Question about Sunbeam SBM6500W Microwave Oven
Door not opening
I have a sunbeam microwave which was working good till today afternoon.now when i checked the door is not opening.all other things are working n perfect
  • Sunbeam Master
  • 9,098 Answers
What usually breaks is the door open lever.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
To order parts, refer to the Sunbeam number in your manual.
Posted on Aug 19, 2008
  • John Apr 02, 2015
    The link to the info mentioned above is broken.
The keypad on my sharp microwave model R-953 (SL) M is not working. Anything I press on the keypad does not respond, but the light comes up whenever I open the door. It works well till 2days ago.
it could be any number of things . usually taking it into a repair shop and having it checked is only way to know for sure and get estimated repair cost .Mine was the door switch and cost 50.00 for them to repair .
Sep 20, 2015 | Sharp Microwave Ovens
Why my door on my frigidaire microwave model GLMB209 won't open?
Good Afternoon Friend,
I understand that the door will not open on your Frigidaire microwave, model# GLMB209. Specifically, when dealing with your microwave, I suggest contacting your local authorized technician. They have been trained on your appliance and will be able to get the door open and repaired, without causing damage to you, your family, or your home. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Electrolux E30MO65GSS Convection Microwave...
Cannot open door or frigidaire microwave
I understand that you are unable to open the door on your Frigidaire microwave, model# FMV156DC. Due to this being a microwave, I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance and should be able to get the door open without any damage to the appliance, or harm to you or your home. Hope this is helpful.
-Best Regards-
WP
Jun 11, 2014 | Frigidaire FMV156DC Microwave Oven
Microwave quit when door was open
yes,unplug the unit,take the screws out of the side and back lift the cabinet up and off and you will see a fuse right on top replace it.hope this helps
May 19, 2014 | Sunbeam Microwave Ovens
I have sunbeam .9cuft microwave model:SGB8901 may be a year old. Now as soon as I plug in, the microwave starts running. It runs as long as the door is closed. When i enter the timer it wont work. It...
follow this steps and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Oct 23, 2013 | Sunbeam Microwave Ovens
Sunbeam microwave model SGB8901 will not stop running.....
I had the same problem, but didn't have the box anymore. The store let me exchange it for another one but that one is doing the same thing too.
May 24, 2010 | Microwave Ovens
My Sunbeam Over the range microvawe will self start!
You need to get it looked at professionally. Faulty microwaves are not really the thing that you should be repairing at home. They can be lethal. Find a local repair shop and get a quote for repair.
Mar 11, 2010 | Sunbeam Microwave Ovens
Sunbeam SMW5500 micro/convection oven shorted out when opening door
You are decribing a typical Door Safety Switch problem. The Door Safety Switches has Failed.The Door Safety Switch is designed to shut down the Micro in the event the Micro is still cooking when the door is being opened. The first "Click" of the switch cuts off the "Cook". If it does not cut off the "Cook", the second "Click" blows the power. Otherwise it would "Cook" with the door open, and I need not to tell you how DANGEROUS that could be. It first Tripped the Circuit Breaker which supplies power to the Microwave. After Re-Setting the Breaker the same thing happened except this time the Micro is DEAD- not even a light working. Yes, there is a line FUSE inside the Micro. You however need to address the Door Switch SHORT before replacing the fuse. If not, it will just Blow The Fuse Again, and Again, until the Short is corrected.
Call around, ask How much to replace a Door Safety Switch.
Good Luck!
Feb 15, 2008 | Microwave Ovens
Sunbeam Microwave stopped working suddenly
Here's the overview on fuse blows: If the fuse blows as soon as you plug the oven in the wall, or when you open the door, the problem is likely with the door switches. If the fuse blows as soon as you hit START, then it's likely that you have a shorted high-voltage capacitor. If the fuse blows a few seconds after you hit START, then it's likely that you have an overheating / shorting high-voltage transformer. If you or a friend decide to work on it, we have *critical* safety, disassembly, troubleshooting info, door switch info, etc. at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Mar 30, 2007 | Sunbeam SBM6500W Microwave Oven
Sunbeam SBM6500W Microwave Oven Logo
177 people viewed this question
Top Sunbeam Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sunbeam Microwave Oven Expert? Answer questions, earn points and help others
