overide Switch to turn off the light.
check for an open door ( all doors ) , defective courtesy light door switch, or short in interior light electrical circuitry.
Apr 04, 2009 | 2002 Chevrolet Venture Passanger
Chevy Venture power windows- 2003
It is possible that it is the fuse but if so something caused the fuse to blow. It may be in the wiring which if you pull up the carpet by removing the door floor trim and lifting the carpet you will see the wiring underneath. Probably laying in water. Look for splices in the wiring which will have corroded. Repair the wiring then replace the fuse.
Another problem may be in the motors found inside the doors. The brushes may have worn out. If so you need to replace the motors. Unlikely that both motors failed at the same time though.
Usually the drivers door first since it is the most used.
Dec 17, 2008 | 2003 Chevrolet Venture Passanger
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
