Question about RCA F36668 36" TV
RCA tv with guide plus comes on and off randomly
My 36" tv is hooked up to a sat dish and has worked fine for years. It just started to have the guide plus menu come on (and off) then goes to regular tv menus without using the remote and goes back to regular tv, like nothing has happened. Have tried to reset the guide several times and it has helped but it still comes back but not as often. Any help will be much welcome!
  • Anonymous May 13, 2009
    The TV has a mind of it's own. It pops into the channel guide and then scrolls thru the menu's. You cannot make it stop. then after a while it decides on it's own that it's tired of doing this and goes into a channel and works as normal.
    Problem Solver:
  • 17 Answers
These tv's are bad for caps in power supply, fluctuations freaking your micro.
Posted on Aug 19, 2008
How do I hook up a Pioneer VSX-918V receiver to Sat.Dish box?
For the audio portion, you must have either a digital coax, optical connection or analog L/R composite RCA jacks plugged into the "Sat.audio in" on the rear panel of the chassis. The other end of THAT connection must come from the "audio out/ variable out" from the T.V. or from the Sat.Dish box.
Sep 12, 2014 | Pioneer VSX-918V Receiver
I have a 322 dish receiver there is just too ports to hook to and i have ant.+ cable and sat. to hook to it anyhelp would be welcome. thanks
Heychuck68102, my name is Mike Houston of DISH Network and I was going over yourpost and I see where you want to connect a cable wire plus you're satellite. Ifyou have a TV that will allow for a RCA connection you can run the RCA cable tothe top red, white and yellow inputs and run the antenna directly to theTV/Antenna IN. Then you will be able to connect the cable to the TV CH ¾ input.I will send a link to help with these steps, http://www.dishnetwork.com/SupportSection/how-to-set-up.
Apr 16, 2011 | DISH Network 322 DTV Receiver
RCA F36715 36" TV received this tv used from a friend. we do not have original remote so we use a generic universal remote. tv works fine, but we cannot get the Guide Plus+ to work. we went through the...
You're cable company may have quit using TV Guide info from "TV Guide", because they want you to get their box for this info, or to save expense. It happened here in Michigan about a year ago. If you have local ABC, NBC, and PBS stations, you can get this info downloaded nightly through an external "over-the-air" antenna.-- assuming you're in the U.S.
May 05, 2010 | RCA F36715 36" TV
RCA Home Theater Premiere 36" TV comes on automatically
Only two possible reasons I can think of for this--
ONE: you have looked in the customer menu and there is no item listed as Timer?
TWO: Does THIS SET HAVE THE GUIDE PLUS LOGO ON THE FRONT OF THE SET? IF IT HAS THE GUIDE PLUS--YOU WILL FIND IT IN THE MENU ALSO---
LET me know if it has the guide plus feature and I can tell you how to end the problem--most of these the set will come on at the same odd time and usually with volume up high.
SD TECH
Dec 26, 2009 | RCA P52937 52" Rear Projection Television
No pict. power button blinks
Chances are you have a bad flyback and two bad electrolytic caps and a retrace cap gone bad. At its best you may have bad grounds under the H.O.T. And that would be under this transistor next to the 100 ohm half watt resistor a coil.Unsolder this coil clean the board contact and replace this coil!
Dec 19, 2009 | RCA F36650 36" TV
Problem with the guide plus
its really pretty simple once you know what you are doing..press the guide button and read and follow instructions...it guides you through it...just go slow...you cant break it...just start over if you press wrong button...it provides all the info you need...try it again...
Dec 14, 2008 | RCA F36650 36" TV
I can not get my tv to work with dish network
The RCA guide will not work with the dish remote. You can get the guide to close if you press the White TV button then press cancel. Remember to press the SAT button after you close the guide.
Nov 19, 2008 | RCA 32F531T 32" TV
Rca f36648 & rca HOME THEATER
Have you tried just hoooking up the DVD player by itself? Is the DVD player output setting correct? Also, make sure the "video input" is set for the correct channel that you are viewing (i.e. Channel 3).
Jul 31, 2008 | RCA F36648 36" TV
No sound
Maybe the audio amplifiers ICs are damaged.
May 21, 2008 | RCA RT2600 System
36" RCA TV Wont power up
IP030 Regulator part number 263567/ Regulator overheating
Nov 29, 2007 | Televison & Video
RCA F36668 36" TV Logo
121 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
