Question about Kenmore Elite 45986 Front Load Washer
The "fin" inside came off
The plastic agitator "fin" inside the machine came off, and I can't figure out how to get to the drum to screw it back in. The same thing happened to the matching dryer, and the tech just took off the front panel. I tried that with the washer, and of course the drum is sealed. Do I get to this from the top? When she fixed the dryer, the screw was sitting in the bottom of the dryer...I have no idea where it would be if I need to go in through the top. Any help would really be appreciated!
  • jlillie42 Aug 19, 2008
    BTW- this is a front load machine
    Genius:
  • 1,028 Answers
If i remember right ..remove washer top remove hose or pug in top of outer tub rotate basket until fin is at top i believe you can acess screw through hole..of course i have been known to remember wrong and apologize if i have this time let me know
Posted on Aug 20, 2008
One of my dryer fins fell off how to get it back on
Look inside the drum at the place where the fin was on the drum.
Do you see any screw holes now showing?
That will tell you that you need to take the machine all apart and re-fasten the fin on with some screws, unless the holes are stripped out in the fin itself, in which you will need to get a little bigger screws, or buy a new fin.
Oh yes, I have been using an epoxy cement in a tube that has 2 chambers, and this may help you.
I think it would work here, but will not be strong enough to glue the fin back on.
I sort of think it would stand the heat if you used it to help secure the screws into the fin.
Honestly, to me the new fin sounds " hard to get".
Be blessed.
Feb 03, 2013 | Maytag Neptune MDE5500AY Electric Dryer
How do you replace the plastic fins inside the drum
You pop the top and use a screwdriver to put the fins back.themobilian_3044.jpg
See the spring clip? Use a putty knife to release the top
Then you can open the door and hold the fin inside while you use a screwdriver to put them pesky fins back in there.
I wrote a page on these
Frigidaire/Gibson/Kelvinator/Westinghouse Dryer Pixthemobilian_3046.jpg
Oct 20, 2011 | Frigidaire Washing Machines
The plastic fins inside my frigidaire front loader are trapping soose coins and a key i need inside the hollow fins. I guess in the spin mode just enough space opens up to let them in? How do i remove the...
take off the back of the machine. It will give you access to drum. There are screws to loosed. Go the PartSelect.ca and type in your modle number. You will be able to look at a diagram on how they are removed.
Dec 02, 2009 | Frigidaire GLTF2940ES Front Load Washer
Dryer fins coming loose
Unplug Unit.
Refer to pages 5-2 and 5-3 of the manual below to see how to expose the drum by lifting the top of the machine. Then turn drum very slowly and only until the screw holes for the missing fins are within your reach. Most of these dryers have two sizes of fins make sure you order the right one if you need to replace them.
Good Luck
Download this file : Maytag Dryer
Sep 07, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I have a GE washer that will not agitate. The washer thinks it is agitating and goes through the cycle. The drum turns but the agitator doesn't. What could be wrong with it and how hard is it to fix?
Pull the agitator off and check the plastic block attached to the shaft top. Is it split or has sheared splines inside it? Remove the mounting screw to expose the shaft. Does it turn back and forth when it should be agitating? If no, possible transmission problems.
Jul 15, 2009 | Zanussi FJS1225W Front Load Washer
No agitation
is this a whirlpool/kenmore top loader if so your drive coupler is broken
Dec 31, 2008 | Washing Machines
Whirlpool Duet: gray plastic agitator poece inside drum broke off
here's the part number for the replacement 8182233, thinking it may come as a 3 pack , if they're not broken no need to replace. but the new one will simply slide in and with a click forward lock into place. they also come shipped with a screw to secure. in order to install screw you'll need to remove the top of the washer(3 screws across the back of the top assy and slides back and off. then you'll see the top of the tub area, a small black hose will run from the white box to the left to directly top of the tub assy. remove ethe hose from the tub and spin the inner drum to the correct position, they screw hole will line up through the opening, re-secure the hose to the tub and your in!
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Replacing the a drum "fin"
you should be able to Open the top of the Dryer, from front to back, U might need to pry the front corners up with a flat tip screw driver. It should hinge to the back, to expose the Tub... Hope this Helps U...
Sep 20, 2008 | Maytag Atlantis MDG6400AW Gas Dryer
Replacing the fins on Duet whirlpool washer
most paddles are removed by grabbing hold of the paddle and pull towards the front of the washer which should release them youll need to lift it out when you have pulled on them love
Sep 12, 2007 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
104 people viewed this question
Sal De
fordexpert
Robert Rankin
