Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore Elite Mod #76523
Kenmore Elite Model # 76523 is experiencing what I gather to be a rather common failure of the refrigerator portion of this bottom freezer unit.   The freezer is fine and holding temp, but the refrigerator portion is another story.   The digital display is operating but cannot be set.   It will show that it is set to 38 degrees and then pops back to 68.   I have of course called Sears who was of no help whatsoever and couldn't get anyone out for four days.   I have called another service who will respond in 24 hours!   Needless to say, but of course I will anyway, this will be my last Kenmore appliance.   They've been great for decades but it seems times have changed.
  • joefiala Aug 22, 2008
    The cheap plastic fan that came as original equipment with the refrigerator was the problem...replaced it with a 'real' fan and the problem was solved. It took about 12 hours for the unit to come back to temp. Thank You!
  • 25 Answers
The problem is the fan unit that pushes cold air up to the fridg, usually located nere the back of the freezer.
Posted on Aug 20, 2008
WHIRLPOOL SID BY SIDE FRIDGE MODEL GD5RHAXNT00 LIGHT HAS GONE OUT IN REFRIGERATOR AND TEMP GUAGE IS NOT SHOWING A READING
What youre experiencing is a common main control board failure.
The main control board for this model is no longer produced. But, don't scrap your refrigerator because new control boards are no longer available -- Save your appliance and high replacement costs and let us remanufacture the control board for you. This is a common control board failure that FixYourBoard.com can repair. We remanufacture the main control board in your model and back our work with an industry leading two year warranty. W10135090 Whirlpool ELECTRONIC CONTROL BOARD MAIN CIRCUIT BOARD
May 26, 2014 | Kenmore 57029 Side by Side Refrigerator
Kenmore Refrigerator Elite Mod # 106.55602400 is not making ice
Is the food frozen solid in the freezer? Does the ice maker get any water to it? Do you see any ice buildup in the freezer?
Jan 19, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have the Kenmore Elite Model # 795.79773.901 and I keep getting Er 1F. What does that mean and what do I do to fix it?
Hi and welcome to FixYa, I am Kelly
I hate to just paste a link to the answer but this answer is quite thorough:
http://www.managemylife.com/mmh/questions/116713-getting-er-lf-fault-code-kenmore-elite-refrigerator
If you have frost build up in the freezer compartment it can impede operation of the fan. Frost build up is usually a secondary symptom of an automatic defrost system problem. i.e it is not defrosting... due to a failure of one of the following:
-defrost heater
-defrost thermostat
-defrost control
Hold the door light switch depressed and see if the light goes out and that the fan is running.
If the fan has failed the part number is around $60.00 usually. There are AC and DC fans in this unit.
Your parts can be found here:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Refrigerator-Parts/Model-79579773901/0583/0161000/F1104078/00002?blt=06&prst=0&shdMod=79579773901
Thanks for choosing FixYa,
Kelly
Jul 21, 2011 | Kenmore Side by Side Refrigerator
Kenmore model 106.53532300 side by side. Replaced compressor start kit, compressor now runs. Freezer freezes but refer still warm (60 degrees) what could be wrong
Are you cleaned the coils? Is it frosted?
If it is frosted then usually one of the defrost components has failed; maybe the defrost timer, defrost heater, or defrost thermostat.
Check it and keep us updated.
Jun 22, 2011 | Kenmore Side by Side Refrigerator
Our Kenmore Elite fridge mod 596.76252702, leaks about a cup of water on floor, 1-2 times a month
The condensate drain that takes the defrost water out of the fridge is blocked.
Pour some warm soapy water down the freezer drain and this may clear it
Apr 04, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My Kenmore Elite 25' Bottom Freezer Refrigerator, the lower freezer portion is working mainting a -3 degrees but this morning the upper refrigerator portion is not, what would be some likely problems to...
I guess you are talking fahrenheit temperature?
This is ok for the freezer.
The problem could be;
\ ducting blocked restricting air flow
\ evaporator fan not working
\ ice build up on the evaporator blocking air flow
You will need to get a technician to look at this problem for you
Mar 25, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Fridge Area Light Will Not Turn Off
Yes unit was built by LG. The light broplrm is most likely the motherboard along with the light socket assembly that would have to be rreplaced. There is service information that the repair should be cover by an extened warranttee from the manufscture. The service flash sf46-515 indicates this and was recently put out. call Sears for service. Please note: recheck your model number as the one covered in the service info ends in the number :"one" insted of a "0"
Sep 02, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Bottom Freezer Mod. #795 75544401
The unit was built bt LG. It is a computer controled unit and the timer is built into the main control board on back of the unit. However, the most likely cause of the broblem is the defrost terminator located on the evap on the upper right hand corner. Also, try unpugging the unit it will reset the computer board. You will also have to defrost the unit.
Aug 28, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
373 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
