Question about Samsung MD800SC Microwave Oven
Samsung MD800SC Microwave runs but stopped heating
I have a Samsung MD800SC that suddenly stopped heating the food or drinks, even though it seems to be operating.
  • 3 more comments
  • jnewman19 Aug 19, 2008
    When I hit Start or One Minute, the inside light came on and the turntable revolved as though everything is working. I don't think the sound changed either.
    However, testing it again to respond to your question, after having it unplugged for two weeks, it worked normally again suddenly.
  • jnewman19 Aug 20, 2008
    Following up on my earlier post about the Samsung MD800SC Microwave, it heated one cup of water. But after that, again it appears to be working (lights on, turntable rotating, timer counting down and then stopping appropriately), but the contents are not warmed at all.
  • Anonymous Feb 12, 2009
    I have a Samsung MD800SC, which suddenly stopped working. I plugged it out, but I cannot bring myself to get rid of it. I calle Samsung and was told that the megatron which was the on;y thing that was still under warranty may be the problem.II was given two(2) numbers to call which I have not done. I really like this oven.
  • Anonymous Feb 23, 2009
    Same problem..... just would like a repair location in Chicago or need to find that special screw bit to repair myself. This was such a good design.
  • William Miller
    William Miller May 11, 2010
    When you hit Start to cook, do the inside light and turntable come on?
    Any unusual noises?
    Is it louder or quieter than usual?
  • Samsung Master
  • 9,174 Answers
Chances are you have a bad connection, maybe the cook relay or at the magnetron, but feel free to write back with details when it fails again.
Posted on Aug 19, 2008
  • William Miller
    William Miller Aug 20, 2008
    Since you say it's not louder or quieter than usual, my gut tells me it's either a bad connection at the magnetron (loose FA terminal) or a bad magnetron.
    Here are some links you or someone you know can use for test help, but read their safety warnings first:
    http://www.gallawa.com/microtech/diode.h...
    http://www.gallawa.com/microtech/mag_tes...
    http://www.gallawa.com/microtech/xformer...
    You can order Samsung parts here.
    If
    it's within the magnetron portion of the warranty (usually 5-9 years)
    but out of the original full warranty (usually 1 year), then your
    manufacturer will cover the part cost, but not the cost to visit you or
    the labor charge to do the work.
    If
    nothing else, you can save about $75 by taking it to the shop yourself.
    You can find your nearest Samsung-authorized service center here.
SOURCE:
Microwave won't stop running
there's a ghost in your microwave, call ghost buster. Seriously, the problem is the control panel. (((((the microwave oven can store thousands of volts of electricity in its high voltage capacitor, even after the microwave oven has been unplugged. That's more than 30 wall outlets combined.
Replacing electronic parts in a microwave oven can be extremely dangerous.))))))) tank you
Samsung Model SMH1816S XAC Parts
Mar 30, 2014 | Samsung Microwave Ovens
Microwave heat level has changed. My mother is elderly and thinks the micro is broken because it started overheating everything. she isn't well and I wonder if she touched a button that would change...
Wow, that is FAST! I feel it is broken as well. I had a commercial Panasonic 1,500 watt machine that was not as fast as that. Microwaves do have multiple levels, usually only Full Power, Half Power and Defrost (which is low power, pulse, wait, another pulse, wait). It also depends what the food is? Something like one slice bacon, which is thin, and has minimal water content, would heat up much faster than a meat pie. This is why the standard output test uses a measured amount of water, and a set cooking time. I am a trade chef by the way, so this is one of my specialist subjects. Let me know how you get on by clicking COMMENT under my post. I'll get a notification.
This is the way to test the output
How To Check the Output Power wattage of Microwave Oven
A slightly easier way
http://products.geappliances.com/appliance/gea-support-search-content?contentId=16857
Feb 22, 2018 | Samsung MD800SC Microwave Oven
I hv a 24ltr Sharp Carasoul Microwave. Few days back, its plate stopped working, but its heating the food fine. Why has the plate stopped rotating? Will the food be evenly heated even though the plate...
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You order Sharp parts Encompass here or call them toll-free at 866-779-5835.
> Will the food be evenly heated even though the plate is not rotating?
No.
Sep 07, 2010 | Sharp R-1480 Microwave Oven
My samsung microven MD800SC / zam 1100 watts (made in Malaysia) is working but not heating anything. Kindly advise what is the problem.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 26, 2010 | Samsung MD800SC Microwave Oven
My microwave has suddenly stopped heating. It seems to be running but the food doesn't get hot.
heatman101
hj
Jun 09, 2010 | Whirlpool MH1150XM Convection/Microwave...
Not cooking food even though it comes on
Check the power setting. You can tell if it is on a lower setting because it will cycle ( you can hear it humm lower for a short time then the sound is different and then it humms the same again. It happens...it is new.
Sep 02, 2009 | Oster 0.7 Cu. Ft. Compact Microwave
Microwaze suddenly stopped heating food, runs well but just does
take outer cover off look inline with the black wire
Aug 31, 2009 | Microwave Ovens
GE turn table microwave stopped warming food
my microwave 1640GB from GE suddenly cannot heat food and make some noisy sound. as it is mounting in the closet, it is not easy to replace. any solutions or suggestion
Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave run with a different noise and stopped heating up food
heatman101
fkj
Samsung MD800SC Microwave Oven Logo
809 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Steve Allison
Steve Allison
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
