Question about Zyxel Computers & Internet
Router not working
My router is not working no other device can connect to it,
it use to work a whie back but now nothing can connect to it,
I have tried restting, tried to log on to 192.168.1.1 but no
i have done ipconfig
your my last chance something must be there as i can pick it up on my laptop but cannot connect to internet or anyting but it there on my sony vaio with a yellow ! on it
if no can help may just chuck it and get a new one lol
i have spent to many hours on it
  • 2 more comments
  • kewns Aug 19, 2008
    just resetit the dhcp has been disabled
    hello i have reset the route loads of time still cant get nothing 192.1681.1
    regards,
    stephen
    C:\Documents and Settings\kewns>ping 192.168.1.1
    Pinging 192.168.1.1 with 32 bytes of data:
    Reply from 192.168.1.1: bytes=32 time=42ms TTL=60
    Reply from 192.168.1.1: bytes=32 time=12ms TTL=60
    Reply from 192.168.1.1: bytes=32 time=15ms TTL=60
    Reply from 192.168.1.1: bytes=32 time=10ms TTL=60
    Ping statistics for 192.168.1.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times in milli-seconds:
    Minimum = 10ms, Maximum = 42ms, Average = 19ms
    this is the result from a ping test
    hello if your still there can you tell me what you mean by
    cheers
  • kewns Aug 20, 2008
    Hello I am having a problem with my router, right here goes
    Been having problem with router it works with the pc but i cannot connect anything to it,
    I connect the router via cable modem, I do believe this is a gateway error or dchp is not installed
    But when I have reset my router like Dave said but i had left my laptop on and when it came back my laptop connected to the router and everything worked i even mange to go online to 192.168.1.1
    But when i tried connecting to my old pc it did not work saying something about limited or no connectivity. So basically I can use my route with one thing not all
    I am getting really mad now lol
    Please some help me as all I can think of now it must be the pc settings as I can not log 192.168.1.1
    On my pc at all when it is connected to internet
    Regards,
    Stephen
  • 426 Answers
Just resetit the dhcp has been disabled
Posted on Aug 19, 2008
My belkin router n3000 stopped working out of the blue , internet connection shows up but no internet
Try recycling the router by unplugging it then after 20 seconds plug it back in. See if you can stay connected. If not, unplug the modem and the router, then plug the modem in and let it cycle up for about a minute or two, then plug the router in and let it cycle up.
If you turn your computer and router off at night, then when you turn them back on, if the router boots up before the modem, it will have connection problems. A power outage in the house causes the same thing if the router cycles up before the modem.
Jun 08, 2012 | Belkin Wireless Surf Router (F7D2301)
Modem will connect to router but not to computer
This is mostly because it has not adapted to the changes when using another device aside from the router, especially a router. What I have done with internet modems is when you are removing a router, or if you are installing a router is allow that modem to be shut down for about 10 - 20 minutes before you use other devices it does not recognize right away.
May 05, 2010 | Toshiba PCX2600 (c40054) Modem
Unable to connect to Wireless Router
Hi, There have been some compatibility issues with certain wireless cards. First try (for a short time) to remove any encryption you have set up on your wireless system. If the laptop logs on now, this is the problem I've confronted a few times. Try the different types of encryption that your router provides. If that doesn't work, I'd send the Netgear back (if its under warranty) explaining the problem. If there is no help there, maybe you should get the same model of router as next door. Hope this helps
Mar 25, 2010 | Toshiba Satellite L555D-S7910 Notebook
Wireless connectivity suddenly lost
Have you tried power cycling the router and the modem? if not:
1. Turn off your modem and router by unplugging the power cord at the back of the devices.
2. Disconnect the Ethernet cable from the modem to the router vice versa
3. After a minute, replug the power cord at the back of your modem then reconnect the ethernet cable at the back of the modem as well.
4. After a minute, replug the power cord and the ethernet cable at the back of your router.
5. Try to test the connection.
Warning: You can reset the router if you know that you can reconfigure it back to connect to the internet. If you don't know how to set the router back to connect to the internet, it would be ok to you to not to do step 6.
6. If it didn't work, You can reset the modem. Press the reset button at the back of your router while it's turned on, wait for 15 seconds after that, unplug the power cord at the back of the router while the reset button is still pressed, wait for 15 seconds after that, replug the power cord at the back of your router while the reset button is still pressed, wait for 15 seconds again then release the reset button after 15 seconds.
7. Reconfigure your router's settings to communicate to your modem. ( I don't know if you have cable internet connection, but if so, you can just clone the mac address of your modem to connect to the server, if you are using DSL if it's asking for a username and passowrd, just use the PPPoE type of configuration in your router)
8. If it failed, try to update the firmware of your router.
Jan 14, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Linksys Wireless Router Stopped working
Try holding the reset button for 10 seconds, while holding the reset button in, unplug it for 10 seconds, plug it back in, but don't let go of the reset button for another 10 seconds. Respond with any results.
Jan 15, 2009 | Linksys Wireless-G WRT54G Router
Internet connection problem Zhone 6211
After a while the net stops working then when i open the router page for the settings it starts back working
Aug 08, 2008 | Paradyne 6211 ADSL2+ Router (6211I1200)
Connecting desktop and laptop to a wireless router
I have the same problem. Startign this morning, when I connect modem directly to desktop, it works. But when I connect modem to this router and then connect to desktop, nothings works.
again - if connect modem back to desktop directly, then it works!.
what is the issue.....? not able to figure it out.
I did reset, change router IP etc etc everything nothing resolves the core issue!
Jul 19, 2008 | Linksys Wireless-G Broadband Router
NOT WORKING AFTER POWER OUTAGE.
are u getting all the lights on the router?if yes then connect the router with modem n if its wireless then turn off all three devices
then turn modem on first n wait till the lights on the modem get settelled,then turn the router back on n the computer,n check whether the computer is picking the wireless or not,if yes try the
internet.
Apr 20, 2008 | D-Link DI 514 Wireless Router (DI-514)
Linksys WRT54GX2 constantly disconnects
I just upgraded from firmware version 1.01.14 to 1.01.22 and I have the same problem, the router just keeps resetting itself. I think the solution is to go back to the old firmware, but I haven't been able to find a copy yet, Once I find firmware version 1.01.14 for the WRT54GX2 router. I will let you know if this is the solution... :)
WRT54GX2
Mar 08, 2008 | Linksys Wireless-G WRT54GX Router...
Router lights not coming on at all?!!!
could be a faulty transformer,,,,is the transformer stone cold or warm to the touch? i would exchenge for another
Jun 15, 2007 | Linksys A+G WRT55AG Wireless Router
Computers & Internet Logo
161 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
