Question about InFocus Televison & Video
IN1 Projector G300-WW. I have just purchased this projector today and the mains lead on it has a european 3pin plug attached,I need to connect wtih an English 3pin plug, can you tell me the safest way to do this please, as I want to make sure that I do not damage the projector, Thankyou, Regards Reg.
    New Friend:
Cut europen 3pin plug and replace with english 3pin plug.
Posted on May 15, 2010
6ya staff
SOURCE:
I have purchased an used MP7630 projector. How do you start running an MP7630 projector. Do I need software for it as well the leads.
You should just require the leads as when you plug your pc into it if the resolution is set correctly, will produce a picture.
Jan 06, 2011 | 3M MP 7630 Multimedia Projector
My infocus g300-ww projector turns on and then turns right back off. What could be the problem?
Dec 27, 2010 | InFocus Televison & Video
Black and white stripes, no picture
just clean your projector board that connected to the main board, just clean the port.
Oct 08, 2009 | InFocus Play Big IN1 DLP Projector
IT APPEARS VERTICAL LINES (ABOUT 10) ON SCREEN AFTER 2 HOURS OF PROJECTION. WHAT IS THE PROBLEM?
clean out the projector with canned air to remove any dust. lines can be caused from excessive heat from too much dust. fans could be wearing out, causing voltage spikes and drops. also could be that the main board has an issue and needs replacement.
Sep 08, 2009 | Barco iQ Pro G300 LCD Projector
Connecting my pc to a sanyo plc sw30 projector
never mind the usb, u need to only connect the video output ( yellow rcs connector ) to the vido input of the projector & it will work fine!!!
Dec 29, 2008 | Sanyo PLC-SW30 Multimedia Projector
Infocus IN1 Gaming Projector
Hi, I just bought the same projector Infocus IN1 and after just 15 minutes of use it turned off due to overheating. It seems that the lamp is very ineffecient and produces too much heat. The ambient temperature in the room is only 16 deg. celcius.
The solution I came up with is to have a standing fan blowing air directly on the back of the projector from less than a foot away. The standing fan which we usually use here in summer was enough to keep the projector cool. The infocus IN1 did not switch off for the next 2 hours (the entire length of the movie), until i turned it off myself. I am not sure how this system will fare in summer when the room temperature reaches 30 deg. celcius.
Oct 21, 2008 | Compaq Microportable 2810 Multimedia...
Sanyo plc-su50 projector - can't get it to work
Please select correct input in menu of projector, that is Computer/ PC, like that...
Aug 02, 2008 | Sanyo PLC-SU50 Multimedia Projector
I recently bought a infocus in1 audio projector and i cannot get sound and picture together. only seperately by pressing the input botton
Sounds like you have the video and audio plugged into different inputs. For example the video is going to video 1 and the audio is going to the audio input of video 2
If you get only video one input and only audio on another input... Then the above described connection is the only thing that would cause this to happen!
Cheers
Jul 29, 2008 | InFocus Play Big IN76 Multimedia Projector
Televison & Video Logo
666 people viewed this question
Top InFocus Televison & Video Experts
Donni Steen
rostit
Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
