Question about Car Audio & Video
I have a Kenwood KVT-512 headunit (the 7" flipout DVD player). I just recently installed it in my new car and since the installation I have noticed one small problem. I set the monitor settings so that the "angle" and "slide" are how I like them. They will then stay in this position for a good amount of time. Sometimes they will stay to this position/setting after turning the car on and off a couple times. However, after several (no specific number) times of turning the car off and then back on at a later point, when the monitor flips back out it resets itself to a very undesirable position so I then have to go back into the settings while driving and adjust the angle and slide all over again. Any ideas why?!
  • PoopX Apr 03, 2009
    Mine does the same thing pretty much, except the only thing that gets changed is the angle, the slide stays the same. But sometimes when i turn the car on and off some amount of times the angle will be readjusted and I have no idea why.
SOURCE: amplifier problem
chceck if its not over heating. If its very hot move it to the different place or install a fan
Posted on Aug 23, 2007
robotek
  • 1512 Answers
SOURCE: Password reset?
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Posted on Dec 14, 2007
SOURCE: kenwood kvt 911 dvd head unit
I have a question. Everything is working perfectly except for there is no picture on the TV nor DVD. It was working fine until the other day when I messed around with some wires seeing if any of them were loose. Any suggestions?
Posted on Mar 26, 2008
SOURCE: kenwood KVT-627 DVD. the
WHERE CAN I BYE A PACKET SOUND FOR KENWOOD KVT 627 THAT IS STOLED. I DONT HAVE THIS PACKET AND IT CAN`T TURNET ON. THNX
Posted on May 31, 2008
  • 13433 Answers
SOURCE: Daylight Saving Time will not set correctly
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Posted on Jun 10, 2008
KVT-512 Car DVD Player: Battery was disconnected ans car stereo locked out...
Sorry...KENWOOD codes are only available from the Main Dealer or a Radio Decoding Service
May 17, 2010 | Kenwood KVT-512 Car DVD Player
I need the site for kenwood kvt-512 update
try this I use this for getting user manual or leave them a question Good Luck!!!!
Techman
http://www.kenwood.ca/Support
May 14, 2010 | Kenwood KVT-512 Car DVD Player
My 5th generation ipod is reading on my kenwood kvt-512 but no music is playingits been updated to firmware version 2.5
This happened to me. What worked was turning off the ipod (not stand by mode). Turn it back on and plug it in, it should work.
Jan 26, 2010 | Kenwood KVT-512 Car DVD Player
Kenwood KVT-512 iphone compatibility
Just ignore the airplane mode prompt and if your wiring is correct everything should work.
With my BMW I had to connect both the solid blue (pwr ant) wire and the blue with white stripe (p conn) to the solid blue wire from the factory harness.
It isn't obvious that either of these are needed as the KVT-512 has it's own power supply but the way most factory power amps are installed the power from the KVT-512 is not used and the car manufacturers power amp needs to be turned on.
If you are listening to the radio the pwr ant wire will turn on the power amp, this didn't seem obvious because the BMW doesn't have a power antenna. And when you are using the DVD player or the iPod connection you need the P Conn wire to turn on the car power amp as the ant pwr is disabled because you are no longer using the radio and Kenwood assumes you will not need the antenna so no power to this lead.
Solder all three wires together and you should have sound all the time.
Jul 01, 2009 | Kenwood KVT-512 Car DVD Player
Kenwood KVT-512 subwoofer
put it in standby mode first.. then switch the rear av-out to sub.. then you can turn the sub on/off
Apr 04, 2009 | Kenwood KVT-512 Car DVD Player
Kenwood kvt512 code
forgot my code how can i reset it
Jan 27, 2009 | Kenwood KVT-512 Car DVD Player
Need installation instructions
do you still ned the intructions on how to install your kenwood kvt-512??
Nov 20, 2008 | Kenwood KVT-512 Car DVD Player
KVT-819 Kenwood, Region 1
NO IT HAS BEEN FORMATED TO READ USA REGION 1
Jan 28, 2008 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
