Question about Brother MFC-8220 Fax
Brothers MFC 8220
Receiving error message 6A
what do I do
  • Anonymous Sep 11, 2008
    Error 6A. Has anyone found a solution?
    Please post if there is a fix.
    Thanks.
  • nene684 Jan 05, 2009
    i can't get it to send out going faxes everytime i do it tells me to unplug it and call brothers does any1 have there phone #
    Problem Solver:
  • 6 Answers
It sounds like your machine has a mechanical malfunction and will need to be serviced.
Posted on Oct 10, 2008
When I turn on my brother mfc 8440 I received this message in the screen : Error 6A
To clear the error, the procedure is as follows:
1. Turn off printer
2. Hold down MENU button on front panel and turn on power while continuing to hold.
3. Release button after 5 seconds (after the Please Wait message)
4. If error still occurs:
5. Press 91
6. If error still occurs:
7. Press 99
This should clear the error.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jul 05, 2011 | Office Equipment & Supplies
My brother mfc-8220 printer does not want to print. the drum was broken and i replaced it and the toner but yet i hear a grinding sound followed by an error message saying paper jam. I removed the paper...
it might be that the drum replaced is tighter or the space to pass with in the drum is less. friend did u replace the drum of a same model and same type?
May 12, 2011 | Brother MFC-8220 Fax
BROTHER DCP 8020 ERROR 6A
A Brother MFC-8840D reported an Error 6A on the panel after a short power-outage that occurred. Calling Brother indicated that the error reflects that.
1. Turn off printer
5. Press 91
7. Press 99
Good luck
Please rate FIXYA
Apr 07, 2011 | Brother DCP-8020 Laser Printer
Printer repair brother mfc 8840dn
To Clear the error follow the procedure
1:) Turn Off the printer
2:) Hold down the menu option on the front panel and turn on the power while the menu button is still pressed
3:) Release button after 5 seconds (after the Please Wait message)
4:) If error still occurs Press 91
5:) If it still ocurs press 99
May 07, 2010 | Office Equipment & Supplies
Machine error code 6A what that means?( Brother mfc 8440)
I argued on the phone with a BROTHER REP. that he should give the codes and directions to reset the machine, he refused time and time again, saying that this means physical damage to the machine an re-setting it is impossible to help, but i insisted, and it did fix the problem and the error went away.
here is what you should do, unplug for 10 sec. press and hold on the menu key while you plug it back in untill you see the screen "parameter init" press 99 and wait, this is what i did and it fixed the problem !!
Jan 26, 2010 | Brother MFC-8440 All-In-One Laser Printer
Having problems with long distance fax transmissions - receiving number not receiving fax. Fax machine: Brother MFC-8220.
Is the 1 placed infront of the number, is the line part of a PBX system requiring to dial a 9 to get a outside line.
Aug 13, 2009 | Brother MFC-8220 Fax
Toner empty error message on brother mfc 8220.
OK
Here's what you do if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Feb 28, 2009 | Brother MFC 8220 All-In-One Laser Printer
MACHINE WILL RECEIVE BUT NOT FAX
That code is a Bad Main Board.
Try unplugging power cord for 10 seconds.
Aug 06, 2008 | Brother MFC-8220 Fax
Brother MFC-8220 Fax Logo
220 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
