Hi.
First option: Try to change the USB cable from WDP 320GB. to CPU USB ports.
Second option: Connect to windows 7 operating system. if can't access also. problem with hardware hardisk mainboard inside.
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
SOURCE: My computer does not recognize
if u are using a external hard disk case with the normal hard disk
try connecting your hard disk with a new casing.
if it is made as a external hard disk change the cable .
because after a few time usage the cable will not be quite good as new.
After inserting the usb cable in your pc if it shows any warning
information, or any message just give me that too for exact solution
SOURCE: Western Digital External Hard Drive Won't Boot Up
Take it our of the external encasing and plug it in directly to your motherboard. This has worked for me in the past. I just had my second wd external harddrive crash so now I will do the same process all over again.
SOURCE: access denied
I am having the same problem..computer is showing that its there but says its 'unaccessable'...access denied. a few days ago, my computer got turned off due to a power outage. when I turned it back on, the mybook was deleting itself.....It worried me, and it wasn't showing up on my computer for a little bit. eventually it was back on and had backed itself up. Now again after another power outage, it deleted itself and now its just at a stage where its saying access denied. sorry, I don't have a solution, I'm just like you, looking for answers. I had so much data on this, please don't tell me that I've lost it!
i noticed you ran the chkdsk utility on this drive did you try to repair bad sectors or just files
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box if still no joy
try to use the external hard drive in a different computer and check whether you are able to access the data that is present on the external hard drive or you can try to connect it to a different port and check
hope this helps
