Question about Cell Phones
Iphone 3g error 13 - Cell Phones
  • 7 more comments
  • Anonymous Aug 24, 2008
    i also get error 13
  • Anonymous Aug 26, 2008
    me too
  • Anonymous Aug 29, 2008
    same here
  • Anonymous Sep 12, 2008
    same here
  • Anonymous Dec 19, 2008
    I am tryibg to Restore it but its getting an error (13).
  • Anonymous Jan 27, 2009
    i have the same problem
  • jmnicasio Feb 18, 2009
    restoring occurs for about 1 minute then it goes error 13 or error 1603. Please help
  • Anonymous Feb 26, 2009
    i tried it but didnt help
  • Anonymous Mar 01, 2009
    what useless help just to fill html pages.,, thid doesnt work.
Hi friend:
Don´t use front USB hub from computer.
Try rear USB ports.
If you are using laptop, try on diferent computer.
Regards
Posted on Jul 11, 2009
    New Friend:
I had this problem - if you tried a different cable and usb port and still have this error try this.
Step 1. close out itunes and disconnect your phone
Step 2. turn your phone completely off
Step 3. relaunch itunes
Step 4. plug in the usb end into your computer, but do not connect your iphone yet
Step 5: This is the somewhat tricky part....hold down the round circle home button while you plug in your iphone.
This is suppose to bypass any software currently on the phone that is corrupt and do a true fresh install. Of course you probably already know that all information will be lost from your phone - so hopefully you backed up before the crash.
Good luck
Posted on Dec 15, 2009
The problem is in cable, i am sure.
there are many inductions arround and cable doesnt work propertly.
I try this many times and i make circles from kable and put iphone so much near to computer that cable works.
So, there are both ways to solve it.
1 - better cable
2 - make circle from kabel
Sorry for my english, hope everybody understand
Posted on Aug 19, 2009
    New Friend:
I can restore with success 3.1.3, but there is an error 13 when i try to restore 4.0, is it still caused by bad cable I try 2 orginal cabels...
Posted on Apr 11, 2010
I moved from using front usb's to rear to fix the 2003 error. I think the iphone needs to utilize optimum power via the cable & the rear usb's use 75% of the given power to a pc whereas the front usb's use 25% of the given power. I hope that helps :)
Posted on Feb 27, 2012
    New Friend:
Hi, , can someone help me with unknown error 2003? my iphone 3g 3.1.3 is stuck in its recovery mode, . now whenever im trying to restore it again, the error kept on flashing out.
Posted on Jun 28, 2010
Restart your computer or use a official apple USB cable to connect your iphone and try it again
Posted on Sep 13, 2008
3 Suggested Answers
SOURCE:
SOURCE: iPhone 3G Error 0xE8000001
I just had this problem and it turned out to be... It didn't like my iPod cable. Switched to the iPhone cable and it worked.
Seems to be an iPhone 2.0 prob, or 3g prob, since I was using the iPod cable to sync my old iPhone just fine.
Posted on Aug 07, 2008
sknerdish
  • 53 Answers
SOURCE: iPhone 3G Unknown Error Occurred 6
try restoring to backup
Posted on Feb 18, 2009
Error 1015 me aparece y no puedo restaurar
Hola, el error 1015 sucede cuando tienes en un iPhone 3G con el baseband 6.15 (baseband de iPad), prueba restaurar el iPhone con un firmware customizado sin baseband (utiliza redsnow para crear el firmware customizado). Saludos
Aug 09, 2013 | Apple iPhone 3G
Hello sir, i am using apple iphone 3g i am getting internet connection autometically so i am loosing money in the left corner of the phone letter E is always visible i wants to disconnect the internet pls...
