Question about GE JVM1440 Microwave Oven
Microwave blower motor wiring
My blower motor went out and they wanted $145.00 for a new one but I found a guy on Ebay selling blowers from freight damaged microwaves for $18.00 brand new and he said that if I sent him the model # he would get me one with the right plug well the one he sent is wrong what I have in the GE Model# JVM1440WHD4 is a Samsung what they sent is a OH SUNG what I need to do is change the plug the wires on the GE are red-orange-blue-white-violet the wires on the OH SUNG are black-blue-yellow-red-white I know that the black is ( High Speed) and the White is (Low Speed) on the OH SUNG they are marked, I am not sure which ones are power and neutral . Sure could use some help. Thanks
  • Jme Kelly Oct 29, 2011
    what color is hot and witch is neutral
I have an OH SUNG from a different model micro and have hooked it up every which-way I could and some how managed NOT to mess it up. I finally realized I needed the 6 microfarad capacitor across the RED and YELLOW. Works like a champ. ****** can move some air btw. I am thinking about thowing this puppy in my PC when I overclock it...
Maybe your VIOLET = BLUE and YELLOW = ORANGE?
Posted on Nov 25, 2008
How do I change the front exhaust to top exhaust on a Kenmore microwave/hood
In order to change the venting on the microhood you need to uninstall the unit and at the top of the microwave is the blower unit. Remove the cover, flip the blower and you should then see the fins on the motor, reinstall the unit under the cabinet and your good to go. I hope this helps, good luck
Mar 15, 2015 | Kenmore Microwave Ovens
Blows the fuse when the fan starts
Short in blower motor circuit. Possible faulty blower resister
Mar 21, 2012 | Microwave Ovens
I bought new Kitchen Aid microwave with hood combination and followed the instructions to install it. Everything was OK until I came to the Wall Venting Installation, step 4. Lift blower motor out of...
On this model, item #1 is the only part you will need to invert. Lift out and rotate to allow venting to be possible to the wall. In other words, the open part needs to face the back of the microwave. Also if you removed the blower, you will need to re-install it back and correctly. You could have venting issues if not back in the proper location.
Jul 28, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Want a part number for the light bulb that is under the microwave. Maytag model mmv6178aaw
mmv6178aaw Light bulb Found at sears parts direct. PN: 53001905 $14.95
http://www.searspartsdirect.com/partsdirect/part-number/Maytag-Parts/Microwave-Parts/53001905/0022/464/Model-MMV6178AAW/3048/0123370?keySuffixId=&productTypeId=&searchModelNumber=MMV6178AAW&blt=06&subCompDesc=BLOWER MOTOR
If the link does not work go to http://www.searspartsdirect.com and do a part number search using 53001905 then click Go.
You can do a model vs part search also using the searspartsdirect link just in case I did not get you the correct light bulb.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Maytag MMV6178 Stainless Steel 950 Watts...
I have a kenmore microwave hood combination model 721.80019. The blower unit has recently started squealing when we run the microwave. I am not sure if it is rubbing up against something or not. Is there...
I just found out the same problem with mine.
I think the bearing of the fan motor has problems.
I took it apart and now looking for a used or new fan motor unit.
Bill
Aug 14, 2010 | Kenmore Microwave Ovens
The blow or fan stop working and the circuit breaker kicks off
It sounds like your exhaust blower has a shorted wire to it or the motor itself is bad. If you have a basic knowlege of electricity, some hand tools and lots of patience you can take the unit down off the wall, remove all the access screws and locate the blower (usually on the top back). Follow the wires from that to the control, look for breaks or tears in the wire, if none found then the blower motor will need replaced.
Apr 18, 2010 | Microwave Ovens
GE JVM1440 microwave - Fan only works on 'low' speed
Only working on low would probably be either a bad blower motor or a bad main circuit board. I dont remember ever having to replace a blower, but the main board has relays that switch back and forth for what ever speed you are trying to use. Problem is the main board will be quite expensive. May want to look at prices on new units. And remember on a new unit you get full factory warranties on everything.
Oct 02, 2017 | GE JVM1440 Microwave Oven
Changing the venting on my MH2175XSQ
yes FORCE...doct be afraid to break it 'cause you really can't. On mine after frustration I got agressive and found out the little black power wires were "holding it in the unit. A little prying pulling will get the motor unit up and out so you can "roll" it 90 degrees and reinstall screws and job is done.
May 22, 2009 | Whirlpool MH1170XS Microwave Oven
Blower
check fan motor and related circuit.,control panel circuit also check..
Oct 01, 2007 | Maytag MMV4205 Microwave Oven
GE JVM1440 Microwave Oven Logo
1,169 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
