EPSON DX7400 will not print new ink cartridges fitted
EPSON DX7400 will not pprint after new ink cartridges being fitted
  • Anonymous Aug 21, 2008
    Yes mine also very temperamental - and now just 4 months old - has vertical lines when printing. I have done all the correct procedures for maintenance, cleaning heads etc., and am using original cartridges. Not impressed with this model. Have been an epson printer user for many years - but this model has problems it seems.
rizla
  • 1463 Answers
SOURCE: Fitting replacement ink cartridge
this may help you to change the ink http://esupport.epson-europe.com/ViewArticle.aspx?lng=en-GB&kbid=311830&data=wsMoc1iChVGcisk9ncQeIGFU002FHBhpsVxk
good luck
riz.
Posted on Nov 20, 2007
SOURCE: EPSON DX7400 ALL IN ONE PRINTER INK CHANGE
ok just done it - i always have to look it up too!
find the default printer from your control panel
click right click and pick properties
then hit printing preferences
then click tab marked maintenance
and follow the ink cartridge replacement instruction
printer leads you through no probs - hope this helps
Posted on Apr 25, 2009
SOURCE: Epson cx8400 Black Ink Cartridge doesn't work on Printing
I put alcohol in inside the printer, where you insert the ink cartruges then cleaned with paper towl and it works for me.....
Posted on Oct 14, 2009
Remag1234
  • 387 Answers
SOURCE: how do I change the ink cartridge on a Epson
Directions are on the Inside the cover and in the manual, you can also find them at the Epson website.
Posted on Dec 29, 2009
jimmy_k8
  • 242 Answers
SOURCE: how do i change the ink cartridges on my epson
It is as simple as below.
Open up the hood of your printer.
Switch on the printer.
The cartridge will come in the centre to remove.
Press at the back of the cartridge and slowly remove it.
While installing the new one follow the reverse process.
Thanks
Jimmy
Posted on Apr 29, 2010
Epson stylus dx7400 will not work with ciss - lights keep flashing
this mean that the waste pads full and you need software to reset the printer
Feb 11, 2013 | Epson Stylus Office Equipment & Supplies
HOW CAN I CHANGE A INK CARTRIDGE IN MY EPSON DX7400 THAT IS NOT EMPTY
Connect the power cord, rise the cover that accesses to the print-carriage, turn On the printer; when the print-carriage move to left, unplug the power cord then, manually, move the carriage until the right area where you can open the cartridges-cover and change the cartridge you need.
May 21, 2010 | Epson Office Equipment & Supplies
Thinkjet ink cartridges rejected by epson dx7400 - no matter how many times I try using my chip resetter, which normally works and lets the printer use the remaining ink in the cartridge.
The Epson 69 cartridges have two chips. One on the exterior of the cartridge and one just underneath. You can reset the outer chip before the cartridge is less than 25% full. If it drops below this amount of ink before being reset, the internal chip kills the outer chip. You will need to get a new cartridge or a new chip if this happens.
Dec 19, 2009 | Office Equipment & Supplies
Mar 25, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson dx7400 printing green
one of your people advised me that it was most likley a bad cartridge i changed it and it worked ,thanks
Feb 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson DX7400 only printing Blue + Black
I'm sorry you have received no response on this , it's probably because you have posted it in the C86 printer group rather than the DX7400 group. I presume you have now solved this problem. If not, please re-open it (in the DX7400 group) for help.
Dec 15, 2008 | Epson Stylus C86 InkJet Printer
SSC service Utility for Epson DX7400
I have replaced the cartridges , the chips have worked , the printer goes through the cycle but does not print but the ink is going down
Sep 22, 2008 | Epson Stylus C86 InkJet Printer
Printing in black & white when color cartridge ran out
One of the possible reason why you can't print black in white because Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. More than that Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head.
Apr 15, 2008 | Epson Stylus Photo 1280 InkJet Printer
412 people viewed this question
jasbo
jasbo
