I have red and green shadows around every image on my screen. Happened one day out of the blue. What is the problems and around how much should the parts cost. Would it make more sense to call for a repairman for inhome service. Around how much would that cost?
You need to replace the two convergence ICs they are STK392-110 you can get replacements at the following link with fre installation instructions.
http://servicemanuals.vstore.ca/
SOURCE: double vision
you need to replace both convergence ICs they are STK392-110 you can get replacment ICs at the following link with free instalation intructions with pictures. Here is the link.
SOURCE: Panasonic Rear Projection Screen TV
you need new convergence chips, there are 2, part number stk 392-110, also you must check for burnt resistors, if you don't have very good soldering skills at least, you will need a tv repairman.
double vision and wavey red line
My projection HDTV at first would not turn on one day so I unplugged it and then it did turn on only to a smell of something burning.
I turned off the TV and removed the back panel and had my wife turn it on again, it smelled bad again and I noticed one of the resistors in the back was glowing red (on fire).
I turned off the TV again and this time no glowing resistor only a double vision screen with red highlights.
Any remedy would be greatly appreciated.
Thank you.
TV model # PT-51HX43G
Edward
