Question about Hunter 52" Ceiling Fan With Light And Remote Control
Remote wiring I have an existing ceiling fan with an add on remote control. Does anyone have a wireing digram or can tell me how to wire it up. The switch on the wall kills all the power coming to the fan. I have the color wires wired together(pink to pink , etc.) It is a hunter add on divise. Model # CP911OR
  • Fred Boehme Aug 19, 2008
  • Jesse Hassan May 11, 2010
    What color wires do you have in the wall? What color wires does the switch have?
Coldcut
  • 1554 Answers
SOURCE: wiring a ceiling fan with a remote sensor
since you have a remote, you don't need that extra wiring for the light/fan. just wire nut it off.
the switch at wall has 2 switches but only one will work now.
Posted on Mar 31, 2008
muttandjeff
  • 359 Answers
SOURCE: wiring connection ceiling fan
copper to green , white to white , seperate the black and the black with th white tracer you wired together connect the black to the black and the black with white tracer to the red in ceiling , without looking this is my best advise ,good lk
Posted on Nov 27, 2008
SOURCE: need a hunter westside2 model #21621 instructions w/ pictures
Costco.com has an online manual for this fan. That is the same model number you are looking for.
Posted on Jun 13, 2009
SOURCE: Hunter ceiling fan. Lights and fans turn on and
Obviously you have 2 (two) hunter fans with remote, so one of the fan needs to have frequency changed : on the base fan you will find (white rectangular )receiver that has 8 (eight small) switches, the same switches you would find in the remote control, slide 1 switch up ( on the remote and the receiver). Make sure same number ok (these 8 switches has #'s 1,2,3,4,5,6,7,8) then reinstal your fan back the way it was. you'll be fine. good luck
Posted on Jul 27, 2009
SOURCE: Hunter Douglas Ceiling Fan Does Not Work
have hunter douglas fan glass globe broke cant find repalcemants i have all the serial no do you no wher i can go to find 91/2 globe
Posted on Aug 20, 2009
Help. I need help properly connecting wires on a new ceiling fan.
Usually, the fans with remotes will dim the lights by holding the light button for a few seconds. So, the red wire would stop this feature if wired directly to the fixture. That would eliminate the wire coming out of the receiver for the lights. If you want the light to dim, then tape off the red wire, so the remote will dim them. The wall switch won't work anymore. If you want to connect the red wire , tape off the wire from the receiver that connects to the light sockets and connect the red wire to the wire for the light sockets. This will operate the fan but the remote will not dim the lights. If you have a motor speed controller in the wall from the old fan, remove it and replace it with a switch or eliminate the switch altogether so the remote will control the fan speed.
Nov 13, 2016 | Dryers
Trying to replace a remote controller in a Hunter ceiling fan with a Harbor Breeze univer. need help with wire color code.
Did you try reading the directions that came with it? I can tell you that the black wire with white stripe coming from fan is the light wire.
Apr 01, 2016 | Hunter 52" Ceiling Fan With Light And...
Would like some troubleshooting help with a ceiling fan that the switch turns the light on/off but the remote won't control the fan. Can anyone help with wiring questions?
Is the remote control function an add-on to the fan, or is that built into the unit? If it's built in you'll want to go to the manufacturer on that one. As for wires in the wall, black is "usually" the 'live' wire, while white is the cold line. I'm no expert on wiring, but have done some outlets and light fixtures before. Good luck!
Dec 07, 2013 | Dryers
Wiring instructions are terrible. Ceiling wires = Red, Black, White, Copper. Fan wires = Black, White, Copper. Remote wires = Neutral in(Black), Live In(Black), Light out(White), Fan out(White),...
That is dificult to follow .. here is the usual wiring plan for ceiling fans .. green to green or bare and mounting bracket ... ceiling black and red are live from the switches, fan and light.with a remote you really only need one of these , so cap off the red and use the black as your input to the remote .. the neutral to the remote should be the white .. there are only 3 wires from the fan so I am assuming that there is no light , or the light will be activated from the remote .. the black for the fan and the black for the lights connect to marked wires on the remote. .. lights out, fan out
or looking at your description .. ((Remote wires = Neutral in(Black) white ceiling wire, Live In(Black) blaxck ceiling wire, Light out(White) blue Fan/Light wire, Fan out(White) black fan/light wire, Common(White) white ceiling and white fan/light wires.
May 21, 2010 | Hunter 27148 Remote Control
I am installing a ceiling fan/light with a remote control and the wiring in the ceiling has a red wire and two white wires which are connected. I am used to seeing only a black and a white wire. in order...
the two white wires are the neutrals, just add the fan's white wire to the other whites. The red wire is the hot wire, same as a black, so connect it to the black.
Oct 11, 2009 | Home Decorators Collection Star-tech Fan...
Grande Lodge Fan
Aug 06, 2008 | Hunter 52" Ceiling Fan With Light And...
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Wiring a ceiling fan with a remote sensor
Mar 31, 2008 | Dryers
Wiring-
The ceiling has Black and white (dirty I expect) ,
black is hot , white is neutral
the green is ground ( the fan will ground through the mounting screws)
so connect the black to black (hot)
as you have only one choice left that is the blue/white to white.
I assume you have a strong bracket and a fan was existing previously in this spot. If not you have to install a new fan support and wiring box.
Jan 26, 2008 | Universal Remote Control Hampton Bay...
Dryers Logo
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
