Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca converter box
My converter box fell off the tv set. now i can't get my tv to work. I can't find the instruction manual on how to reprogram my tv to the converter box . the model dta800b please help.
  • dominowms Aug 23, 2008
    cable connector broke off
Glue it back
!!!!POOP!!!!! hehehehehehehe hahaha
Posted on Aug 23, 2008
I have a RCA converter box and switched to a new TV and can't find the book so I need all the program codes for my RCA converter box to all Sanyo TV sets to reprogram it accordingly
go to this place and download the codes and instruction manual or www. or
God bless you
May 25, 2012 | Sanyo Televison & Video
I lost my remote for my rca converter box this remote works with my tv but wont on the converter box. Is there a code i need to make it work? or do i need another remote?
I can help you reprogram your RCA RCR311B for all your converter box.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Entering the codes you have looked up for your Orion TV on this remote's device code list.
I hope that helps.
Dec 30, 2009 | RCA RCR311B Remote Control
Programming RCA converter box remote control with Phil/Mag TV---
Good day,
You should have the instruction guide. If not look below. It's there but look closely for the guide itself and how to increase it's size to readable.
Check on the back of the TV to see if there is a 3 and 4 setting, If so, set to 3.
With nothing connected to the tv, and using the tv's remote, scan for channels. It should come up with only channel 3.
Then using the remote with advanced options, set the the input to either antenna or auto.
Connect the antenna cable to input on the converter box. Using the supplied cable connect the output from the converter box to
the TV. Turn the TV on first, followed by the converter box.
Then follow the instructions.
Not really easy so you'll have to fight your way thru it.
Finding the right setting for the antenna will probably take the most time, requiring a station scan after each adjustment.
Dec 28, 2009 | RCA Televison & Video
I have an RCA converter box hooked up to an RCA TV and a Sanyo VCR. The TV and VCR are set on Channel 3. The converter box is set on Channel 4 and the TV is also switched to CH 4 when viewing digital...
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Feb 27, 2009 | RCA Televison & Video
Will an RCA Digital Convertor work on Durabrands model #1304.?.
Hello chlpepr2,
Yes it should work, connect the RCA video out (yellow connector DTV Converter) to the RCA video in (yellow connector TV set). Then connect the RCA Audio out (Red-Right White-Left DTV converter) to the RCA audio in (Red-Right White-Left TV set).
Then setup your converter box according to the manufacture's instructions.
I hope this helps,
Thank you,
Jan 20, 2009 | Televison & Video
Want to continue to record on my VCR after digital hookup
You have to use the RCA plugs on the back of the converter box and the tv (red,yellow and white). Or you can attach the antenna wire to box and then attach the wire that comes with the converter that is listed as to the tv and instead attach it to the antenna in on the vcr. The converter box will determine which channel your vcr will get a singal to record from. Your VCR for every program will be set to channel 3 or 4 (depending on what your converter box is set to broadcast on). Make sure the power saver on the converter box is turned off as if you want to record a program in say 4 hours, if the converter box turns off in 2, your vcr will have nothing to record.
I ran seperate coaxible cable to the tv from vcr and unplug the tv converter box everytime I want to watch the vcr. You can also use the RCA cord to send the signal from the vcr to the tv and use the input signal to watch your recorded programs. I had static showing up everytime I played it through the second converter box thus I solved it by running a seperate coax line. I don't know if you will have this problem, just wanted you to be aware.
Jan 12, 2009 | Insignia Digital-to-Analog Converter for...
New Rca DTV converter / panasonic tv trying to get remote to work
You must set the code to conect your tv to your remote. The instructions are in your manual with a list of codes.
Nov 25, 2008 | Televison & Video
Remote codes for RCA Digital TV Converter Box (DTA800B1)
I was just looking for them and then found my manual and felt bad for you guys so I scanned it and uploaded it to photobucket ^^ please feel free to save the remote codes but you may have to zoom in alot to see them ^^
Sep 16, 2008 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
159 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