1.Turn on your local Wifi either home or how so its temporaily disabled the 'E' Edge connection provided by your carrier provider
2.After the Wifi is connected
3.Open safari browser on your iphone
4.Type in the address bar www.iphonenodata.com
5.Scroll down to the end until you see a Disable EDGE/3G
6.Click on Disable EDGE/3G
7.You'll see a popup asking you to install a Profile
8.Install the profile and after the installation is done
9.Restart the iphone
10.Turn off the Wifi
11.Wait for 'E' to appear on the statusbar (Edge)
12.Try surfing the internet
13.If you get an error saying "Could not activate cellular data network"
14.You have successfully disabled the edge it will longer take your money if the phone is idle
Mar 27, 2011 | Apple iPhone 3G
While restoring my iphone 3G with software3.12 error 1601 help?
read your catalog carefully if not go to a phone repairing shop
Mar 27, 2010 | Apple iPhone 3G
The glass screen of my iphone is shattered - is it repairable or do I need to buy a new one? Phone works fine
It is repairable. I recommend having it done professionally. You can do it yourself but I have seen multiple issues with people messing up their iphones doing that,
Check out the following link for more information on getting it repaired.
Cracked 3G Iphone Screen Repair
Dec 29, 2009 | Apple iPhone 3G
When I was trying to resore my Iphone it says
Hi ,after searching all over the internet and posting on every forum possible i didn`t find a real answer well it seems to be a rare problem but critical. Don`t get confused by this noobs that they just post "to be in business" ,here are some tips that confused me as hell like changing the motherboard of my iphone and battery and i saw very much of you did the same way after tryed all my tips here and no result... and that are...restoring in dfu mode or recovery mode, tryed all versions of itunes,hard reset,adding the source 74.208.10.249 gs.apple.com in the file C:\WINDOWS\system32\drivers\etc\hosts,reinstall windows xp ,vista, 7 eaven on iMac,tryed with iReb NOTHING WORKED...but don`t panic and don`t replace anything at your iphone because it must be released a bootrom update in 2-3weeks and that should solve all the iphones troubles.Good luck cya i think this will help a lot with error 13:D
Oct 29, 2009 | Apple iPhone 3G
Have unlocked 3g iphone on 3 network.when try to
You need to update carrier settings. Try here. http://www.benm.at/2009/06/13/helpbenmat/
Aug 07, 2009 | Apple iPhone 3G Black Smartphone
IPhone 3G Error 0xE8000001
Where did you purchase your phone? however, you first need to update itunes to 8.0.2, that might solve your problem. Unless you have an unlocked phone then restoring your phone is useless because when you restore an iphone with itunes in the US without an att sim card it will actually lock the phone, but I do not think that is your issue. the two things you are seeing the connect to itunes and the emergency call system means that your phone is not properly activated. which is done by connecting it to itunes.
Jan 20, 2009 | Apple iPhone 3G
IPhone 3G server problem
Apple had a problem with their servers during the iPhone 3G launch, they under estimated the number of people that will try to log into the iTunes server at once, as a result the server fall down.
If this is the error you get, when connecting to the iPhone 3G to iTunes server you can relax, your iPhone 3G is 100% OK.
It looks like this -
The barber pole spins for a minute then throws a -9838 error
Jul 13, 2008 | Apple iPhone 3G
Iphone will not restore
Try restoring in DFU mode, which is different than recovery mode. I happened to stumble across it while trying to restore an iPhone 3G that a user unplugged in the middle of the 3.1 update. It kept showing an error of 1611 or 13 and wouldn't restore in recovery mode. I found this DFU mode option and the restore worked fine. The DFU mode keeps the iPhone OS from loading, so you don't run into as many compatibility problems. Go into DFU mode, then try restoring the phone and see if that works.
http://techierambles.blogspot.com/2009/09/restore-iphone-with-error-13-or-1611-in.html
To enter DFU mode:
1. Connect your iPhone to your computer
2 . Turn iPhone off. You may have to hold the power and home buttons down together to force the phone off
3. Once the phone is off, hold the power and home buttons together for 10 seconds exactly
4. After 10 seconds, release the power button but keep holding home until the computer recognizes that a USB device was plugged in
5. iTunes should detect your iPhone correctly, and also allow you to restore to the factory default settings
Mar 02, 2008 | Apple iPhone Smartphone
Cell Phones Logo
13,651 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
