Question about Memorex MMP8565 MP3 Player
Won't charge using usb cable
Goes directly to transfer mode and does not charge. tried most everything.
Help.
  • 2 more comments
  • ewtoejam Sep 04, 2008
    Mine's doing the exact same thing.
    It Goes to Transfer Mode and won't even charge.
    I'm clueless.
    Please help us. :/
  • Anonymous Oct 02, 2008
  • makaoe Oct 03, 2008
    mind won't charge nothing had it pluged in as recommended but still nothing do i need to download something cause all my other mp players had noproblem with the computer.
  • Anonymous Oct 03, 2008
    I have the same problem. transfer mode and not charging.
Just have it plugged in and press mode and if it still doesnt work then press and hold mode for a little bit
Posted on Sep 05, 2008
Spy pen not working
If you have a Spy Pen, sometimes it just appears to be either stuck with the light on, or dead and won't turn on. We wrote this report to show you some of the tricks we found to getting your it to work again.
1. Perform A Hard Reset
The majority of the time, just inserting the end of a paper clip in the opening below the status light on the back, and performing a hard reset, will get your Spy Pen working. Just bend a small paper clip end out, and insert straight into the opening. When you meet resistance, push lightly, and you can feel the reset button depressed.
Make sure it goes straight in, and not at an angle, or you could damage some of the components inside. Let go and try to turn it on.
2. Rule Out The USB Cable
If you are using a USB cable to either connect the Spy Pen to your computer, or to the 110V wall charger adapter, one day the cable will fail. If you use the USB cable because you can't connect the pen directly to the computer, try just plugging it directly into the computer.
Don't use a USB hub, as sometimes there is not enough power for the it; just connect it directly to the computers USB port. On some computers, use the USB port on the back, as front USB ports are sometimes weaker.
3. Rule Out The 110V Wall Charger
Just like the USB cable, the 110V wall charger adapter will also fail at some point; so if it does not seem to take a charge, try charging it for 3 hours in the computers USB port. If the status light is on while its charging, its getting electricity to charge the battery.
4. Put The Spy Pen Back In Video Mode
Several Spy Pens have switches to go to photo mode, or voice activation mode. If you move the switch to change modes, and you do not move it back to video mode, the computer will say it is not recognized. Try moving the switch back to the original position.
5. Erase & Reformat The Spy Pen
If the Spy Pen shows up as a removable drive on your PC, just right click on the icon and let go on "Format." Then check the "Quick Format" button, then hit OK. The drive will be erased, and reformatted. This usually takes care of any pens that make it this far.
Feb 13, 2014 | Computers & Internet
Psp 1001 charging really slow using usb to ac adapter
You have to buy ac adapter I was same I don't have ac adapter but I have powerbank so I can charge it
Feb 22, 2013 | Sony PlayStation Portable (PSP) Console
Garmin nuvi 40 goes into usb mass storage mode when pluged to charge
I updated my Nuvi 40 with the latest software and it will not reboot into GPS mode with the usb cable connected. It used to work. I have figured out how to get it to charge with a standard USB cable:
1) Power it on.2) Press the battery icon for 8 seconds - it will enter TEST mode.3) Plug in your USB cable from the PC to the Nuvi - the screen will change to say charging.4) Press the power button 3 times rapidly - it will say Charging across the screen and it will go dim and then dark.5) To wake it up and use GPS mode while charging simply press the power button 3 times rapidly, again.
Works Great!
Nov 15, 2011 | GPS
Recharging
press the power button several times while player is connected via USB, waiting a few seconds between, eventually it will start charging, took pressing power on mine 5-6 times till it eventually started charging.
Aug 10, 2009 | Memorex MMP8565 MP3 Player
It goes to motorola flash mode boot loader version:boot_c_03.08.oor_mpap
Check your cord , sometimes cables are charge only, and some are for transferring data, (data -only) cords.
Apr 12, 2009 | Cell Phones
Charge
Try turning off the device and then plugging your usb data cable to your pc.
Thanks!
Mar 17, 2009 | Sony Ericsson W200i Cellular Phone
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
Can't transfer video to PC
I could not find the manual for this model on the web, so I'm giving you my best guess.
I found some information that said you could transfer still images and Motion-JPEG video clips to your computer using the USB port.
In general you cannot transfer video to your computer using a USB. To transfer video from most camcorders you need a DV (Firewire, also called 1394) cable. You also need some software.
I'm thinking that when you have an SD card in your camcorder there's some way to tell it you wish to record Motion-JPEG clips to the card rather than full video to the tape. If you've created a standard recording I don't think you'll be able to transfer it with USB.
I believe Windows Movie Maker will let you connect to your camera using a DV cable. I used software called Scenalyzer. A full demo is available free of charge at www.scenalyzer.com. The demo will leave a "watermark" on your video. If you like the software you'll need to buy it in order to capture video without the watermark.
If you have any more questions, let me know.
Dec 28, 2007 | Canon MVX330i Mini DV Digital Camcorder
Can't transfer video from cam to pc
While capturing the video you have to change the Video mode to PAL or NTFS mode & store the Video's in Memory card,
When you want to transper the video's, remove the card or directly plug in to the camera to Computer USB port
Now you can transper the Movie's easily..
Try it out.
good luck..
Dec 02, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Innovage Digital Photo Album w Keychain driver
Summary of Solutions posted here and elsewhere:
I just received a Innovage Digital Photo Album Keychain as a gift and ran into some of the issues posted here. I am going to summarize the solutions I have come across in hopes they will help others.
Installing/obtaining the software:
The keychain requires you to use custom software to upload pictures. The keychain includes a mini-cd with the software. If you have a computer with a slot loading cd (i.e. laptop, imac, mac-mini, etc) do not try to put the CD into your computer, it may become stuck! Either call the service line and order a full size cd, or try downloading the software from either:
Coby DP-151 software
Digital Foci - Pocket Album software
(While these are different digital photo products, the transfer software appears to be same as the Innovate software)
The software should be installed before you plug in the keychain into your USB port.
Software Issues:
Some users have complained that they can't see the whole transfer window. You might have your screen resolution set too low (like 680x480 or 800x600) try increasing to 1024x768 or bigger.
Finding photos: The software is quite simple, it does not integrate with your photo software (e.g. iphoto) it simple reads image files. You will need to point the software to where your photos are stored on your computer. For most people this is either "My Pictures" or simply "Pictures" folder.
Transferring photos: There have been some recommendations to transfer the photos to the keychain in small batches (like 6-10) rather than queuing up 60 images to transfer all at once. Apparently the software has crashed on some peoples machines when transferring many images.
Device Issues:
Charging: The device has an internal battery, it must be charged via your computers USB port. In must be in the charge mode, it will not charge when it is in the update mode. When you first plug the device into your USB port a menu should come up on the screen. You can use the arrow buttons to change the selection, then press the power key to select your choice. For charging you should select "USB Charge". In this mode the keychain will display images and won't let you power off. The red light will supposedly turn green once the keychain is fully charged.
Transferring images:
The keychain must be in the "USB Update" mode before your software will talk with it. Try unplugging the keychain, plug it back in, wait for the menu, use the arrow keys to select "USB update", press the power button. Now try running your transfer software
Bad USB cables: Many people have reported that the supplied USB cable doesn't work. If you are having problems with charging or transferring images, first try another USB cable from a similar type device if you have one (many cameras have the same sized mini usb connectors)
Hope this helps someone!
Nov 30, 2007 | Baby Gear
Memorex MMP8565 MP3 Player Logo
50 people viewed this question
Top Memorex Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
