Question about Protron PLTV-32 Television
Where is the Fuse??
I posted earlier... I need to replace the fuse..I ripped the back off of my TV and I need someone to describe the fuse Im looking for??? I cant seem to find it (although Im sure its right in front of my face)
  • jadonavanna Sep 18, 2008
    can't get power to tv might be fuse where is it
Once you take off the back of the tv you can see where the power cord plugs in and there is a thin metal cover you pull that off and unplug the power cord from the board and right in front of that under the other metal cover you will see a small fuse with a white middle. pull it uot and get a new one. i think that is what you are looking for
Posted on Sep 20, 2008
Wont turn on
whille tv running after 5minutes
shotingdown
Nov 26, 2013 | Akai CF2791 27" TV
I have the red Cuisinart BFP-703 SmartPower Duet Blender/Food processor. I turn it on and press and of the buttons and it does come on. What should I do?
if you over loaded these machines there is a thermal fuse one time shot will blow . it is not resettable , you can buy them @ Radio Shack 8 amp should do fine . it might be stamped with the rating value too. need a test meter to check component very small .187 diameter & .750 length apx
Mar 14, 2010 | Cuisinart Blenders
F24 fuse blowing audi a3
What is the F24 fuse? What does your panel cover/manual say that fuse is?
Nov 05, 2009 | 2006 Audi A3
No power to TV. No sound, no picture.
frist you need to check the fuse it is inside of tv by the power cord looks like this maybe a Panasonic tv did notsee any model number so i will gess as to what is wrong check fuse if blown need to replace with a white glass looking fuse of same value like i said dont know what model number this set is but the thermister could be at falt for the fuse to blow.
Mar 14, 2009 | Panasonic Televison & Video
Power light goes on then shuts off after a couple seconds
my friend you have a power supply problem,check the fuses, replace any blown one and if blows the fuse again you need someone with electronics skills to replace one the yokes that is bad,usually is the red.
caypianan@yahoo.com
Jul 27, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Panasonic tv CT32SL14J
You'd better make sure that there's no power on in the TV by checking the red light in front of it. If it's sure there's no power when the TV's plugging in the outlet, then the problem may be the fuse.
The GLASS fuse locates right after the power cord where is connected to the TV. Using a screw driver to open the back (make sure the power cord already taken out from the outlet !), try to have the power cord side opened as wide as you can. You can use your finger tip to push straight from bottom to up to take the fuse out. For sure, you can see the fuse having the core disconnected in the middle.
To my case, the fuse was 6.3 Amp and 125 Volt, but I can only get the 6.3 Amp- 250 Volt at my local Radio Shack store. However, it's fine to replace with this higher volt fuse.
It costs about 4 bucks for a bag of 4 glass fuses. Worth to try with the "practice" and for having your TV back on again !
~NDo~
Feb 24, 2008 | Panasonic CT-32SL14 32" TV
Ge model 46gw945
NEED SOME TECH EXPERIENCE ON THIS--- UNPLUG THE TV,,,I REPEAT ,UN PLUG THE TV FROM AC---TAKE THE BACK OFF--CHASE
THE CORD THAT GOES INTO TV AND YOU SHOULD SEE A SMALL 5 AMP FUSE IN A HOLDER,,CHECK TO SEE IS IT;S BLOWN--IF SO ,,REPLACE IT WITH"""THE SAME FUSE""""""""""" ,,AFTER REPLACING --REPLACE BACK OF SET ,,PLUG IN AND TURN POWER ON,,IF IT STILL DOES NOT COME ON --CALL A SERVICER,,,,,IF IT WORKS ,,,,,,,,,,,,,YOU OWE ME 35.00--HA!!!!!!!!!1
Feb 09, 2008 | GE 46GW945 46" Rear Projection Television
Panasonic CT-32sl 13 32" TV
This sight rocks! And so do the people that posted information! Went to Radio Shack and got the 6.3amp 250 volt fuse. Fuse was easy to get to once I removed all of the screws and easily slid off the back. $2.99 fix (foe the fuses)
Jan 04, 2008 | Panasonic CT-32SL14 32" TV
Fuse blown
the fuse will always blow if there is a shorted component. the horizontal output transistor may be the most likely culprit, if you are not a technician, have it service by a qualified one.
May 15, 2007 | Samsung TXR3079 TV
TV turned off by itself and now it won't turn back on
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. Could be several things- a 15 cent fuse, some solder joints that fail due to expansion and contraction of the circuit boards. Hard to say. Look for parts that look or smell burnt, might help you narrow it down. The fact that it stopped suddenly, with no gradual deterioration makes me think that something blew, and it's a matter of replacing it. No tube damage or anything more serious, just a local fuse or cap. let someone have a look Good luck
Jun 13, 2006 | Philips 27PS60S 27" TV
Protron PLTV-32 Television Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
