Question about HP LaserJet 2420 Printer
Hp 2420 displays 53.07
I have a 2420 displaying 53.07 and won't clear with power down. Checked fan with covers off and the fan starts until the error appears. Is there a re-set procedure to clear the error or is the controller toast?
  • 138 Answers
The 53.07 error relates to Memory. Turn the printer off. Remove the right side cover. Remove any and all DIMM (memory) cards and printer/network cables from the formater board. The memory DIMMS are located behind the metal cover. Remove any Jetdirect Cards installed into the EIO slot on the back of the formatter.
With all accessories removed power up the printer and see of it comes to ready. If not, you need a formatter board. If it does come to ready, power it off and plug one peice that you removed back in and try again. Keep adding one at a time and powering up again until the error returns. When you get the error, the last added back onto the machine is the problem.
Here's a copy of the service manual to help with disassembly, troubleshooting and part numbers for ordering.
http://www.feedroller.com/Store/Service%20Manual/LaserJet%202410%202420%20and%202430%20SM.pdf
Hope that helps you. If so, hit me with a fixya!
Posted on Sep 03, 2008
SOURCE:
Pc suddenly powers off
that can be meaning if the processor is Not Supported with your motherboard,or the New Processor is not in good condition (can be Over Heat or damage).
Processor over heat or damage can be because the HEAT SINK (white or grey pasta at the top of processor) is not enaugh to cooling the processor or,the fan Proseccor is Dirty.
Jan 18, 2012 | Computers & Internet
FF95 SERVICE ERROR CODE IN PRINTER
Does it give a 49.FF95? As their is no such error code "FF95" for a HP 2420. However I've seen 49. XXXX error codes before (XXXX meaning weird Alphanumeric Characters and numbers). This type of error code you can try a couple of Items:
1st - Perform a Cold Reset:
1. Turn the printer off.
2. Hold down the SELECT button, and then turn the printer on. Continue holding down
the SELECT button until all three printer control-panel lights flash once and then
remain on. This might take up to 10 seconds.
3. After the message SELECT LANGUAGE appears on the display, press the
UP ARROW button or the DOWN ARROW button until COLD RESET is highlighted.
4. Press the SELECT button. The printer performs a cold reset and then continues its
power-on sequence.
5. Check all I/O settings and reset any customer-set printer configuration values
If the machine still comes back to the Strange FF95 error I would start with the replacement of the formatter,
Part Number for the Formatter:
Network versions Q3955-60003
Non-network versions Q3953-60001
Hope this helps..
Feb 25, 2011 | HP LaserJet 2420 Printer
My printer is giving an error message..."error 57.03"to continue turn on then off....i do it to no avail.help me
This is a Fan issue you have 2 of them one on the front right side and one on the left. if you remove both covers see which one is not working
Now if their are both working then you will need to replace the ECU (Engine Control Unit).
I've attached a link that shows you how to remove the covers off the 2420 it's a pdf file .
And the Left side cover will need to be removed to access the other fan.
Oct 18, 2010 | HP LaserJet 2420 Printer
My HP Laserjet 2430dn makes a grinding noise after power on.
CHECK RS PRINTER PARTS FOR HP LASERJET 2400 2420 2430 PRINTER GEAR KIT
Feb 26, 2009 | HP Office Equipment & Supplies
Hp 2420 error 49 3c1a
If the printer is displaying 49.xx error message, followng the following document
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00280149&jumpid=reg_R1002_USEN
Upgrading the firmware should resolve the issue.
Please let me know one you perform the above upgrade.
- Nikhil
Nov 20, 2008 | HP LaserJet 2420 Printer
When going to print to a laserjet 4000pclx printer I get an error code 7900FE. What is it and how do I fix. it.
If you have cleared the print queue so there are no outstanding 'faulty' files; it's worth knowing that the 79.00 error can also be caused by poorly fitting or incompatible memory cards.
To clear the printer queue on PC
click on start
click on run
type: services.msc
scroll down to print spooler
right click on this service then press restart
exit out and try again other wise continue below..
Can you make sure they are firmly mounted?
Remove all communication cables so that only the power cable is connected.
Remove the Jetdirect card, if installed.
Remove any other accessories, such as the envelope feeder.
Hold down the green "GO" button.
Turn the printer on.
When the words "Cold Reset" appear in the display, release the green "GO" button.
When "Offline" appears in the display, press the green "GO" button. "Ready" should appear in the display.
NOTE: If the words "Cold Reset" do not appear in the display, hold the "GO" button down until you hear the motors rotate. The words "Restoring Factory Settings" will appear in the display if the "Cold Reset" was performed successfully.
Turn the printer off once the printer displays the “Ready” message.
Reinstall each of the above-mentioned components, one at a time, turning the printer on and off again each time a component is installed.
Continue installing and power-cycling until all accessories are installed and the printer is at a “Ready” state.
If it is determined that one of the components is responsible for the 79.00FE error, refer to next.
If the printer will not return to a “Ready” state after removing all of the components and performing the cold reset, try a different power source by moving the printer to a different location and plugging the power cord directly into the wall.
If the printer continues to display the 79.00FE error, upgrade the firmware. A firmware DIMM can be obtained from the HP Parts Store at http://www.hp.com/buy/parts . Version 6.36 Firmware DIMM is Part Number C4251-67905; however, part numbers are subject to change without notice.
If the printer still continues to display the error, contact HP for further assistance.
Jul 28, 2008 | Computers & Internet
Memory error
Just do 2 steps:
1. Press Stop.
2. If the display highlight "Resume". Press the OK (Check Button).
The display will tell you that a Non-HP Cartridge is installed and Economode is Disabled.
At least, you can now print. The display will show back again to "Ready".
Jul 23, 2008 | HP LaserJet 2420 Printer
Paper jammed problem 13.05.00 JAM INSIDE TOP COVER
It happens form both: manual feed and tray... sensors don't look misplaced.
Nov 19, 2007 | HP LaserJet 2420 Printer
Sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Aug 13, 2007 | Ricoh Aficio 2015 Copier
HP LaserJet 2420 Printer Logo
323 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
