Computers & Internet Logo
Anonymous Posted on Jun 13, 2011
I want to download driver for MB 945GZT MV 1 0 ATA 133 serial How can I get it ?
Anonymous
Level 3:
  • Master 336 Answers
  • Posted on Jun 13, 2011
Anonymous
Master
Level 3:
Answers
336
Questions
0
Helped
82036
Points
1066
  • Anonymous Jun 13, 2011
    see attach picture.
5helpful
I have a D102GGC2 motherboard with intel pentium 4 processor 524 , LGA775 Pkg 3.06GHz,.So please tell me about related drivers and chipset and how to download from intel site ?
Link for download of drivers etc. is at the bottom. Choose Operating system, etc and what you need (drivers, software, etc.).
I don't know if it will come to you as a hyperlink or not. If not you will have to copy and paste or type in address bar as one long string.
Manufacturer:
Intel
Part Number:
BOXD102GGC2
General
Product Type
Motherboard
Form Factor
Micro ATX
Width
9.8 in
Depth
8.6 in
Compatible Processors
Celeron D ,
Pentium 4 ,
Pentium D
Processor Socket
LGA775 Socket
Multi-Core Support
Dual-Core
Chipset Type
ATI Radeon Xpress 200 / AMD IXP 450
Max Bus Speed
800 MHz
Storage Controller
ATA-133,
Serial ATA-150
Power Connectors
4-pin ATX12V connector,
24-pin main power connector
Processor
Installed Qty (Max Supported)
0 ( 1 )
Memory
Supported RAM Technology
DDR2 SDRAM
RAM Installed ( Max )
0 MB / 2 GB (max)
Supported RAM Speed
PC2-3200,
PC2-4300
RAM Features
Dual channel memory architecture
Video
Graphics Controller
ATI Radeon X300 Shared video memory (UMA)
Audio
Audio Output
Sound card
Audio Codec
Realtek ALC861
Compliant Standards
High Definition Audio
Telecom / Networking
Networking
Network adapter - Realtek RTL8101L - Ethernet,
- Fast Ethernet
Features
BIOS Features
ACPI support,
SMBIOS support,
Rapid BIOS boot
Hardware Monitoring
System voltage,
CPU fan tachometer,
Chassis fan tachometer
Sleep / Wake Up
Mouse wake up,
Keyboard wake up,
Wake on USB port,
Wake on LAN (WOL),
Wake on PCI device,
Suspend to RAM (STR)
Expansion / Connectivity
Expansion Slots Total (Free)
1 Processor - LGA775 Socket,
2 Memory ( 1.8 V ) - DIMM 240-pin,
1 PCI Express x16,
1 PCI Express x1,
2 PCI
Storage Interfaces
Serial ATA-150 - connector(s): 4 x 7pin Serial ATA - 4 device(s),
ATA-133 - connector(s): 2 x 40pin IDC - 4 device(s)
Interfaces
4 x Hi-Speed USB - 4 pin USB Type A,
1 x Parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25),
1 x Serial - RS-232 - 9 pin D-Sub (DB-9),
1 x Mouse - Generic - 6 pin mini-DIN (PS/2 style),
1 x Keyboard - Generic - 6 pin mini-DIN (PS/2 style),
1 x Network - Ethernet 10Base-T/100Base-TX - RJ-45,
1 x Display / video - VGA - 15 pin HD D-Sub (HD-15),
1 x Storage - Floppy interface - 34 pin IDC,
1 x Audio - Line-in - Mini-phone stereo 3.5 mm,
1 x Audio - Line-out - Mini-phone stereo 3.5 mm,
1 x Microphone - Input - Mini-phone 3.5 mm
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D102GGC2
Hope this helps.
13helpful
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Ultra ata 133 ide controller........i installed this on a brand new gigabyte MB with windows 7..........Device manager knows its there but with a problem. I cannot locate drivers for this device...
if u cant locate the drivers name, try using unix base(linux) live cd's, like knoppix for example, they usally detect all the drivers u have in minutes and even gives u all the names and serial numbers, then u can download them.
8helpful
3answers
Is there driver for mothetherboard asrock ata 133 for win7
HERE IS THE SITE FOR DRIVERS AND BIOS UPDATE FOR THE ASROCK K7S41GX (http://www.asrock.com.tw/mb/download.asp?Model=K7S41GX&o=All)
3helpful
ECS 662/1066T-M2 (15-S120-011003) ATA 133 can this motherboard support core2dou processors? pls i wanna upgrade mind..ty ur client .jay.
According to the website for this product, yes.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&DetailID=725&DetailName=Feature&MenuID=1&LanID=0
7helpful
3answers
In my motherboard manual(ASUS P5GV-TMX) specifications there is an entry showing storage/RAID -- 1 x UltraDMA 100/66/33 4 x Serial ATA First are those speeds ?? So does this mean it doesnt support UDMA...
You have 1 IDE connector (1 X UltraDMA) labeled PRI_IDE on your MB that uses a flat ribbon cable to connect with hard drives or optical drives that use that type of connection. The 100/66/33 are transfer rates: 100 MB/s, 66MB/s, or 33MB/s. These connections are quickly becoming a thing of the past and being replaced by the faster SATA (Serial ATA) connections which have transfer rates of 150 MB/s to 300MB/s. Your motherboard has 4 SATA connectors. (4 X Serial ATA)
Thanks for using Fixya.
2answers
Need to install my new dvd writer on my dell dimension 9200 pc. The plugs are different. now what?
If the plugs are different most likely you bought a SATA drive. If your MB doesnt support SATA then there really isnt any use for that drive, i would return it and purchase an IDE drive, chances are thats what you have. Good Luck!!!
1helpful
3answers
Grand Canyon Tech
Grand Canyon Tech
