Question about Garmin 010-00358-00 GPS Receiver
Garmin e-trex Vista - blank screen
My Garmin E-trex Vista will have the screen go blank with the exception of one dark line down the center. It is somewhat random and it doesn't matter if I am running off the battery, plugged into the cigarette lighter or into the laptop. Sometimes it goes blank in a minute or two, other times in fifteen minutes. New batteries don't help.
Wayne
  • wstewart Aug 20, 2008
    Yes, this confirmed what I suspected.
    Wayne
    Master:
  • 623 Answers
Go to this website
http://brilliantcorners.org/nodes/87-fixing-a-dead-garmin-gpsmap-60csx
Posted on Aug 19, 2008
  • 928 Answers
I would suggest that you contact Garmin for a replacement if you still have it under warranty. If your computer can still detect the Garmin when plugged in you might still be able to update the firmware but as you said it does not turn on then that would be a remote possiblity so it would be best to have it replaced if it is under warranty
  • Thomas Lim
    Thomas Lim Aug 19, 2008
    Hi! any updates to my directions for the update?
My Garmin Etrex Legend starts up and finds the satellites, but then screen goes blank except for vertical line on the screen.Stays that way until batteries wear out. Fixable?
I have the same Garmin product. It had a problem displaying anything. I went to the Garmin web site and got tech support. They fixed the problem by telling me what to do. Try them befor you throw it away. But it sounds un-repairable
Aug 11, 2009 | Garmin Etrex Legend Handheld Gps
Screen goes blank after locating sattilites.
Accordingto Garmin, this problem can be fixed by disabling the WAAS feature in teh set up menu. There is an incompatibility between the old Garmin software and latest WAAS upgrades. Later software from Garmin is supposed to fix this problem.
May 21, 2009 | Garmin eTrex Legend GPS Receiver
Display on my Garmin E-Trex Legend GPS
Sounds like the screen is shot and theres nothing really you can do to fix it, sorry :(
You can send it to Garmin for the flat rate repair fee of $79 dollars. I would recommend getting the new eTrex Legend H with the high sensitivity receiver if you want a similar model. It's sat reception will blow the prior version out of the water and has 24mb of memory rather than the 8mb it used to have.
Jan 19, 2009 | Garmin eTrex Legend GPS Receiver
Error message when downloading; No response. Check connection or
من مشکل ترا حل کرده نمی توانم کشاد خان
Jan 10, 2009 | Garmin eTrex Vista GPS Receiver
Screen goes blank except for a verticle streak
I had the same problem (blank screen, vertical line). After speaking with Garmin, I was told to make sure I was using the latest software version, and to turn off the WAAS function. Disable it for now, because the WAAS signal, coming from the satellite, has changed, and Garmin has not yet published a remedy to correct this problem. A fix should be out in a software update, sometime in the future, hopefully. I also did the software update, to the latest version 4.0. The unit performs perfectly now, however, the accuracy is not quite as good, due to the lack of WAAS. Good Luck!!
Nov 03, 2008 | Garmin GPSMAP 76S GPS Receiver
Blank Screen on Garmin E-Trex Vista
The problem is that your software version needs updating. A recently added satellite creates a glitch in the older software. Go to the Garmin website, load WebUpdater if you haven't already done so, and the updated version (3.8) will automatically install to your Garmin unit. I had the same symptoms, they have now disappeared and my Etrex Vista is back to normal.
Oct 14, 2008 | Garmin GPSMAP 76CS GPS Receiver
If that is the case you can go to www.Garmin.com to use the webupdater
http://www8.garmin.com/support/download.jsp
Click on unit update. If that does not work then its most likely shot.
If you need further assistance please reply Thanks
If this works please dont forget to rate under my name on the premium post that you have.
Aug 19, 2008 | Garmin 010-00358-00 GPS Receiver
Yes, this problem has been caused by the launch of a new satellite earlier this year. As soon as your unit gets a fix from the new satellite, it causes this problem. Simple immediate fix: disable WAAS in the setup. Permanent fix: go to Garmin website and update your unit's software and it will fix this temporary problem. Enjoy your GPS and don't forget to come back and tell us if this fixed your problem.
Screen is unreadable
I have garmin e-trex Legend and it was just working fine then the next time i turned it on the screen is unclear with lines thru all the writing. Please help.
Jun 04, 2008 | Garmin eTrex Legend GPS Receiver
Screen Blanks
11-08-07
I had the same problem with an etrex Vista. I spoke with Garmin, they said that a recently launched WAAS satellite is interferring with some models (he mentioned it is the models with a black and white screen). Garmin tech support said that they're working on a software patch but for the meantime switch WAAS off.
Call Garmin tech support with any questions or to find out about the software patch, 1-800-800-1020
Nov 04, 2007 | Garmin eTrex Vista Cx GPS Receiver
Garmin 010-00358-00 GPS Receiver Logo
130 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
