Question about Whirlpool GHW9200L Front Load Washer
Instructions to replace door lock
Your post said you have instructions to replace the door lock. we have the lock replacement part, but no instructions. Can you help?
    Genius:
  • 1,028 Answers
Remove spring around door seal on front pull seal off and push inward to inner basket remove 2 screws in lock assembly and pull lock toward opening remove wiring connections reinstall in reverse..spring can be a dog but not a bad job
Posted on Aug 21, 2008
My Bosch Vision 300 series washing machine wont start?Why? What has to be done to it?
Michael, the door lock/latch mechanism should be tested, if faulty replace. Have a good repair Tech. check, diagnose and estimate repair. Make sure to at least look at the first link, it tells of a reset procedure that may fix your washers door latch problem. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://baubilt.com/?p=1318
How to replace washing machine door lock on Balay Bosch Neff and Siemens
http://www.repairclinic.com/Shop-For-Parts/a11b129/Bosch-Washing-Machine-Parts
Aug 22, 2016 | Bosch Washing Machines
How to disengage the saftey on 06' dodge caravan sxt power sliding door?
disengage the saftey Anon, I believe it is done on the overhead console or if you mean the child prevention lock, it is a small switch by the doors latching assembly. Links below give instruction.
Thread 2011 Grand Caravan Sliding Door Child Safety Lock Engaging on its...
Dodge 2006 Grand Caravan User Manual
How To Install Replace Power Sliding Door Lock Actuator Chrysler Town and...
Apr 03, 2016 | Dodge Cars & Trucks
Tailgate sometimes does not un lock.
Neil. Tailgate lock actuator may be wearing out. Tail gate lock actuator replacement links below. Check the attached links,instruction and guides, Good luck
LIFTGATE HARDWARE PART 2 LOCK DETAIL for Buick Rainier
Door Lock Actuator 1ADLA00004
Apr 02, 2016 | 2006 Buick Rainier
Why doesn't passenger door unlock with key fob or switch?
Dannie, power lock actuator faulty. Check the attached links,instruction and guides, Good luck
Front Door Lock Actuator Replacement 2007 to 2012 Tahoe Silverado...
How to remove door panel 2008 Chevrolet Silverado 1500 LT better quality
Automatic Power door lock repair 2007 2014 GM Truck Suburban
Mar 30, 2016 | 2008 Chevrolet Chevrolet Avalanche 1500...
Machine won't start code dl F
The machine is not starting because the door lock fails to lock the door as what error code FdL stands for. It flashes after the door locking routine fails to lock the door after 6 attempts. Replacing the door lock/switch assembly is the only viable if no problem is seen with the wire harness connecting the assembly to the central control unit. The link below contains the detailed instructions in replacing the door lock/switch assembly.
Replacing the Door Lock/Switch Assembly on Whirlpool Duet and Kenmore Elite Washers
Aug 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Control panel displaying DL F and not starting
The door locking routine fails to lock the door after six attempts the the error code FdL flashes to indicate a failure in the door lock and switch assembly. The only viable solution is replacing the door lock and switch assembly. Click on the link below for the instructions in replacing the door lock and switch assembly.
Replacing the Door Lock and Switch Assembly on Whirlpool Duet Front-Load Washers
Nov 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door wont close
I just posted a solution for you on your previous post. I understand that your door will not close. The door latch has probably been damaged. You can try locating the manual release on the door latch assembly and pulling it to see if it resets the latch. Follow this link to see how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
If it doesn't reset, you will need to replace it. Use the link I provided to you previously for the instructions on replacing the door latch. A replacement latch costs approx. $43 and can be repaired by YOU. It's not a difficult repair job at all. You can save quite a bit if you read the instructions I have posted and do this yourself. Don't get discouraged, if you need help I can guide you.
May 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Coded"F dl"
"Fdl" is a door lock error. It's usually attributed to a defective door latch mechansim and/or wiring harness from the Central Control Unit (CCU). More commonly, however, the door latch is the culprit and needs to be replaced. Post back with your model number (located around the door opening) and I can give you advice on where to get replacement parts. If you go to my profile and look under "Tips and Tricks", I have step-by-step instructions on how to replace a door latch on a front loader. I hope this helps you.
May 03, 2008 | Kenmore 4292x Front Load Washer
Whirlpool duet washing machine door lock error
My front loader has the door locked and I can't open it. I have already turned off the power and that didn't solve the problem. The manual says that if you try to open the door too soon after the cycle completes, then the door locks. How do I open it now? What do I do?
Nov 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9200L Front Load Washer Logo
103 people viewed this question
Dan Webster
Dan Webster
Sal De
