Question about Whirlpool LSQ8000 Top Load Washer
WHIRLPOOL TOP LOADER 3RLSQ8000
THE MOTOR APPEARS TO BE WORKING BUT THE DRUM DOES NOT SPIN.
THE WASHER FILLS UP WITH WATER BUT THE DRUM DOES NOT AGITATE AND DOES NOT SPIN IF SELECTED.
ALL I CAN HEAR IS THE MOTOR WHICH SOUNDS AS IF IT IS WORKING ALTHOUGH A LITTLE CRANKY!!
NOT SURE WHAT THE PROBLEM COULD BE?
ANY IDEAS MOST APPRECIATED.
THANKS
PAUL
    Genius:
  • 1,028 Answers
Ck coupling between motor and gearcase ..probably broken or cracked ..remove 2 screws on back bottom of console lift console up remove lid switch plug remove clips each corner remove cabinet remove clips on pump remove 2 screws holding motor clips on remove motor clips remove motor and there it is
Posted on Aug 20, 2008
Washer fills with water then stops, will not spin or drain water. There doesn't appear to be a plumbing issue.
if it's running (making noise) but not moving it's the coupling between the motor and trans$13.00 part if it is just sitting there quiet it's probly the lid switch is broken this only applies to top loaders
Dec 09, 2009 | Whirlpool Washing Machines
Washer motor runs, but the drum does not spin on the spin cycle
It is most probably the motor coupling if you have a Whirlpool top loader.
Ash
Oct 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Top Loader LAT9406AAE s/n 23257742UQ Will not operate in any mode
if the washer will not fill I would change the water inlet valve. this could be the problem for all other issues. if the machine has no water in it, likely the timer will not advance to wash.
Oct 27, 2009 | Washing Machines
Whirlpool washing machine (model LLR 9245 B) does not work
If it's a top loader, the coupler is broken. It's located between the motor and the gearcase. If you put it in spin and hear the motor run, this is your problem. It drains because the pump is mounted on the opposite side of the coupler and will be un-affected
Mar 25, 2009 | Whirlpool Washing Machines
3RLSQ8000 Top Loader
Make sure the lid switch is making good contact throughout the spin cycle.
Jan 15, 2009 | Whirlpool LSQ8000 Top Load Washer
Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool top load washer LSQ9610LG0 wont spin but makes noise
HI thanks for your question. the part that failed is called the motor coupling. it s located on the motor and the transmission. if you need help to replace come on back. but that's the part you need to change. thanks
Oct 14, 2008 | Whirlpool LSQ9610L Top Load Washer
Whirlpool LSQ8000 Top Loader
the motor coupling is most likely broken. part number 285753A.
Aug 19, 2008 | Whirlpool LSQ8000 Top Load Washer
Whirlpool LSQ8000 Top Load Washer Logo
242 people viewed this question
Dan Webster
Dan Webster
Sal De
