Question about Sony Cyber-Shot DSC-P52 Digital Camera
Troubleshooting for my sony cybershot 3.2 megapixels
Please kindly advice me on why my cameral lenses refuse to open even when the batteries are new.
victoria
    Genius:
  • 1,689 Answers
There is a possibility that the lens assembly is not in the right angle like a piece is not in line, or a possible gear slipage, there are many other reasons why this is happening, you may refer to the pictures below.
question, does the camera give out an error message or when you turn it on and press the zoom, do you hear a sound from the camera itself?
if in case will you turn it one and gently push the kens sideways, because like waht i mentioned, a part may just be stuck.
http://forum.ecoustics.com/bbs/messages/8691/248818.jpg
http://forum.ecoustics.com/bbs/messages/8691/248819.jpg
Posted on Aug 19, 2008
Len is not opening
The following video lists troubleshooting steps for a jammed camera lens:
Dec 13, 2012 | Sony Cybershot DSC-W55 7.2 Megapixels...
My camera is shutdown while the lense is out. What to do?
I think the battery is the first thing that you should consider about. Seems like your camera has no power even to make a picture. Have you check the battery power? If the camera got low bat you should charge first and try to turn it on again.
If you have make the battery full but the problem persist, maybe your battery already drop/broken so you need to buy the new one. But if you have a friend who have the same camera as you are, you can borrow his/her battery to check out weather this is battery problem or not.
Hope this help and be kind to rate please.
(^_^)
Jan 08, 2011 | Sony Cybershot DSCW310 Digital Camera
I own a sony cybershot dsc w35 when i switch on the screen displays "turn the power off and on again" help?
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cameras
My Sony Cybershot w120 camera and now the lense won't pop out
Hi, there is no need to buy a new camera. The lens is avaible as a spare part. If you get a help from an authorized service they will solve your problem
Apr 08, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Sony cybershot 5.1 megapixel doesn't start at all even when i put in new batteries. Is this a problem with the start-up button? Need your help please.
F001 or F002 are faulty. If both are OK than replace SY-127 board and keep in mind that both Fuse are also located on SY-127 Board.
Nov 26, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
Sony Cybershot camera won't turn on
i think dere is sm problem i ur camera battery .....
replace it frm d shop where u hv purchased ur camera n see it works or not....
if dere is still havin problem show it to ur dealer....n tell him d fault...
Jun 18, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Sony cybershot DSC-W50 lens problen
thats normal.
it just doesn't have enough power to bring the lense back in.
once you charge your battery and turn it on the lense will automatically come back in and then out for you to take a picture.
Apr 06, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony cybershot dsc-n1 took 6000 pics and stopped working Screen went white before died with lense extended no sign of power next cybershot DSC-N2 took 15,000 pic and died just refuses to turn on. no power...
no non of sony cameras come with any life pan
ya they are telling something baout life cycle
but i have cybershot with 29000 pic and my friend is having about 20000 so if your cameras is in warrenty period then go to sony service station they will fix it
or if you r out of warranty period then go for repairing your camera probebly changing CCD of your camera will fix this problem
Mar 26, 2008 | Cameras
Sony Cyber-Shot DSC-P52 Digital Camera Logo
271 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
