Question about HP Photosmart s20 Film Scanner
Streaks on prints
My S-20 prints have multiple lines across the saved images. Color prints (also computer images) have these lines too but the colors are smudged. I've cleaned the mirrors and blown out the interior with air. I've also cleaned the lamp inside to ensure there are no dust particles. The symptoms remain the same. What now?
  • Anonymous Jan 27, 2009
    When I scan my pictures...I have the same problem. Colors are all streaked up...how can I fix this problem? This is not a printing problem...it is a scan problem. After scanning you can see streaks across the picture.
  • 490 Answers
Lines/streaks at the same location indicate either a speck of dust stuck on the glass or the glass may be scratched.
S. Mohan
Posted on Jan 04, 2009
SOURCE:
How do I fix my Samsung Multi-function laser printer which has started to print smudged pages.
try to stop the sheet just before it enters the fuser and see if the marks are on the paper already. if not then it has to be the fuser if they are them you have another issue.
Jan 15, 2015 | Samsung CLX-3175FN Color Laser All-in-One...
Unwanted colour lines on prints
It may be time for a new printer. Colored lines are often an indicator that the printhead is worn out. Dark smudges on the back of the print are likely just a need for cleaning the inside.
Sep 02, 2014 | DSC GESTETNER - DSc38u Color Printer
Smudge and missing ink
remove all image units. clean the class where the laser writes on the drum with machine no laser. so clean. smudge what color replace the that color image unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 07, 2014 | Konica Minolta Magicolor 1600W Printer
HP M375 prints out of alignment
Are you using 3rd party consumables?
even if you are not I would recommend you replace all 4 imaging units ( toners) and allow the machine to perform the calibrations before using,
also I would clean the image belt calibration sensors ( located along top edge of ITB ) as they often get coated with toner particles,
also - is there a grinding noise - this could indicate a poor fuser- which if the vibrations are strong enough will definatley alter the printed image
p.s. 3rd party toners arent cheaper, the damage they do is unseen by the user until its too late by which point all the savings you made and more will be needed to repair/replace.
Mar 05, 2014 | HP LaserJet Pro 300 color MFP M375 MFC /...
Color smudging
Hi, either the drum or belt or both become defective.
Dec 16, 2013 | Samsung CLP 300 Laser Printer
Yellow deposit
Remove the Yellow Drum unit, Check the drum for any toner. The drums should be clean and I believe a Green color. If you see any toner on the yellow unit replace the unit. Some models have a charge cleaner built into the image units, if that is the case with yours you will see a light blue knob on the front of the unit. Pull this knob in and out about 5 times to clean the units charger this may correct the problem without replacing the yellow image unit.
Mar 09, 2010 | Konica Minolta Magicolor 5670EN Color...
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Multiple vertical color lines,i take the picture,how can i send you this photo?
There are two ways you can do this.
1. post the image to a site like photo bucket or flicker and post the link here
2. next to the You Tube on the top of the post reply window click the image. This will open a window. Browse to where you have the image saved and click it. This will insert the image to your reply.
Jun 02, 2009 | Acer 22" X223w LCD Monitor
Black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Oct 08, 2008 | Samsung CLP 300 Laser Printer
HP Photosmart s20 Film Scanner Logo
208 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
