Forest Riverhttps://forestriverinc.com > Component-Manuals
PDF
Plug earphones into jack for private listening. Overrides speakers. USB Input. This input is for service personnel only. COAXIAL Output. Connect to your SPDIF ...
39 pages
Sansuihttps://sansuiworld.com > assets > qled-smart-tv
PDF
ANT: Connect the antenna to TV via coaxial cable on ANT jack of the back panel. • AV: The output AV terminal of DVD can be connected with the AV input port ...
30 pages
Based on the user manual for your TV, I don't believe you can play media from a USB device on your 39in model.
The USB port on the TV is used for the 'Time Shift' feature on your TV (which allows you to pause, play and rewind broadcast TV).
I do not believe your TV can play digital media without a device providing video output.
Hope that helps. http://www.sansuiproducts.com/images/manuals/SLED3900.pdf
The TV has some firmware defect. Seek tech support. Unplug it from AC mains wall socket, and plug it again after 5 minutes. This must make it a hard reset.
hit done? But first read through the manual and see if there is any sort of initiall startup procedure. (unlikely) Then try checking all connections. If that doesn't work, unplug, check for the right connection ports, and replug everything. If it still doesn't work, take it to a professional or return it and buy a new one, it could just be defective.
LG 32D450 LCD TV doesn't support video playback from usb. The USB 2.0 input of this particular model can only read jpeg format (photo/snaps) and MP3 format for music playback. please click the link below and see the technical specification and USB input.. http://www.lg.com/us/tvs/lg-32LD450-lcd-tv
