Question about Whirlpool LSQ8000 Top Load Washer
Whirlpool LSQ8000 Top Loader
THE MOTOR APPEARS TO BE WORKING BUT THE DRUM DOES NOT SPIN.
THE WASHER FILLS UP WITH WATER BUT THE DRUM DOES NOT AGITATE AND DOES NOT SPIN IF SELECTED.
ALL I CAN HEAR IS THE MOTOR WHICH SOUNDS AS IF IT IS WORKING ALTHOUGH A LITTLE CRANKY!!
NOT SURE WHAT THE PROBLEM COULD BE?
ANY IDEAS MOST APPRECIATED.
THANKS
PAUL
  • 125 Answers
The motor coupling is most likely broken. part number 285753A.
Posted on Aug 19, 2008
  • benham Aug 19, 2008
    Remove the 2 screws on the front or back of the endcaps on the sides of the control panel, ( front or back depending on design). The control panel will come forward then flip up. Next use a screwdriver to pop out the spring clamps that hold the cabinet onto the frame. They are about 3/4 of an inch wide and about 3 inches from each side. Disconnect the lid switch. Now you can tilt the cabinet away from the back of the machine, while tilting the bottom front of the cabinet will slide out and the cabinet can be set aside. now you will have access to the motor etc. Release the clamps holding the pump onto the motor. Now you should see two screws that hold the motor clamps, one above and one below the motor shaft, remove those. Use a flat blade screwdriver to pop off the clamps holding the motor. pull motor out to expose coupling. Make sure to use part # 285753A. repair sould take 10 minutes.
How do I repair my Whirlpool Ultimate Care 2 LSQ9549L Top Loader Washer?
check the motor coupling,if the coupling is broken you'll hear the motor run but the agitiator won't move and no spin,the coupling connects the motor to the transmission.watch this video
http://www.youtube.com/watch?v=9K1KHEogf3c
May 30, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
Whirlpool top loader washer not agitating
Hi, Do you know if the lower half of the agitator is working? THere is a dog kit that might need replaced in the agitator to get the top half to work. If neither half agitates, there is probably a transmission issue. Start the washer with no laundry in it and see if either sections of the agitator work.
I hope this helps you.
Vic
Jul 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
"jackhammer" sound coming from my washer
# Balance the load
# Level the machine
# Inspect the water pump for a blockage
# Inspect the coupling
# Inspect the transmission
# Adjust the drive belt tension
# Check the motor bearings
# Check the drum brakes
Jan 09, 2009 | Washing Machines
Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
M/n la7800xkw2 washer will not spin or agitate
Jumper the lid switch.
If it works then, replace the lid switch.
If not,
Replace the wigwag.
Nov 15, 2008 | Whirlpool LSQ8000 Top Load Washer
WHIRLPOOL TOP LOADER 3RLSQ8000
ck coupling between motor and gearcase ..probably broken or cracked ..remove 2 screws on back bottom of console lift console up remove lid switch plug remove clips each corner remove cabinet remove clips on pump remove 2 screws holding motor clips on remove motor clips remove motor and there it is
Aug 19, 2008 | Whirlpool LSQ8000 Top Load Washer
Washing machine noise
check the dogs in the agitater
Mar 25, 2008 | Whirlpool GSC9455 Top Load Washer
Whirlpool LSQ8000 Top Load Washer Logo
178 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
