Question about Canon Powershot SD450 / IXUS 55 Digital Camera
How disassemble? Trying to open up my SD450 to try to fix E18 problem. Can't get covers off. 2 screws each on left, right and bottom, but still it's sticking at the top. Is there another screw somewhere I need to remove?
  • dan93230 Aug 19, 2008
    Thanks. I'll try it tomorrow. Are you in the US or UK? Generally how much does fixing the E18 problem cost?
  • dan93230 Aug 22, 2008
    Thomas, I might be interested in this. I could ship it to you and give you a US address to send it to. [I live in UK, but going to US in early Oct.] Is there a phone or email address to ask more about this?
    Dan
    Sniper:
  • 87 Answers
Http://thydzik.com/replacing-a-cracked-canon-ixus-55-ixy-60-sd450-lcd-screen/
Posted on Nov 26, 2008
Open battery covering and (A/V/USB) covering - find a hidden screws there.
Posted on Oct 03, 2008
SOURCE:
I am trying to remove the HD, so I can connect it to a SATA/IDE to USB adapter. Not sure how to remove the HD.
Hi
thank you for your query
Please do the following
1) Turn the laptop over on its front
2) You will be presented with the bottom of the laptop, the screen hinges should be facing the front
3) In the bottom left hand coner there will be 2 screws, screwed into what looks like a little black plastic cover
4) Remove these 2 screws and using a flat bladed screwdriver open up the plate
5)The hard drive will be located underneath this cover
6)Simply pull the drive to the left or right (depending what side the connector is on), and pull up and out
This will remove the hard drive, reverse the above if you wish to reinstall
I hope this helps
Mar 04, 2010 | Toshiba Satellite M45-S265 Notebook
I get a 1200 error when trying to fax
Lexmark X4270 Error 1200 Fix - Click here for document link
1. Unplug printer from wall and remove power supply.
2. Unplug any phone lines or USB cords connected.
3. Remove printer attachments, paper trays and phone.
Figure 1 - Printer paper holder and completed print tray
4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
Figure 2 – Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back ofprinter (2 screws), and bottom of printer (1). View the images below tofind where to remove the screws.
Figure 3 - Top view of printer showing which screws to remove.
5. Cont…
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable to reveal the gold screw beneath
6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
7. Remove the ink cartridges out of their carriage.
Figure 6 - Displays ink cartridge carriage with ink cartridges removed.
Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
NOTICE: The ink cartridges are all the way to one end. If the X4270 isplugged in, the cartridge carrier is stuck and doesn’t move. Afterfurther investigation a noticeable small black plastic lever ispreventing the ink cartridges from moving. Photo below shows lever upand down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200.Image on left displays lever up. Image on right displays lever down.
8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
9. Lift the front cover open (if not already open) and plug in theX4270. Cartridges should move to center as if preparing for replacement.
10. Unplug the X4270 and remove power supply.
11. Remove bottom assembly carefully.
Figure 8 - Displays bottom assembly with lever and spring
Note: The cause of this problem is the spring slides out of place overtime, probably because of ink shed on one end of its loop and loopattachment.
Figure 9 - Displays loop attachment
12. Place spring in loop attachment and use hot tip of heated toolto melt top of loop attachment to prevent further errors. Melt top ofloop attachment similar of that to a mushroom top.
Figure 10 - Displays fix for jammed carriage.
13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
14. Plug in and check if operational.
15. Reassemble X4270 using steps 3-7.
Feb 16, 2010 | Lexmark X4270 All-In-One InkJet Printer
Canon sd450, e18, need schematic of lens
http://www.e18error.com/
here are instyructions and a reference to the schematic at the bottom of the page.
cheers
Jul 31, 2009 | Cameras
E18 on canon sd450
the gears might be damaged already for the lens that why its not moving anymore, you may need to contact the manufacturer for service center referral
Jul 25, 2009 | Canon IXUS V2 Digital Camera
Error E18, the zoom is blocked
Hi
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
There are six screws holding the metal frame of the camera body together, two on each side, and two on the bottom. Remove all screws, pop the strap-hook plate (sorry, probably not the most technical term there), then gently lift the front plate off by pulling up from the bottom, and remove the back plate in the same fashion. These should come off relatively easily. This is what the camera should look like as you remove the plates:
img-5340-thumb.jpg?w=324&h=217
  1. Now, looking from the top of the camera, you should see a small motor on the left side, as shown below (it’s beneath the cable with a “22” written on it):
    img-5346-thumb.jpg?w=324&h=217
  2. Take your screwdriver (or another small instrument) and gently try to rotate the plastic piece attached to the motor on the left side, as shown below:
    img-5359-thumb.jpg?w=324&h=217
  3. At this point, try placing the battery back in the camera (if you have removed it), turn the camera to one of the capture modes, and press the power button. If all went well, your lens should now be able to extend and retract properly.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 26, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Trying to replace the motor on my maytag toploader washing machin
Hi There,
On the bottom of the front panel there should a philip head screw right above each fron adjusting leg.
