Question about GE Profile Harmony DPGT750EC Electric Dryer
GE Profile Performance Dryer
Inside light will come on when door is opened but dryer will not start.
  • Anonymous Sep 03, 2008
    DRYER HEATS UP BUT DRUM DOES NOT TURN
  • Anonymous Sep 15, 2008
    when door is opened light is on cled door and dryer doesnt start tried unplugging no change
GE Easy care 4 prong Installation
Grn = Ground
White = Neutral ?
Black = ____ top or bottom?
Red = ____ top or bottom?
Please advise
Posted on Aug 20, 2008
Control panel turns on but dryer won't start. Start/pause button flashing as usual, but just beeps twice when pushed.
That generally means the door is open. Assuming you have the door closed I would investigate the switch that tells the dryer the door is open. It may be bad.
Jul 10, 2014 | GE Profile DPVH880EJMG Electric Dryer
Display doesn't light up
Check the power cord is tight. and check that you have 220 volts then contact me back
Jan 20, 2014 | GE Profile Harmony DPGT750EC Electric...
I have a ge harmony profile dryer and when its cold usually below 40 the screen will not come on the light inside the dryer when i open the door will come on but the touch will not come on until the room...
I have this same problem and have found that if I disconnect the vent to prevent cold air from coming in, the problem goes away, but it takes about 2 hours to warm up. In addition, I tried putting a hair drying pushing air back through the dryer's vent intake into the dryer itself, and this took an hour.
Some reading indicates it might be a faulty thermal fuse, but it isn't clear.
Did you every find a solution to your problem?
Dec 16, 2010 | GE Profile Harmony DPGT750EC Electric...
My ge profile dryer won't start.I checked the breakers and they were ok. Any other suggestions?
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
May 08, 2010 | GE Profile Harmony DPGT750EC Electric...
GE dryer won't start up - sounds like the drum is stuck.
unplug it,open the door and look up.you'll see two screws,take them out and remove the top panel,then look around three or four inches down from the top and removetwo more screws,one on each side,this is harder than most dryers to work on,not much room to reach under the drum to remove and reinstall the belt,there's also one more screw down on the right hand side below the drum that has to come out also, just remember how you took it apart,if you start it and hear a loud humming sound that's the motor,hope this helps you
Feb 06, 2010 | GE Profile Prodigy DPSR513GA Dryer
THe computer panel is dead. The light comes on inside the dryer when the door is open, but when I press home, power, etc, there is nothing in the computer screen. I bought the dryer 12/29/08. Bonnie...
Hi Bonnie. I see your dryer is under one year old, so don't mess with it yourself. Call a local authorized GE servicer for fast warranty service, or GE at 800-386-1215 to get the standard slower warranty service. (Be sure to have proof of purchase to varify warranty status)
Jul 29, 2009 | GE Profile Harmony DPGT750EC Electric...
Light bulb is out
The bulb is on the inside of the door face frame, just above the door.
Feb 17, 2009 | GE Profile DPSB619ED Electric Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
142 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
