Question about Kenmore Elite 45986 Front Load Washer
WILL NOT STRART ONCE SELECTION IS MADE
CLEAN OUT FILTER IN FRONT BOTTOM .TRIED TO START THE WASHER,BUT THE START BUTTON JUST BEEPS TWICE
  • Magee1020 Aug 20, 2008
    cleaned out filter,washer won't restrat, just flashing 16 minutes remaining. now what??
    Genius:
  • 1,028 Answers
Try unplugging from wall hold start/power button down for a few sec also ck door lock
Posted on Aug 21, 2008
Bosch dryer beeps
Two Beeps on my Bosch WTE84100au Condensing Dryer means a thermal overload but also means one of the thermal sensors is faulty .... as if it is always on.
Open the door, pull out the lint catcher and clean around the silver probe (it's like a shiny 1/8" nail sticking into the cavity below the lint catcher). If it still doesn't work (and still 2 beeps), just flick it lightly a couple of times. If it still doesn't work, flick again from the other direction.
Mar 24, 2014 | Dryers
The washe is flashing F-21.
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Mar 12, 2011 | Whirlpool AWM9000 Front Load Washer
Kitchenaid washer model khws02rmt1 error f2
It is probably error code F02 and it indicates a draining problem and the display can be cleared by pressing the Pause/Cancel button twice. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working.
Disconnect power and
remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Let us know if the problem persists.
Jan 19, 2011 | Washing Machines
Error code F02 appearing. Not fully draining.
The fault code indicates a draining problem and the display can be cleared by pressing the Pause/Cancel button twice. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Oct 26, 2010 | Kenmore 44832 Front Load Washer
GET ERROR CODE f-2, AND IT WONT DRAIN THE WATER kENMORE ELITE hE3T
It is a code for a long drain problem (more than eight minutes). Press the Pause/Cancel button twice to clear the display. When the display is clear, press the Drain & Spin button then select No Spin by pressing the Spin Speed button, and then press and hold the Start button to start draining the water.
Use your senses to check whether the drain pump is running or not. The drain pump is located at the front right bottom of the machine. Check the volume of water being discharged to the drainage.
Disconnect power to the washer and check the drain hose for clogs and kinks, and then repeat the No Spin draining process, if the drain pump is running and water is being pumped out, until the water is completely drained out of the washer. Just press the Pause/Cancel button twice when the code appears to clear the display and restart draining.
Make sure the drain hose is raised no more than eight feet above the floor where the washer is installed. The drain pump cannot pump the water properly out to the drainage more than eight feet above the floor.
When draining is complete, empty the machine then prop up the bottom front edge of the washer to allow easy access to the three screws attaching the lower front access panel to the cabinet. Remove the screws, and then push the panel down and off the cabinet to access the drain pump.
Place a shallow pan or lay a towel under the filter to catch the water from the pump. Unscrew the filter from the pump assembly and drain the water. Clean the filter for any debris that might be causing the pump to work poorly then screw it back in place.
Slide the lower front access panel up back into the cabinet and secure it the three screws.
Mar 12, 2010 | Washing Machines
My washer will not start. I press the start/pause button and it just beeps twice and does not lock door or start wash. ge adora model wcvh6260
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Aug 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
WASHER WON'T START
possible door latch or even the strike on door itself may be broke
Sep 04, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore Elite HE5t Power and Errors
try hitting pause/cancel twice to clear the codes
May 17, 2008 | Kenmore Elite 45986 Front Load Washer
Wont start on any program
Close your faucet valve & unscrew your hoses to check screens on hoses & machine. Clean out well. Water from faucet shd be in good pressure. Refit, check for leaks. If this is not the problem change your inlet valve, it is easily done.
& rate me pl.
May 05, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Kenmore Elite 45986 Front Load Washer Logo
94 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
