Question about SanDisk Sansa e250 MP3 Player
Sansa clip Well my sansa clip is acting weird when i plug it in to its usb cable it says connecting then 10 seconds later it says disconnecting and I need it to work because I need it for school and I don't have the money right now to go but a new one. what do I do?
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Sep 08, 2008
My sansa clip 2 gb doesn't work , when i plug the usb cable my sansa starts charging battery but I can't pass songs to my sansa because it doesn't recognize it , what do I do?
Hi
Try and reset the player by inserting a pointed object inside the small hole, press and hold for 5-10 seconds to let the player reset. If this doesn't work then connect the player with the computer and let it charge for a while. Now go to control panel-> administrative tools-> computer management/system management-> storage, check if you are able to see the mp3 player here. If it is visible then try a reset and try again. If not then reset the player while it is connected with the system. This will resolve your issue.
Hope this helps...
Sep 14, 2010 | SanDisk Sansa m250 MP3 Player
My Sansa clip mp3 player doesn't get detected
Trying:
1. Update Windows Media Player 11 for computer
2. Get in Device Manager, right click on icon device and anable it.
Good luck
Jan 22, 2010 | SanDisk Sansa Clip MP3 Player
My sansa clip mp3 player wont come on
Connect the Sansa to your computer via yoru usb cable.
Press and hold the Power On button and the Play button (>||) for 20 seconds
Jan 07, 2010 | SanDisk Sansa Clip MP3 Player
Mp3 player malfunction
1. Try updating the drivers-
- Right click "My Computer", choose properties
- Click the hardware tab and choose Device Manager
- See if you find the name of the device there - if yes, Right click on it and choose "Update Driver"
2. Try changing the mode to MTP
3. If nothing works, unplug the USB cable, Lock the device, Push the round button in the middile of the Sansa player, continue holding it and plug in the USB cable.
4. One more option you could try -
  • turn off your mp3
  • press the hold(lock)button down to activate it.
  • press the center button and keep it pressed ..
  • connect the USB cable supplied with the device always pressing the center button,
  • connect the other end of the cable to a USB jack on your PC.
  • From there it should work properly.
Dec 14, 2009 | SanDisk Sansa Clip MP3 Player
My sansa clip mp3 2gb cannot be seen by windows and sus I cannot
I heard if you just disconnect the usb cable from the device, lock the device, press and hold the round middle button while you connect it back to the usb cable, it should appear.
Apr 14, 2009 | SanDisk Sansa Clip MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
When i plug my sansa clip in the usb it wont pop up.
change the cable then check , or check in some different system
Nov 27, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Clip 2GB won't transfer songs
I had a similar problem with with one of my mobiles, so not sure if it applies in this case, check the ports, and make sure the device is connected to the correct usb port that the pc has allocated to your portable device (sansa clip)
Sep 17, 2008 | SanDisk Sansa Clip MP3 Player
Sansa e270 freezes when USB cable disconnected
Reformat the whole thing with Rockbox. That's the whole point with buying the Sansa, as far as I understand.
Jul 12, 2008 | SanDisk Sansa e270 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
