Looking at the board with the SATA connectors to the right and the backplate to the left. Look to the lower right corner of the board. You will see a group of two rows of pins(9pins with one missing) The pin that is missing is pin#10. The pins are numbered even on the pin#10 side, odd on the other. The Power Switch - Pin 2 is the Red wire/white is Pin 4. The Power Led - Pin 6 is blue pin 8 is white.
Shhhh! Must be a Gateway Secret.
Those are the power switch button wires. They should slide onto the motherboard only one way. Look very carefully and the plastic should be molded for one fit.
