Question about Hyundai L90D+ 19" LCD Monitor
Theft Deterrence Mode
So ive had this model of monitor for yrs. ive never used this plugin option before, in fact, i never installed the imagetune software on this computer. so the scenario here is that i moved from my apartment into this other place and of course had to unplug the monitor. after i got to the next place, i plug it back in and this stupid message pops up. i dont understand how that could happen... and since i never installed the software, i CANT install it and use the plugin options (theyre kept greyed out...). so it seems to me ive literally NO WAY to get this stupid thing off my monitor... unless someone knows of a trick, like install a driver for a diff monitor, or knows the exact process to turn off in task manager... idk... but hyundai tech support is just 3 guys who trade shifts-- 2 of which know absolutely nothing-- and they basically just keep pushing things back. HELP!!
I also had this problem just this week so i took it in and it worked fine it worked fine till i got home with it ,so i called gateway and they wern't absulutlly no help then i was in 3 different chat rooms with gateway and the again were no help they were sending me to a pay site then canceled my session before i got the address or # and that will be the reason i wont buy gateway anymore,but i did get it back with out help from gateway;by unpluging the the display cord from display to PC about ten times each time it would stay on a little longer till it finally stayed running .hope this helps someone and goodluck KM
Posted on Aug 16, 2009
Ok, solved it! I plugged the monitor into another computer and got the same message. I then installed the imagetune software followed the prompts and then had to restart, when it restarted it went into countdown mode to enter the pin #(which you need and I had). As soon as I entered it tada!!! Put it back in my original computer figuring it would give me the countdown again which it didnt, I found that odd. One thing I should have done is disabled this feature while it was hooked up to the other computer because I still cant access that part on my computer.
Posted on Dec 14, 2008
SOURCE:
Tip
Gateway LCD monitor EZTUNE theft protection problem
You need to install EZTUNE but you need to go here first:
Portrait Displays' Theft Deterrence minimizes theft or unauthorized relocation of your display. Theft Deterrence does not prevent the display from being stolen, but hinders the operation of the display once it is removed from the 'Theft Deterrence enabled' host computer.
This site is provided for you to securely store your PIN in the event you should need to retrieve it at some point in the future.
Please select from the following options.
Change your PIN. https://pinreg.portrait.com/change_p...=dtune&OEM=gwy
Forgot your PIN? https://pinreg.portrait.com/remind_p...=dtune&OEM=gwy
GatewayShield™ Security Available
Protect your hardware using the EzTune™ Anti-Theft Software and reinforced lock slots. The slots, paired with a cable lock, physically anchor your display to a secure fixture. The software keeps the monitor secure using a unique PIN code. In the event the display is removed from the PC without the code, its full functionality is disabled.
on Apr 14, 2010 | Computers & Internet
Monitor message says "Theft Disable
The theft deterrence system can be disabled temporarily by unplugging the monitor's power cord. Then it will start the counter again. (The default is 60 minutes and is set in the EzTune software.) The software locks the monitor to one computer (the one running the EzTune software). To disable the theft deterrent message, enter EzTune and click on the Extras tab. Then select the Theft Deterrence section and enter the PIN. The PIN can be saved online and then you can request it if forgotten: https://pinreg.portrait.com/index.php?OEM=gwy&PRODUCT=dtune&ULANG=enu .
The EzTune software is available here: http://oem.portrait.com/dtune/gwy/enu/upgrade.html .
The user's guide and other documentation is available here: http://support.gateway.com/s/MONITOR/7005574R/7005574Rnv.shtml .
I hope this helps.
Mar 15, 2011 | Gateway FPD1975W 19" LCD Monitor
My lcd mode no HP L1750LCD a massage seems on my - Can donacchu1561 be sent back in a time machine to 2011?
Hi, you can solve your problem to follow these instructions.Open the HP Display Assistant.
  1. Click the Plug-ins tab.
  2. Click the Theft Deterrence button.
  3. Click the Disable Theft Deterrence button.
Good Luck
Feb 24, 2011 | HP L1750 LCD Monitor
Power went off and now my gateway monitor displays GatewayWhield theft Deterrence. I never set up a password how do I fix this problem. Connect the monitor to the pc you would think fixes it but no. Help
Disable GatewayShield Theft Deterrence
  1. Launch EzTune.
    View Picture
  2. In the EzTune window, click the Plug-ins tab, and then click Theft Deterrence.
    View Picture
  3. To deactivate theft deterrence, click Disable Theft.
    View Picture
  4. Type the PIN for the monitor in the appropriate field, and then click Accept.
    View Picture
  5. A screen confirms that theft deterrence is now disabled.
    View Picture
Dec 03, 2010 | Gateway FPD1785 Monitor
Theft disable menu pops up and won't go away and it keeps turning off my monitor
You need to install EZTUNE from Gateway, but you need to go here first:
User manual:
http://www.retrevo.com/support/Gateway-FPD1975W-Monitors-manual/id/1071ag416/t/2/
Apr 14, 2010 | Gateway FPD1975W 19" LCD Monitor
They say theft mode enable and doing like screensaver
"To resume normal operation of the monitor, connect it to the original system and use the HP Display Assistant Utility to disable theft deterrence (Option 1) or install the HP Display Assistant on the new system (Option 2)."
This happens when you move parts from one pc to another.
Cheers
Jun 20, 2009 | HP Computers & Internet
Theft Deterrance system
If you ever have this problem but cannot get to the 'extras' button, leave the computer on that (hopefully) already has the eztune software installed, pull the power on the monitor (the cord, not just press the power button) and then plug it back it...it should unlock automatically. It ticks me off that I just got off the phone with gateway tech support and they wouldnt tell me that because my monitor is 'out of warranty'...purchased 4/8/08 and problem today 7/15/09...bums. Anyway, they offered to fix for a fee. I got it fixed.
Sep 29, 2008 | Gateway FPD1975W 19" LCD Monitor
Anti theft mode
If L90D you need a PIN number to unlock it.
Connect to your original computer and run Plug-ins - Theft deterrence to enter or reset PIN - or go to web site via software - see below
http://www.hyundaiq.com/Eng/DownLoad/MonitorDri/View.asp?page=1&SchSel=&SchStr=&idx=87&V_nm=30
Under the ‘Plug-ins’ menu is the ‘Theft Deterrence’ option – a more accurate term than the ‘Anti-Theft’ sticker on the monitor itself. Why? Well anyone can physically steal this monitor from me. There is no Bond-like lethal gadget that would bring certain death to a would be thief. Rather, the theft deterrent is a PIN-based procedure that hinders the operation of the display once it has been removed from the host computer. Briefly, you register and store a PIN to a secure web site, then set a countdown timer. If the power and display cables have been removed and the monitor has been attached to a different computer, the timer counts down. If the correct PIN is not entered using ImageTune, the monitor will enter theft mode and display a large warning message. It doesn’t prevent the monitor from being swiped, but at least there's some satisfaction in knowing the thief can’t use it.
software called ImageTune that replaces the usual on-screen display (OSD) tools, arrives on an included CD. With it, you can adjust basic monitor settings such as brightness and contrast with a mouse instead of with the small, squishy membrane buttons under the bezel.
Apr 03, 2008 | Hyundai L90D+ 19" LCD Monitor
Open Questions:
Hyundai L90D+ 19" LCD Monitor Logo
740 people viewed this question
Top Hyundai Computers & Internet Experts
 Mike M
Mike M
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
