NEC LT170 projector won't turn on!
Why won't my projector turn on when prompted to? The only thing that happens is the power button starts to flash orange and the status button flashes red. The bulb button does not flash or turn on. I hear a fan/motor turn on but that's it.. Can someone help please?
  • 1 more comment
  • Anonymous Jan 18, 2009
    I have the same problem.
    The status light turns red and blinks 6 times and stops and again blinks 6 times.
    The manual says it is a lamp error and should wait for minute and try again. I did that but still not working.
    I would really appreciate some help
  • wilsoab Jan 21, 2009
    I have the same problem with my NEC LT 170....what is this!
    update: I put the projector up for six months, took it out and plugged it in, it came on!
    this lasted for about two weeks, I realized that if I left the projector plugged in when not in use, i would get the blinking lights, If I unplugged after use it worked.
    However, I accidentally left the projector plugged in overnight, now my projector will not fire the lamp and I am getting the flashing lights described above.
  • Anonymous Jan 26, 2009
    Same here, shop says the fans need replacing, $400.00. But then I plug it in and it works fine....
  • 29 Answers
So glad to find a posting regarding this issue. I too have a NEC LT 170 that I <3 and when used the first bulb to the end of what I thought was its life got another. Smiling for months as I watched and enjoyed the big pictures on my Living Room walls. Then it stared, or i should say stopped starting.
Since I had laid out the Living room around it, surround sound and all, Iwasn't about to just give up and the compact nature of the projector made me not want to. Patiently I looked into it. I found that the bulb has a capacitor that fires high voltage to begine the arc that vaporises the mercury. I removed the bulb examined the contacts safety glass reflector and found them all to look well. reassembling the Bulb worked!!! Then same week end didn't, Repeted the proceedure thinking loose contact to capacitor?(could hear the high frequency of the capacitor firing, once, twice, three times then the flashing light of Malfunction.
Now My wife is not the fixer in the house though when we were dating we had a beta projector that wasnt working and I was about to take it apart when she said "let me show you what I do" and walked over picked it up and gave it a ittle spank on it's bottom. fliped it back over and pressed plat and all was well. Ever since whenever i am at my technical wits end before i get the hammer I flipp it over and give it a swat. Well it's been a year now and I am embarrassed to say I don't have a better solution though I have refined my understanding.
There is a third contact that is energized by the capacitor to vaporize the condensed mercury in the cold bulb. when I turn it; lense down and give it a slap on the non chord side near the rear (back side by bulb) only while i hear the Capacitor fire (high pitched PEWWW). This shakes the small droplets of condensed cold mercury around the contact that is attempting to arc through them to make the gas that the primary filament fluoresces. Some times I get it on the first try. others on the second or third. Then if I unplug I can try again.
Have you ever noticed on your winshield how the dew covers the whole thing and then as you drive it rolls off in droplets. This projector was designed to be moved alot and the problem only shows up when the cold projector isnt moved and the condensed mercury isn't collected around the firing filament. Rolling and slapping the cool projecter rolls a ball of mercury around collecting all the little balls together to where they can then be vaporised by the capacitor and start the fluorescent reaction.. The permanent fix to this is to redesign the bulb with more mercury.
Posted on Feb 20, 2011
  • 2,239 Answers
The colorwheel may need replacing.
Posted on Dec 23, 2009
SOURCE:
The projector turns on but won't project any light through the lens.
If this is a NEC VT series projector, Change the lamp. When if it continues to blink amber and not project and image after installing a new lamp check the lamp cover to see if the micro switch tab on the lamp cover broke off. Some models have a built in lens cover. If the cover is not slid over to open completely the light may not turn on.
May 19, 2014 | NEC VT800 LCD Projector
NEC vt800 projector troubleshooting
That is a problem with the lamp. Replace it with a known good one.
Feb 27, 2013 | NEC VT800 LCD Projector
VT595 LCD Won't come on. Power light orange Status red Blincks Once every sec or so.
If the lamp life has exceded its safe working limit, it will probably go into a permanent standby mode, I used to have an NEC MT830, I had to hold down the off button for 20 seconds to reset the lamp life, maybe it will be something similar. If you have your manual, it may give instructions, if not there will be a downloadable manual on the NEC website.
Good luck
Aug 09, 2011 | NEC VT595 LCD Projector
I have a nec vt560 and the power light stays orange and the status light is off until buttons are pressed. bottom line is...i cant get the projector to come on...the power light never turns green.
The projector is in standby mode, which is a good sign.
When you press the ON button for "at least 2 seconds or more", what happens.
Do any lights come on at all?
Mar 20, 2011 | NEC VT560 Multimedia Projector
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
NEC LT170 diplays annoying line
Hi there
This is a common Mainboard failure - you'll have to get this repaired or replaced !
Must warn you that this is quite expensive
Mar 28, 2008 | NEC LT170 Multimedia Projector
Whatever button i press the status light flashes and nothing happens?
hi 1) Check that the power cable is plugged in and that the power button on the projector cabinet or the remote control is on. See pages E-16 and 17 in the manual http://www.fixya.com/user-guide/p155892,m5221,gm34/NEC-VT460-Multimedia-Projector.aspx 2) Ensure that the lamp cover or lamp housing is installed correctly. See page E-30. 3) Check to see if the projector has overheated or the lamp has reached the end of its usable life. If there is insufficient ventilation around the projector or if the room where you?re presenting is particularly warm, move the projector to a cooler location 4) You have pressed control panel key when Control Key Lock is enabled good luck
Apr 20, 2006 | NEC VT460 Multimedia Projector
2,310 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
