Question about Akai LCT2716 27 in. LCD Television
Power on no picture
The power button indicates power is going in but no picure, no sound just a small click or something like a relay or something tripping in side . Power light flickers and nothing. Has been unplugged for 2 days plug in no change. NO GREEN LIGHT, RED LIGHT FLICKERS, WENT BLANK ALL AT ONCE, CRACKLING SOUND, NOW SMAL CLICK WHEN TURNED ON, NO PICTURE, NO SOUND
  • shanakey1 Aug 20, 2008
    Power red light is on, but will not turn green even after unplugging set for 10 minutes. Signal comes thru HD black box [Shaw]
    Tech that I contacted told me that he could not effect repairs as the tech is changing so fast that he cannot keep current. Also Akai would not supply parts??
Dougarm
Just unplug the TV wait a a short time, plug it back in and turn on right away. This has worked for me.
Posted on Jan 19, 2009
    Genius:
  • 1,694 Answers
Power supply PC board must be rebuilt = replace all bad capacitors.............T.
Posted on Jan 14, 2009
Power button clicking..no picture
If the power indicator is on, power is getting to your TV. The clicking sound without results means that something is wrong with the internal power supply
Jan 04, 2013 | Philips Televison & Video
Audio Receiver only makes one "Clicking" sound when I push the power button
Definitely sounds like a relay... How old is your unit? Sometimes they get stuck and need a good cleaning with DeOxit. Good luck!
Aug 21, 2017 | Yamaha HTR-5940 Receiver
Philips Magnavox 32MT3305 keeps shutting off with relay clicking. The green power light stays on but the picture and sound go out right after the orange status bar goes away. If the channel up or down...
the relay is the safety protective device..sometimes a defective component or something. maybe an overloaded power supply might caused this problem..so before any thing could gets worst..the relay will shut the unit..
Jul 18, 2011 | Philips 32MT3305 TV
Aiwa AV-D57 , it has no power, the little red light will come on but that is it, it makes a clicking sound when pushing the power button, i checked the small fuse inside and it is good, what can be the...
assuming something isnt blown it sounds like you are having the same problem as me. when you remove the top of the of cover of the unit you will need to look in the back left hand corner of the unit where the power cable comes in. next to the fuse is a small black box that has a relay inside. you will need to remove the outside cover of this relay. make sure the power is unplugged on the unit before you go playing around the 120v input area, but once the power is removed, you will need to remove that cover. you should be able to get it with your fingers, but if not grap it with a pair of needle nose or something. more than likely the cover will crack if not break into a million pieces due to being brittle from years in the heat of your amp. its ok if it does. inside of this you will see a small relay which looks like a coil of small copper wire. on the top (side opposite the board it is connected to) is a silver piece of metal and if you push down on it, it should move like a lever causing two small copper pieces to the left to make contact. (warning: if you know about electronics and relays skip to the next paragraph) basically the coil of wire is an electromagnet. when you try to turn on the unit it powers that electromagnet pulling the shiny piece on top down as long as the unit has power forcing those to copper pieces together, which allows voltage to pass through the circuit just like flipping a light switch.
Your relay is too weak for whatever reason to force the circuit shut and will either click one good time or maybe a couple of times. you may even find that if you keep hitting the button it will come on eventually. unless you are good at soldering and want to waste the money I dont suggest replacing the relay. what I did for the cheapest fix possible was use some electrical tape and wrapped it around the relay forcing the contacts permanantly closed. Now be warned that if something else is wrong with your unit, or you short something in the future you may or may not have the type of protection you would normally have because this relay will not open. it may just blow the internal fuse if something shorts, it may fry the unit. I cant say for sure, because I havnt had that happen. so avoid shorting things or throwing bits of metal shavings and screws inside the unit while powered and you should have a working unit.
Jun 11, 2011 | Aiwa AV-D57 Receiver
I have a Toshiba 51h84.I push the power button and I get a solid red power light. There is a click from inside, kind of like a relay clicking on. No picture, no sound. If I leave it on I get an occasional...
Tv have "LAMP" indication LED light blinking?The tv projection lamp is dead,require changing.Hearing alot of clickings sound too?Mean the board,call the Ballast board is dead.Require change the Ballast too.The Ballast board,the board that help to ignite the projection lamp.
Aug 06, 2010 | Toshiba 51H84 51" Rear Projection...
Power button comes on but no sound or picture
change the resistor in the relay circuit as they go high in value
also when you take power supply panel out check all caps for bulges etc.
Aug 26, 2009 | Philips 42PF9431D/37 TV
RCA SCENIUM HD50LPW166 worked fine, then "POP!!" has power
you lamp is bad. even if it looks good, its not firing (you're seeing the spark gap fire, indicating this). the lamp is customer replacable and roughly $200. the 5 blink error is a general shutdown error
Dec 08, 2008 | RCA HD50LPW175 50" HDTV
Sony KV-27FS100 No Picture
Check Horizontal Output Transistor, if found bad / short, replace it.
Aug 13, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
No sound or picture
your relay is turning off most likelt due to on of the stanby voltages being out of parameters I would check the low voltage regulators and the horizontal output transistors.
Jun 16, 2008 | Toshiba 50HX81 50" Rear Projection...
Akai LCT2716 27 in. LCD Television Logo
422 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
