I have sonata 2006 , 2.4 - , recently strange sound coming from rare side and increasing when i drive it slowely i changed the dampers but the sound stil coming and increasing day by day , alot of mechancials check it but nothing new unless the sound coming from rare tire or something there , please i need help if is it a commen proble in hyundai sonata 2006 ??
Basically, if your camshaft were to break, 2 things. One is, the motor will no longer run at all. The camshaft is on the top of the engine inside the valve cover, and it is responsible for opening and closing the valves. Second, take some pictures, because camshafts breaking is really as rare as hen's teeth! Wish I could tell you what the problem is, but my only suggestion is: don't drive the car, or even start it for that matter. Have it towed to a repair shop. This sounds serious.
sounds like the compression, something is not torque down right, and recheck the timing. did you spin the motor 2 times be hand to see if the timing was on mark
Have you had this listened to or driven by a front end repair person, they are very good at noises, i think this is a worn part that causes this, just can't remember which one, the dealer is your best choice here.
ya i recently had my battery go bad on me. 06 sonata is @ 58k. previous to the battery issue had noted as irritating and strange as it is that my hood latch was not releasing, so after a tow to the shop and a 3 day rental...parts and labor was over$500. the very nxt week even tho i asked them to take a look as id had the ESC off light illuminiate vry sporadically recently. was "noted and light is off now" by the shop. 3 days out of shop light on again....back in shop a week after first. now i'm being told the entire ESC electronics system needs to be replaced at just under $600. i am starting to suspect i shud have gone w a honda.
Happens on rough road or bumps? Grab a hold of your sway bar links fronts and rears, should be tight, no play. These things sound like metal to metal tapping, very common. Get a replacement link that has a greaseable fitting. Easy easy DIY.
A gasoline smell is from a leaking hose and you need to find that fast
You could have damaged a gas line during your repair work.
Get your money back on the damper repair. There are no gas dampers on autos.