Remove these 2 screws. Open the cover and lift up on the front between the drum & cover there are 2 metal clips holding the top down. Swing the top up and remove the front panel. The motor is right in front on the lower left. Let me know if this helps and thank you for using FixYa!
Jan 22, 2009 | Maytag HAV3460AWW Top Load Washer
Help
Place a thick bath towel (triple folded) on the table edge. with the camera off, hold it in your hand and tap the bottom of the camera with medium low force to the above mentioned table edge. Try turn it on to check if it's back to normal. You may need to tap it more then one time, if it doesn't work, with stronger impact force. Just be sensible, not too hard though.
In case you have doubt with this trick to fix, try google 'Canon E18' to find related problem being fixed by others with this method.
Jul 21, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
E18 pops up
An E18 error refers to a problem with the lens. Generally you receive this error if the lens is stuck, which often happens if you drop your camera while the lens is extended or if something like sand or dirt gets inside the lens barrel/gears. Your situation, however, sounds different since the lens seems to extend before giving the E18 error.
If the lens is fully extending before giving the E18 error, you most likely have a problem with the lens sensor located around the O-ring inside your lens barrel... either the sensor itself is damaged or the little plastic piece on the O-Ring that triggers the sensor is broken. If that's the case, there is nothing you can do yourself unless you feel like taking apart the entire camera and finding a replacement piece.
If the lens only comes out a little bit and is not fully extending before giving the E18 error, it sounds like something is making your lens get stuck. If you've recently been to the beach or a park where there is sand, try using a can of compressed air and blow it into the little gaps in the lens barrel... you may be able to blow the sand/dirt out, solving your problem. If the air doesn't work and you feel comfortable taking apart your camera, you can get to the gearbox and manually retract the lens by following my instructions below. Otherwise, I'd suggest a repair shop.
WARNING: TAKING APART YOUR CAMERA VOIDS THE WARRANTY AND CAN BE DANGEROUS! The capacitor that charges the flash can still hold enough voltage to give you a massive shock even when the battery has been removed for some time. Please only attempt to disassemble the camera if you feel comfortable doing so. I accept no liability for anything that happens should you follow my instructions below.
In order to open the camera you will need to remove six screws on the outer casing (2 where the wriststrap ties on, 2 on the opposite side, and 2 on the bottom). After unscrewing all 6 screws, pull the back and front casings off from the bottom out, as there is a clip-hinge on the top next to the shutter button that needs to disengage before you can fully remove the casing. Once the casing is removed, there is one screw holding in the flash apparatus, on the side. Remove it and carefully bend back the metal cage around the flash apparatus and pull it up. The flash will still be attached to the camera with a pair of wires (yellow and black) and a ribbon cable... leave those in place. Please be CAREFUL when handling the flash because the capacitor (the big black thing under the flash) can hold enough voltage to give you a severe shock even with the battery removed. Underneath where the flash was you will see a multi-tiered black piece of plastic... this is the gearbox cover. Remove the three screws from the cover and carefully lift the cover off the gearbox. Inside will be a motor shaft and 4 gears (2 white, 2 black). Remove the BIG black gear closest to the lens. Then temporarily replace the gearbox cover. With the big black gear removed, the lens should freely glide in and out if you push or pull on it. Do this several times in order to clean out any gunk that may have gotten into the grooves of the lens barrel. Then, open up the gearbox, replace the black gear, and screw the gearbox cover back on. Replace the flash into the metal cage and screw it back in. Finally, put the metal outer casing back on the camera and, before screwing it in, try to turn it on. Hopefully it will work again and you can screw everything back in. If not, your problem will require significantly more disassembly.
Apr 02, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Both Screens Flicker after trying to replace touch screen
I finally solved the flickering problem on my DS (!), after I made my 1st engineering attempt overhaul shell, top screen and broken right hinge.   Was really frustrated about the flicker afterwards, and opened up unit back up too many times to debug (risked damage to cable ribbon everytime!).
Anyway turns out there's 2 hidden screws (location:  inside the battery compartment near where the front 'volume slider' is located) that adjusts the flickering (like how you need to calibrate an LCD monitor from doing same flickering effects) . You'll need a really (really!) small philips (+) screwdriver to do the adjustment.
Open up the battery cover with the VOL label upside down & facing you.  The adjustment screws are recessed deep inside the plastic...a right and left screw.  With the DS turned 'ON' to see the screen (whether you twist your neck to be able to see or have a mirror on the table in front of the DS)....slowly/carefully turn the screws to adjust until you like the clarity.  That's it.   The right screw = bottom screen.  The left screw = top screen.
Now.... on to figuring out how to replace or fix the broken Power toggle switch that I snapped off!  Currently using the toothpick method, but that's getting old!  Any suggestions, I'd appreciate it!
Dec 08, 2007 | Nintendo DS Lite Console
Open Questions:
Canon Powershot SD450 / IXUS 55 Digital Camera Logo
217 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
