Home | IBM | G52 15 in.CRT Conventional Monitor | Problem install RH9 at ...
IBM G52 15 in.CRT Conventional Monitor
Problem for IBM G52 15 in.CRT Conventional Monitor
Problem install RH9 at Proliant 1600
By Bomber - usenet poster
Try to install RH 9 at Compaq Proliant 1600 Server, with 128MB RAM, 500MHz
CPU, 9GB SCSI HDD.  An "unknown monitor" probing error occur even the
install mode is
graphic mode or
text mode or
using "linux skipddc text noprobe".
I had try to use HP, IBM G52 and E54 monitor, but get the same result.  Did
anybody knows how to install RH 9 at Proliant 1600 with trouble free?
Posted via news://freenews.netfront.net
Complaints to n @netfront.net
Best Solution
posted on Aug 11, 2005
Very Helpful)
paulrmc
Rank: Apprentice
Rating: 0%, 0 votes
I solve it.
I think it is due to the USB chip of the Proliant 1600, actually it don't
have USB port.  It can solve by using "linux nousb" to install.  After
probing the monitor, it probe my PS2 2 button mouse to a wheel mouse.  I
think it cannot reconize the correct mouse if USB chip exist.  I can also
use the GUI to install.
BTW, HP technical support only said that  "The behavior you are facing is
due to Proliant 1600 does not support Red Hat 9 and is not certified for the
same.", they don't know the problem is due to the non-existing USB port.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
Powe33
Rank: Apprentice
Rating: 0%, 0 votes
I think the main problem is the Proliant's video card, which is not
supported by the RH9 install media, but I could be wrong.
Try the text mode install, choose "Custom Install" and de-select all
XFree86 packages (and all other graphical stuff). This should get you a
basic installation which you can use on the console. Depending on how you
intend to use the box you may choose to download and install the official
XFree86 from www.xfree86.org and try to massage it gently to work with the
onboard graphics controller. Of course you don't need to do any of this if
you intend to work headless, ie. w/o monitor.
HTH
Andreas
Was this helpful?
Yes
No
Popular Solutions for IBM G52 15 in.CRT Conventional
Questions and Unsolved Problems for IBM G52 15 in.CRT Conventional
Do you recommend IBM G52 15 in.CRT Conventional Monitor?
Answer
Answer
How to raise Dell monitor higher?
Answer
I have 2 x medion 19 inch flat screen monitors and I want to know if I can attach external speakers.... (More)
Answer
focus problem occurs after a few minutes of using
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For IBM G52 15 in.CRT Conventional...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
