Question about Apple iPhone Smartphone
Need help fixing my iphone
My husband was looking through the pictures on the iphone when it started to overheat then he said that it suddenly turned off and it wont turn back on. what to do.
Plug it into the charger and see if it comes back to life. My iphone did the same thing but surfing the net. It actually erased all my itunes, which really sucked, so I had to restore it on itunes. Now it works fine--for how long, I don't know. You could also try holding down the power button and the home button at the same time and see it reboots.
Posted on Aug 20, 2008
Not sync iphone itunes
Make sure the cable is not broken, and the connections are in good condition, look at the IPhone connector, make sure its clear of anything foreighn.
try a different cable, if it's not the cable;
Start with shutting off and turning back on both the phone and laptop.
Update your ITunes if needed
If your still having issues, try reloading ITunes.
Still having issues it could be a phone issue, have it looked at....
If your stuck anywhere let us know.
Good luck,
Sep 01, 2014 | Apple iPhone 4S
How to turn off factory settings?
"won't work" is not very useful to try to help. But the solution is resetting/updating the phone through iTunes.
Jun 16, 2014 | Apple iPhone 4 Black Smartphone
My iphone wont turn on after i updated it to ios 6 and it just shows me a picture of itunes
you might need to do a hard reset or you could look up on youtube how to get pass the itune logo on an iphone
Jan 05, 2014 | Apple iPhone 4S
My IPhone will not turn on. It suddenly went off, like it powered down, but wont turn back on after a 20 minute charge...even when still plugged into charger.
Try to connect it with you PC via usb cabal...and if your PC shows that he founds device (Iphone), you will see on Iphone screen that he is start charging...after that you can put it to electicity charging, with regular adapter and charge it for 1 hour and then turn it on and it will work :) That happens when battery lose her voltage (need to be 3,7V)...Otherwise if you PC, when you connect it does not show nothing, than you have some hardware failure and you need to take you Iphone to some mobile service to fix it..
Best Regards!
Sep 05, 2013 | Cell Phones
Pictures all switched to negative lastnight
If the whole screen is looking like a negative mode: go into setting/general/accessibility and turn off Invert Colors
May 05, 2013 | Apple iPhone 4S
Iphone starts up for 5 seconds then shuts off and wont charge
what charger are you using?
if usb
try wall charger as usb wont charge when in restore mode unless the phone is on
Nov 17, 2009 | Apple iPhone Smartphone
My husband was fooling around with my iphone and all of a sudden all of the icons increased in size. How do I get the screen back to regular size? Tapping it doesn't seem to work.
You use three fingers and tab twice on the screen, then go into settings and then general and zoom, turn the zoom off. This happened to my iphone yesterday.
Nov 16, 2009 | Apple iPhone 3G
My 1989 chevy camero, automatic, v8 305 engine, is acting funny. Brand new battery, water pump, brakes, tires, and trani mount. Has some wiring problems. Aparrently is wired backwards. It over heats alot....
CHECK YOUR CLUTCH COOLANT FAN IT SHOULD HAVE RESISTANCE WHEN YOU TURN IT WITH YOUR HAND.IF ITS LOOSE AND WOBBLEY.NEED REPLACING.THAT CAN CAUSE CAR TO OVERHEAT.ALSO IF YOU LIVE IN HOT CLIMATE.YOU NEED 50/50 ANTIFREEZE AND WATER.TOO MUCH WATER CAUSE ENGINE TO OVERHEAT.YOU NEED ANTIFREEZE MIXTURE TO RAISE BOILING POINT.TO HELP ENGINE COOL BETTER.NOW THE STARTING PROBLEMS.CLEAN BATTERY CABLES IF CORRODED.IF THEY ARE OLD BEEN ON CAR A WHILE REPLACE THEM.IF BATTERY CABLES IS GOOD. HAVE STARTER CHECKED REMOVE IT TAKE IT TO AUTO ZONE OR ADVANCE AUTO PARTS.SOUND LIKE A BAD STARTER HIT IT WITH HAMMER AND IT CRANK.
Sep 29, 2009 | 1989 Chevrolet Camaro
Car overheats, Fan wont turn on
coolant temperature sensor is bad
Sep 25, 2008 | 2000 Pontiac Grand Am GT
Apple iPhone Smartphone Logo
49 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
