Question about Acer Computers & Internet
Why is my monitor screen changing colours. Goes green and blue. Also wavers making it very hard to look at.
    Novelist:
  • 125 Answers
Check the cable connections on the back of the computer and make sure none of the pins are bent on the cable , also check the same connection into the monitor and that none of those pins are bent either , it may be as simple as buying a new cable.
Cheers
Posted on Aug 19, 2008
  • Josh Gahan
    Josh Gahan Aug 19, 2008
    Also if none of the pins are bent make sure the cable is connected properly
My Samsung LCD TV slowly flahses colours, each about 2-4 seconds
hi,
your lcd is in test mode. you may try off the power. press and hold menu + source + power on.
this should go back to normal mode.
Apr 01, 2010 | Samsung LA40M81/BDX 40 in. LCD TV
Distorted images
try to change resolution settings.
right click on your desktop and click properties.. >> go to settings tab and change the resolution and colour quality and see if it works.
Good Luck!
Feb 26, 2010 | Dell E228WFP LCD Monitor
ADI GD-166G SCREEN HAS GREEN COLOUR DISPLAY
hope u r a professional..as u r handling chip-level repairing of monitor, knowing itz hazardous n dangerous..
however, check thoroughly for dry soulderings..(esp. at the crt base)..[this chance is maximum]..
see if the base is loose or faulty..
yes, it can b the 'chroma ic'..but don't ignore the associated components..(esp around the base)..
check video amplifier n sub section..
the colour diodes, transistors n resistances at the base..
for better supervision contact ur system admin/vendor....
Nov 11, 2009 | ADI Corporation MicroScan 5P (White) 17"...
Vertical lines on screen
3 problems:
1. your monitor but i doubt it
2. vga component in your computer
3. atx component in your computer.
try go to a friend and make some changes. don't buy anything first. just test them to see what's bad.
Nov 01, 2009 | BenQ FP71G+ 17" LCD Monitor
My moniter screen has turned to blue screen and i am not able to
On your CRT back PCB thers three transistor on for red green and blue its possible that your blue transister is faulty. Try moving your cable see if the colour changes it can also be a faulty 15pin plug
Have a nice day
Dec 24, 2008 | HP Compaq FS7600 17" CRT Monitor
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
Screen colour error
Recommend to go to the color settings and change it to the use settings and adjust accordingly.
Oct 17, 2007 | ViewSonic VA1930WM LCD Monitor
Color Problem:
in Monitor CRT Red-Blue-green cathode guns are there.. Mixing of these colour we can get the original colour chrominace technique. if any of the colour gun is faulty we would get more REad or blue or green picture. Measure RGB voltages. you can verfify which gun is faulty. if then check RGB processing circuits. Else there might be problem Chrominance colour decoder system. Contact service centre
Jan 09, 2007 | Samsung SyncMaster 551 15" CRT Monitor
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
