On Daytek LCD DT4040, After some time like 2-3 hour, sometime 10-15 minutes, image from source disapear and red and green line appear... Not actually on DVI input, no trouble since 30 minutes.. on test for now...
  • Anonymous Jan 23, 2009
    Daytek DT4040 - Turn it on and after about 3 seconds the display goes black but audio is still fine. Anyone know what causes this?
  • Anonymous Mar 25, 2009
    after turning it on for first time of the day after about 1 to 4 hours later it starts to loose its images and turns red and green until it turns black turned it off and back on and the screen turns on and is good for rest of the day. i think it may have something to do with the heat or lack of heat because once it warms up it works fine with no colour problems.
I have a daytek dt 4040 and when i turn it on,i push the red button ,flash 5 or 6 time and turn green have sound but no image. what the problem
Posted on Jul 06, 2009
SOURCE:
A horizontal band of green and red lines across the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Panasonic TC-P46C2 - 46 Inch 720P Plasma...
Toshiba sl738b
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
?Check the cables, connectors and connections.
Take it to a repair shop.
Apr 11, 2014 | Toshiba Televison & Video
Sharp Aquos LC-C4654U The TV blacks out frequently. The blackouts last aprox. 1-2 sec and when the picture reappears, the blue box appears in the top right corner (just like when the tv is initially...
Good day!!! That problem is cause of faulty capacitors on the power supply... just look at the actual image of it through visual check if the capacitors look like leak/bulged on top you need to replace it to end that problem... hope it helps... \thanks for using fixya..
Sep 13, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
Daytek 46" LCD TV.. When
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck in solving the problem....
Jun 09, 2011 | Televison & Video
My Sabre LCD TV is blinking red and green on power button and will not come on
My TV just did this 2 days before Thanksgiving. I just messed with it and fixed it today. Unplug it from the power source for atleast one hour. Plug it back it. Hold the power button til constantly flashes red and green. Wait at least one minute while it continues to flash. Turn it off. Flip the big power source button on the back to off && then on. Then hit the power button on the side, and it should turn on. Worked for mine. Hope it helps.
Aug 31, 2010 | Sabre LCT371BKA LCD TV
Daytek DT4660 - at ac on , led grn for 2-3 secs, one blink red, pause, 2 blinks red, pause , 3 blinks red, pause ,then rapid 5-6 red blinks followed by repeat of above. I've unplugged the 12 volt connector...
Hi
I work on Daytek 4660 models. I have seen the problem you are having and have solved it a couple of times by replacing all the capacitors in the power supply. If you use an oscilloscope to measure the voltages they may appear fine, however I have solved this problem by replacing all the capacitors in the 2ndary circuit of the power supply. It doesn't always work, but has worked in about half of the TVs that have come in with this problem. Also, just to make sure, if you remove the shielding from the board that drives the LCD panel make sure the little smt fuse is good. It's right on the 5V power line close to the ribbon connector from the main board.
Feb 20, 2010 | Samsung LN46A650 46 in. LCD HDTV
Vertical lines atarting about 2 from left side and are approx 1' wide ussualy multi colored but sometimes brown intermitten sometimes as little as five minutes and sometimes as long as 1/2 an hour usually...
That is bad sign of the bad LCD panel itself, but you can try replacing the LCD driver board first. The new LCD panel will be very EXPENSIVE! It will get worst as time goes by.
Nov 11, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
LP690 projector displaying strange lines
to adjust those mirrors, you need to power down, unplug, remove the top, remove the wires from the main board, remove the main board, adjust one mirror, reinstall everything, power up, see whatever difference it made, power down and repeat until it's fixed. it's quite a chore. if that's not the problem, you'll need to replace the optical engine (which isn't cheap) because they don't sell individual parts.
Mar 09, 2008 | InFocus LP690 Projector, Factory...
Televison & Video Logo
532 people viewed this question
Top Televison & Video Experts
Ekse
