56 altura ceiling fan only works in reverse, remote does not change direction. patjim@mts.net
  • Mr Smith Sep 10, 2008
    read elsewhere to use the remote to turn the fan on high, then hit reverse...Ill try it tonight.
    I wish HD simply put a reverse switch in the fan motor itself...stupid design in my book
    Genius:
  • 2,920 Answers
There is a switch on the fan itself you can use to change the direction of the fan
Posted on Aug 20, 2008
Altura 68'' ceiling fan only operates counter clock wise. Removed remote control function. Operates by 3 speed wall switch. How do I operate the fan in the clock wise position. Installed in 2010. It just...
If there's no reverse switch on the fan you won't be able to unless you put the remote back. Also, It should be going counter clockwise.
Aug 09, 2014 | Dryers
I purchased a 68" altura
You may have to physically reverse the position of the fan, or at least the blade
Dec 18, 2010 | Kitchen Ranges
Fan won't reverse though it has before
It could be 1 of 3 things. 1) Receiver unit, 2) Sender (Remote), 3) Motor. For my brand new ceiling fan it turned out it was the motor.
Jun 13, 2010 | Hampton Bay 24002 Ceiling Fan
My ceiling fan has no reverse switch, how do i change the direction
My fan does not have a reverse switch for sure so I scoured the net and got no real answer. I did come accross a comment that said that it worked internally at the remote box in ceiling. Here is how I finally figured it out after about 6 months of searching. Put the fan on high, Turn wall switch OFF, Hold the HI button on remote, Turn switch back on. IT WORKS!!!!!!!!!!!!! Sparq
Jul 18, 2009 | Hampton Bay 24002 Ceiling Fan
Unable to reverse Thomasville ceiling fan rotation w/remote
I e-mailed Thomasville Lighting after my original post but did not get a reply. I then searched and found a similar problem on this site (http://www.fixya.com/support/t187540-ceiling_fan_not_reverse_remote) and read the Best Solution which mentioned running the fan at medium speed (not low), then pressing the Reverse Direction button....it worked. As stated in the original suggestion, this was very counterintuitive and not documented in the manual.
Apr 28, 2009 | Emerson CF2600PW Raphael Pewter Ceiling...
The Hampton Bay Altura Ceiling fan functions only with remote.
I contacted the manufacturer (kingofffans.com) after my Altura fan would run on high speed only and the remote would not control any thing. They said their was a manufacturing defect with a capacitor that affected many of the Altura fans. We are now on a waiting list for a new capacitor and housing, because they did not have enough replacement parts.
Nov 26, 2008 | Hampton Bay 52 In. White Redington...
Hampton Bay w/ remote and will not reverse.
To eliminate this problem and any humming noise, remove any wall switch that turns off and on the fan, just remove the switch from the line and use the remote to operate the fan.
Jul 29, 2008 | Universal Remote Control Hampton Bay...
Hampton bay altura 68
Read this on another thread - apparently the solution came from HB's tech support.
Turn the fan speed to HI and then select Reverse.  You should hear a "click" and see the fan reverse direction.  It seems that the reversing relay only works when the fan speed is set to HI.
Good Luck!!
Two Metre Man
Jul 12, 2008 | Hampton Bay 24002 Ceiling Fan
Heating & Cooling Logo
217 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
