Question about LG CHOCOLATE VX8500 Cellular Phone
Won't turn on
My new chocolate won't turn on when it's off the wall charger, and when i un plug it it turns off. it won't stay on for more than five minutes even when it's on the charger, even though it says the charge is complete.
    Champion:
  • 221 Answers
Your battery is dead. get a new battery
Posted on Aug 25, 2008
SOURCE:
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
My PS3 headset won't charge it stays lit for 3
If there was no change using a new charger, I would suspect the battery is shot
Apr 23, 2013 | Radio Communications
Galaxy Samsung tab 10.1 won't turn on
you had to plug it in the charger for a while and then you hel the power button for more than a minute
if it not work hold power button and volume up for 20 sec.
Mar 22, 2013 | Tablets & eReaders
My new luggie scooter won't charge
I have to ask, did you ever figure out what the issue was? My mother's scooter is having the same issue.
Feb 26, 2013 | Free Rider 2 Freerider Luggie Compact...
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
I have a pair of sp10 and having trouble charging them and the batteries are new and when i put them in the charger i have to turn them on for the chargeing light to come on is this normal or are the...
You do not mention if you are using a wall plug charger, or a drop-in charger. We will give troubleshooting tips for both. To answer your question: If the light comes on and stays on, on the charger your charger is good. You have a radio or battery problem.
Wall Charger:
The light on the HTN8232 wall charger should come on and stay on when plugged into the radio, with the radio turned off. The fact the light comes on when the radio is turned on indicates your batteries are either no good, too low to charge, or you have a battery contact problem.
Solutions: 1) Clean your battery contacts with a pencil eraser.
2) Be certain the batteries are installed correctly.
3) Check your battery date code (three digit number on back of battery above the stop sign. First number is year, next two numbers are the week of the year. Batteries last about 2 years.)
4) Check to see your new batteries are NiCd batteries. The wall charger method is not compatible with NiMH batteries.
5) Try a charged battery from another radio and see if the charger light comes on and stays on with a different battery.
Drop-In Charger:
If you are using a drop-in charger, you would be using the above listed HTN8232 wall plug charger plugged into the tray. Here are some possible solutions for the drop-in charger:
1) Clean the exterior battery contacts with a pencil eraser.
2) Check to see if the wall charger will work when plugged directly into the radio.
3) If the charge capability of the radio seems compromised, take the battery out of the radio and charge it alone in the drop-in charger.
NOTE: Do not use the PTT if you are turn on the radio when plugged into the charger. This will burn out components in your radio.
The SP10 radio is known to be a repairable radio. (Generally around $69 flat rate.)
Best regards.
Dec 05, 2009 | Motorola Walkie Talkie 2-Way Radio
It keeps turning off, I have tried my friends power cord incase that was the problem but even with her cord it turns off, and just before that says that I need to plug the charger in even though it is...
ok sounds like your battery has gone bad.
try this test: remove battery plug computer into the wall.
boot computer if it boots up and stays on you will need a new battery.
Nov 13, 2009 | Compaq Presario R3000 Notebook
Sidekick lx2009 wont turn on & when charging it turns on & OFF!
try plugging it in to the computer or try a new battery
Sep 01, 2009 | Sharp Sidekick LX Smartphone
Charged up but want stay on
If the phone dies when it's not connected to the charger, your best bet is to buy a new battery for the phone.
Apr 04, 2009 | LG CHOCOLATE VX8500 Cellular Phone
LG CHOCOLATE VX8500 Cellular Phone Logo
69 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
