Question about LG LDF6810 Built-in Dishwasher
LG LE Error
I saw the problem was fixed by a broken wire, Where can the wire be found? Is there a test procedure for this error? I have a LE error. The machine takes on water, and will pump water out, but error appears and no wash takes place. Any help?? Thanks
  • 1,543 Answers
The broken wire would be where the wires pass from the bottom of the door into the dishwasher body. A more likely cause may be a motor problem. A number of main motors have had problems with the magnets coming loose or breaking up, resulting in the LE code. You can remove the phillips head screws around the sump cover to gain assess to the impeller, which is attached to the end of the motor shaft. (via a LEFT HAND THREAD screw.) Turn the impeller by hand and listed for noise. Shaft should turn freely, smoothly, and quietly. If it does not, remove the impeller and the cutter bar, remove dishwasher from cabinet, lay it on it's side, and remove four phillips mounting screws from motor and wiring. There is a two year warranty on all parts.
Posted on Aug 27, 2008
Lg front load wm conversation moto type le error pls
Hi Jilu, The link below is a list of error codes for your washing machine..... CHEERS..
LG Washing Machine Error Code = LE
LG Washer Error = Drive Motor Locked Error
CHECK / REPAIR / FIX = Check the wire harness connections on the motor and the hall sensor (tachometer). Repair any wiring issues. If the wiring connections check good then check for damaged motor components. Replace if needed. If motor is good the replace the hall sensor.
LG Washing Machine Error Codes Washer Fault Codes
Apr 03, 2016 | LG Washing Machines
Lg dishwasher displays LE error
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Additional details in this article: dishwasher/how-to-fix-lg-dishwasher-le-error
Hope this helps (remember to rate and comment this answer).
May 26, 2011 | LG Dishwashers
Dishwasher starts and after a while the LE error appears and the diswasher shuts down
take the front door panel off and check and see if your wires are melted into this black spray on insulation. If they are you need to free them from this mess and check for any broken wires. Make sure your plug is unplugged if you need to fix the wires, cut them and splice them back together. Then insert the bundle into a cut bicycle tube and secure it together. Put the door back on and check it to see if the LE code comes up again. Then call LG and let them know what you found. They act like this is something new and it is not. They need to come up with a better solution. The only true fix is to get rid of the LG and buy a better model.
Aug 06, 2010 | LG LDS4821 24 in. Built-in Dishwasher
LE on display
I just had my LG dishwasher fixed. I told the repair man that LE light was comming on. Even over the phone the repairman said its probably broken wires on the door. Me being in construction for years looked around the door for wires. Anyway the repairman took off 6 screws around the door, took the cover off. You will see about 50 wires taped together. He pulled them aside and visually checked them one by one. Sure enough two were broken in two. He twisted them together put tape and he was gone. $87.50 Still Working!
Mar 25, 2010 | LG LDF6810ST Stainless Steel Built-in...
I have and LG nodel #LDS5811ST and after ad couple of minutes it stops with the code LE showing in the time window, what does this mean!
The wire harness has probably degraded and broken inside the door panel of the unit.
This unit may need a new wire harness, Main PCB, Sump and inner door liner.
Depending on serial#
Contact LG @ 1 800 243-0000 they may help you out.
This is a known issue on older dishwashers.
Jan 14, 2010 | LG Dishwashers
LG Dishwasher LE error
When you repair the wires, be sure to wrap the wire harness is plastic like the type you would find in Safeway produce section.  This will keep the wire harness from getting melted on to the black insulation and creating this problem again.
Jul 12, 2008 | LG LDF6810 Built-in Dishwasher
Model No- LD-12AW2 LE Error showing what does this mean
LE error code means that there is a problem with the motor.  One thing to check is to remove the front door panel and check the wiring harness to see if there are any broken wires.  If there is, repair the wire connections and see if the dishwasher returns to normal.  If not, then the motor assembly will need to be replaced.
Apr 20, 2008 | LG 24 in. LD-12BW5 Free-standing...
LE Error
is ther any broken wires between the board and the rotor sensor
Mar 03, 2008 | LG WM-2277HW Front Load Washer
LE error code
Yes this certainly is a sticking point, the inside of the panel is coated with black insulation, when it heats up the wires stick in it and eventually the wires break. The fix is as stated, splice the broken wires together, as well take some of the white insulation and put it in between the wires and the liner.
The errors that can arise from the sticky wires are numerous, LE, IE, etc. EI though is more than likely a siphoning problem. If your unit is noisey during operation, open the door, what is the water level? It should be at the second rim. If not, that is your first clue that the unit is siphoning. Make sure you have your loop in the drain hose.
Sgt 48
Nov 16, 2007 | LG 24 in. LDS 5811 Built-in Dishwasher
LG LDF6810 Built-in Dishwasher Logo
249 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
