Question about Refrigerators
I have a Samsung RB215LASH refigerator/freezer that I want to use as a Keg Beer dispenser I know I can drill a hole through the door but due to the area it is goin into I would like to drill a hole in either the side or the top so I can route the faucet and the CO2 canister outside of the refrigeratior is there a sfe spot to do this
Apparently there is no solution, I have been told that it is not possible to drill through the side or the top of this model with out ruining it so I give up
Posted on Aug 20, 2008
I have water in the bottom of my Beverage air kegerator
Water in the bottom of Kegerator - Dispense Forum ' Discuss Keg ...
www.micromatic.com/...kegerator.../kegerators-kegerator.../5907-water-i...
Jul 18, 2009 - I have a Beverage Air 2 with front ventilating compressor. When I .....Also I do refrain from opening my kegerator door between kegs. I have ... need some help with BM23 - Dispense Forum ' Discuss Keg Beer ...
Aug 1, 2013
New To Me Bev Air BM23
Jul 16, 2012
Beverage-air condenser / thermo
Dec 31, 2009
Beverage Air BM23 Door Not Sealing
Aug 3, 2009
More results from www.micromatic.com
Kegerator leaking water inside - Home Brew Forums
Dec 28, 2015 | Beverage Air Refrigeration DD58C-1-B - 59...
Drill side keg
should not b any on either side,remember to insulate the attached beer valves
Nov 23, 2013 | Frigidaire FRT17G4B Top Freezer...
A while back I purchased a Samsung model RB 215 Refirgerator /Freezer. Works well except that the ice in the bin seems to clump or stick together after it has been sitting for a while. The freezer door is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Defrost is running too long and warming the freezer up too much...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | Samsung RB215LASH
Beer tap
Good day,
If it has the condensor coil mounted on the back of the machine.
(black coil) then yes, VERY DANGEROUS. Refrigeration lines run at an angle from the bottom back of the machine at an angle and terminate at the bottom of the freezer door.
This applies to both sides. Hit one of those and your finished.
Jul 21, 2010 | Frigidaire FRT17G4B Top Freezer...
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Making Modifications to my Hoover Orchid Collection 480L fridge
if it is a fridge and not a fridge freezer, then there should be no problem in drilling a hole thro the side
Aug 21, 2008 | Hoover Refrigerators
I'm using a kenmore refrigerator as a kegerator and I need to know if there is anything I should be aware of on the side of the fridge walls as I have to drill a hole into it to attach the hose from the...
Any lines that run through the cabinet should go up the back or and/or around the door. I would carefully cut a hole in the liner and pull the insulation out in small peices just to make sure.
Apr 24, 2008 | Refrigerators
Danby Beer Keg dispenser fridge.
Draught (or Draft) beer is almost always un-pasteurized and therefore is more fragile. It should be consumed after being "tapped", and is generally truer to the flavors of the ingredients as pasteurization exposes the beer to heat and changes the flavor profile. Always use brewery approved beer line if you want to have foam free fresh tasting beer. Serving it through a plastic tube from the hardware or discount store or the plain vinyl tubing in your beer tap system you will wind up with a foamy, off tasting beer. Real draught beer is not pasteurized. It must be kept refrigerated between 35F. and 44F. A beer will become wild, turn sour and cloudy in a day or two. Below 44F. a keg of draught beer should last 20-30 days before it loses it's fresh brewery taste and aroma. Craft beers (micro brews) tend to have a shorter shelf life and you should contact the brewery for their recommendations. Why does my beer foam up? The 3 most often causes of beer foaming up are: The temperature of the beer keg The balance of the draught beer system pressures The cleanliness of the draught beer system I would suggest that you clean or replace the beer transport tube...
Aug 11, 2007 | Danby DKC645BLS Compact Beverage Cooler
Danby Keg Cooler foam problem
If you are getting foam then finally poors fine you have a temperature problem. If you are getting constant foam then you are probably looking at a pressure problem. First of all make sure that you let your keg sit for at least 4 hours and get down to 38 degrees before you tap the keg. Also ensure that your pressure is set to at least what the pressure is in the keg (generally 13 psi). If you can, try to ask the beer manufactures (if you use a microbrewery) what pressure to set it at. One brew master told me to start at 15 psi and adjust from there.
If you still get foam and you can guarantee that the temperature is correct then you are getting some agitation from something else. Double check all your washers and even check your stop valve on the CO2 line to the coupler. Sometimes the lines are not the correct length or even the correct diameter, when the beer is forced through the line if it starts out thin and then expands or vice versa that gives beer a chance to get agitated and cause foam.
Finally the equipment that is used on these systems are generally not that great. I had a Danby Chill'n Tap and replaced the coupler and the tap and all the lines and that solved my issues, even though my problem was probably a cracked valve for the < $80 it cost me to replace everything it wasn't worth my time to figure out exactly what was wrong with it.
Jul 26, 2007 | Danby DKC646BLS Full Size / Pony Beer Keg...
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
